    How to create a Mask in Layout
    layout
    42 Posts 9 Posters 5.8k Views 9 Watching
    • bmikeB Offline
      bmike
      @dave r said:
      I thought that's what I said, Mike. πŸ˜„ You said it better, though. πŸ˜‰
      guess so. i thought you were suggesting hiding geometry with layers (which i do), but it can get tricky with foundations that might stick partially out of the ground. i usually just draw in a white shape, move it in front of the geometry i need to hide, and proceed to layout.
      all good though!
      lots of ways to work between the 2 programs!
        Ah. We were talking about something different after all. I was talking about drawing the shape in LayOut instead of in SU. I have created masks in SketchUp, though. Awhile back I did an animation of a sewing machine making a lock stitch. There's a mask like a mat in front of the geometry which allows components to move out of view. Most of the components are drawn 2D at different distances from the camera and some actually mask others.
        • bmikeB Offline
          bmike
          and yes, sometimes is just quicker to draw over your model in layout... πŸ˜„
          really depends on views / etc.
          • utilerU Offline
            utiler
            Charles - that is exactly how I do it. Works really well and super fast.
            As do I, Charles. It is the easiest way to form ground planes in section / elevation....
            Just Curious...
            • porch_unpluggedP Offline
              porch_unplugged
              I've just done a masks for a model with a steep enough gradient. I took the ground surface and built down below ground to create a plinth. I set up my views (2D elevations for now) using section planes, then added a section cut face to the section planes to hide all the unwanted geometry. the section cut face colour can then be changed to match the background leaving only the thick section cut line as the ground line. It was very quick to set up the 'plinth' and it gives the freedom to add and change any view with minimal extra work.
              hope this makes sense.
                Pictures, man. Pictures. Or it didn't happen. πŸ˜‰ πŸ˜†
                  porch_unplugged
                  here you go Dave.
                  i kept my section cut face dark as i reckoned it looked good, especially with a light text for the drawing description placed in the dark area of the plinth (did this in autocad, not using Layout anymore, just exporting jpegs from sketchup and importing into cad, and scaling up as appropriate).
                  the bottom of the plinth can be moved down so you don't see the second heavy line, but i'm just clipping it with a viewport in cad.
                  full plinth shown
                  section plane turned on
                  section cut face layer for that elevation turned on
                  final elevation
                    Ah, yes. I see.
                    Why aren't you using LayOut?
                      porch_unplugged
                      @dave r said:
                      Ah, yes. I see.
                      i've been using sketchup (free) casually for years, but really ramping up my use this year. I saw Nick Sonders video, and decided to give Layout and pro a chance. Did a full project in it to get a feel for it, but found a few things a bit annoying, slowness mostly, getting proper dimensions on 2D views, and a few other things. So i just left the trial run out, and haven't purchased the pro version (money is a bit tight for me at the minute 😞 ).
                      so since i was doing a lot in sketchup i needed someway to properly title drawings, so just decided to import jpegs into cad and use viewports like a normal cad drawing.
                        I see.
                        About 90% of the work I do in LayOut involves dimensions, lots of dimensions, and I don't have any trouble getting accurate dimensions. Maybe it's just me.
                          porch_unplugged
                          @dave r said:
                          I see.
                          I started getting this ~ symbol in some dimensions as well as there being problems getting vertical dimensions from 2D elevations, where it was picking up different points in the 3rd dimension. i'm just so used to autocad dimensioning (setting up styles etc.) that it's second nature to me. only thing that annoys me is i can't snap to a point with the jpegs.
                          but sure if layout works for you, keep going. πŸ‘
                            The ~ just indicates that your dimensions don't fall on increments set by the Precision.
                            Ah, well. To each his own.
                            • bmikeB Offline
                              bmike
                              @porch_unplugged said:
                              @dave r said:
                              I see.
                              so how are you getting accurate dimensions in autocad by dimensioning jpgs?
                              like dave said, to each his own, but i get accurate dimensions...
                              https://lh3.googleusercontent.com/-I3bxovoorfg/UBmKMN-lGPI/AAAAAAAATgA/yltmPVt9hRY/s800/8-1-12-roundbarn-section.jpg
                              https://lh3.googleusercontent.com/-CnOoKkgULBM/UBmMs-W-J1I/AAAAAAAATg4/FaiGqkiwXCI/s800/bazaar-garage-6-10-12-shake4.jpg
                              https://lh3.googleusercontent.com/-SP2sdU4ho7k/UFCiawfvwtI/AAAAAAAATsQ/a6GocncGtS8/s800/barn2.jpg
                                Mike, those are beautiful. πŸ‘
                                  porch_unplugged
                                  maybe it's just me then.
                                  At the minute(and i've only really started the thought process really) I'm importing the jpegs with a scale bar and just scaling up to 1:1 in cad. like i said, i can't snap to the end points for dimensions, so for the minute i'm scaling off the sketchup model, and offsetting construction lines in cad to snap to. not ideal i know, and i think i'll probably have to revert to using dimensions in sketchup so they export with the jpegs. this is my first project doing it this way (sketchup to cad), so i'm making it up as i go along. still only in sketch design, so ultra accurate dimensions aren't required yet.
                                    That just sounds like a lot of work to me. If it works for you, great. If I had to work that way I think I'd quit and do something else. πŸ˜‰
                                      porch_unplugged
                                      It's not too bad, drawing out a clipping mask in layout sounds like a lot more work to me. Doesn't look like I'll be getting Pro and layout any time soon, so it'll have to do. πŸ˜„
                                      • bmikeB Offline
                                        bmike
                                        have a look at my layout overview.
                                        even if you don't go pro - there are lots of ways to setup your sketchup to streamline your workflow.
                                          porch_unplugged
                                          @pbacot said:
                                          Brian: Have you tried a dwg export or vector pdf to CAD? I think there a plugins for the dwg or dxf if you don't have pro.
                                          thought never crossed my mind, i'll look into it, thanks Peter.
                                          I'm sure I've watched it already, but just waiting for it load again now (rubbish internet connection) Thanks Mike πŸ‘
                                          • pbacotP Offline
                                            Brian: Have you tried a dwg export or vector pdf to CAD? I think there's a plugins for the dwg or dxf if you don't have pro.
                                            • 3 / 3
