    [Plugin] Slicer5
    336 Posts 82 Posters 320.8k Views 81 Watching
    • F Offline
      funkenpedro
      Thanks TIG, i'll try those suggestions when I get home.
      Check out my new cardboard cutter:
      The cutter part cost me less than my donation πŸ˜„
      • Chris FullmerC Offline
        Looks like your 2 slices of the blade on that old singer from having a major electrical emergency πŸ˜„
        • F Offline
          funkenpedro
          Mwaha. I'll deny it if anyone ever asks but I've done some of my own house wiring, sometimese I wonder if I'm closer than two blade slices to an electrical emergency.
            RonDee
            I am very new to SU but I've managed so far to get by until now. I am trying to use Slicer5 to slice up my model. My model has 5 components all of which are solids and SU recognizes them as solids. However when I try to group them or create a new component out of them in order to use Slicer5 I get an error that my model isn't a manifold solid. This seems to only happen when the model is in a group/component. I'm not sure what to do, any help would be great.
            I couldn't upload the file so I posted it to the warehouse:
            http://sketchup.google.com/3dwarehouse/details?mid=a3927e6baceefafe4bb11506a66e5e90
              @rondee said:
              A 'solid' is a group or component-instance that only contains geometry [edges and faces] and every edge must have exactly TWO faces - no more and no fewer.
              It can also contain guide points and lines as these never interact with geometry.
              However, other object like nested groups or component-instances will cause the object to report as non-solid.
              You can work on a copy of your SKP and explode the nested objects inside their 'container' - if Entity Info says it's a 'solid' [aka 'manifold'] then you are good to go. If not, then it probably means that after the 'exploding' there are now some coincident edges, internal partition faces etc [i.e. > 2 faces shared by one edges].
              Thomthom's Solid Inspector can help identify these issues.
              My SolidSolver can try to fix them for you.
              You can also 'cut a section' and then try to fix things by hand...
                RonDee
                Yes all my parts have a volume amount, which I'm assuming means it is a solid because there is no other indication in the Entity Info saying the parts are solid or not. I have both fixSolid and Solid Inspector which helped immensely at getting my model to the state it is now. But the issue is when I group/make component all the parts together to use Slicer5. It says my model is not a manifold solid which I know it is. Maybe I'm doing something wrong?
                  Reread what I wrote.
                  Forget about 'the volume amount' - the top-bar of the 'Entity Info' dialog says 'Solid Group' or 'Group' etc. If the selected object is a solid it says it's a solid...
                  Adding two solid objects into a single group does NOT produce a single solid group.
                  A solid can only contain faces/edges, so two nested groups inside it won't ever make a solid even if they themselves are solids in their own right.
                  Explode the two solid objects inside the group and then that group MIGHT report as being solid.
                  BUT if those two previously 'solid' objects touched on an edge or had coincident faces etc, then their merged geometry will not meet the simple rule about every solid's edge only having exactly two faces: shared edges can have >=4 faces, coincident faces might have edges with 3 or 4+ faces.
                  So explode any nested solids to get back to one potential solid, and if you are unlucky perhaps with some further editing to move or remove non-compliant edges and/or faces, you'll get a single solid... πŸ˜•
                  • H Offline
                    hebron
                    Cant seeem to instal Slicer, i put the files in the Plugin Folder and nothing happens.. :s
                      Hebron
                      Please complete your profile details...
                      You give me no useful clues as to your OS or SketchUp version etc...
                      Slicer5 is v8 only, with additional options in the Pro version...The current [recommended] version is v8M4
                      Have you actually read the installation/use instructions?
                      RBZ
                      For >= v8M2 you can install this .rbz archive from Window > Preferences > Extensions button [or using Thomthom's 'Simple Installer' tool], the Slicer5 Extension and Toolbar should be auto-activated. Read the instructions...
                      ZIP
                      For < v8M2 - or a manual install you can extract this .zip archive and place the Slicer.rb file and the subfolder with all of its files intact into the Plugins folder, restart Sketchup. You need to activate the Slicer5 Extension from Window > Preferences > Extensions, the Slicer5 Toolbar may also need to be activated from View > Toolbars. Read the instructions...
                      So how have you installed it exactly ?
                      What have you tried ?
                      At what point is it not doing what's expected of it ?
                        randomroutine
                        hi tig,
                        im working on a model, its a 3d scan with some optimizations, and i cannot slice it with slicer5: it always complaint for "selected object is not a 'manifold' solid"
                        i was editing the object in blender and sculptris, and theres no problem in those programs.
                        what am i doing wrong?
                        thanks,
                        krisztian
                        • Rich O BrienR Online
                          It's not a solid volume.
                          Try using TIG's solid solver or Thomthom's Solid Inspector to find the problem.
                            There is nothing intrinsically wrong with using non-solid objects when modeling - provided that you don't want to report true volumes, or to do boolean operations using the 'Solid' tools etc... Some tools rely on the object being 'a manifold solid' for them to work properly...
                            "Slicer5" needs to make multiple intersections of the object of a plane that steps up/across/through the object... and then for each of those slices it has to decide what is a solid and what is a void, so it can then add faces appropriately to the cut-edges and then pushpull them into 3d slices.
                            So if the object is not a manifold solid it's going to be possible to intersect it with the plane and on some occasions we'll get a set of edges that won't be able to form a continuous loop, so this in turn can't take any faces and then in turn there is nothing to be pushpulled into a 3d slice.
                            A 'manifold solid' contains just edges and faces, and every edge has exactly two faces - no more and no fewer - so no holes in surfaces and no flaps where some edges have only one face, no faceless-edges, no internal-partition faces where some edges will have three or more faces, and of course no nested groups/components etc which also render the object non-solid [even if they themselves are 'solids' in their own right]. Exceptionally 'Guides-lines/points' are allowed inside a 'solid' but not recommended...
                            The earlier [much more limited version] of 'Slicer' [still available] did not have the v8 solidity check, and if you were to try it it might offer what you want, always provided that you realize that the 'leakiness' of non-solid forms will never give a full set of 'true' slices...
                            Non-solids are repairable...
                            Thomthom's 'Solid Inspector' tool reports on a selected object - highlighting areas where its solidity is compromised.
                            My 'SolidSolver' tool [get the latest/recent update] tries to fix such issues.
                            If there are obvious issues like 'large holes' in the surfaces, I suggest you edit it and manually repair those first.
                            However, 'SolidSolver' can be useful for tidying up the less obvious internal-partitions, tiny flaps and minuscule holes etc... that can all compromise 'solidity'. The more things you have that need fixing the longer the repair might take - some repairs break other aspects which then need fixing themselves etc, and of course anyone can contrive an object with such convoluted non-solidity that after several attempts at a fix it will remain firmly 'non-solid'...
                            SolidSolver will eventually report [in desperation] that the object is indeed 'irreparable' unless you do some significant manual reworking of its geometry...
                            Also note that if a solid object has tiny facets it might fail to form the intersected edges <~0.5mm and also fail to face/extrude into slices. In that case scale-up the model, scale-up you slicer settings to match, make the slices successfully and then scale-down - the tiny edges/facets can exist but their creation reaches a finite minimum limit as the tolerances can consider two points as being coincident when they are only a tiny distance apart, so no edge is made to span that tiny gap, and of course a face needs a continuous loop of edges to exist so it can't form...
                            • OxerO Offline
                              Oxer
                              Hi TIG,
                              I have a similar error like pbeseda:
                              @pbeseda said:
                              Error; #<TypeError; reference to deleted Face>
                              > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2041;in `pushpull'
                              > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2041;in `fatten'
                              > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2041;in `each'
                              > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2035;in `each'
                              > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2035;in `fatten'
                              > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;1612;in `run'
                              > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;793;in `initialize'
                              > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;657;in `new'
                              This is my Console Ruby Error:
                              Error
                              I work on Mac OSX Mountain Lion 10.8.2 and SU Pro v 8.0.1517
                                Here's v5.14 http://sketchucation.com/forums/viewtopic.php?p=374969#p374969
                                It adds a submenu item to activate/deactivate its toolbar without having to search through the View>Toolbars list...
                                It also traps errors that can occur with the Outline option etc where tiny edges can fail to form properly [size related issue].
                                Now if they do fail then the tool continues, so now the outline might have a few tiny bits missing, but the tool doesn't 'crash-out'.
                                Oxer: I hope this addresses your issue.
                                If not, then try Scaling everything up x10 or x100, doing the 'slotting' [making due allowance for the size changes], then Scaling back down to the original size.
                                The small geometry can exists, it just has problems in its creation.
                                By now we should all be aware of the tiny edge/facet creation issues, which prevent some native-tools and also some scripted equivalents from successfully making very small geometry...
                                  Clever, I'd never had thought of such cool feature πŸ˜‰
                                  • OxerO Offline
                                    Oxer
                                    Thanks TIG, I'm going to test the version v5.14.
                                    EDIT: The same error message in the Console Ruby with v5.14
                                    • jim smithJ Offline
                                      jim smith
                                      thanks for the update!
                                      "Out of clutter find simplicity,
                                      from discord find harmony,
                                      In the middle of difficulty lies opportunity"
                                      Albert Einstein
                                        Can you post the SKP or PM it if you like... with details about what you are trying to do [settings etc]...
                                        Have you noted the issues about smallness?
                                        It can also apply to largeness too...
                                        SketchUp/OpenGL can't cope with very tiny or very gigantic geometry and some edges/facets can fail to form... Also have the objects miles from the origin can also cause issues.
                                        Obviously I'd prefer that my tools don't 'fail', but sometimes it's the nature of SketchUp and not my code.
                                        If I can see the issue first hand I can perhaps see if I can trap for such errors better, or at least advise on the best way to model to avoid the issue...
                                        • OxerO Offline
                                          Oxer
                                          It's a very simple geometry, a cube and you can see the settings in the image below:
                                          Perhaps there is a conflict with another plugin, i'm going to uninstall other plugins.
                                            The following are the usual suspects [messing with base-class/methods ill-advisedly etc]...
                                            SketchyPhysics [current version]
                                            Podium [some earlier version]
                                            SunPosition [all versions]
                                            Matchbox [all versions]
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
