    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
    • thum8sT
      thum8s
      OMG, Amazing work, like magic!!! πŸ˜„
        Scottish
        Great ruby! but problems with install? doing this the standard way but comes up with
        Error Loading File clf_shape_bender_loader.rb
        no such file to load -- progressbar.rb
        any help out there??
        Scottih
        • Chris FullmerC
          yup, it requires an additional script called progressbar. There is a link to it on the first page, where you downloaded shape bender. Here's the link again:
          File Not Found
          (www.smustard.com)
            Scottish
            File Not Found
            (www.smustard.com)
            Thanks Chris, im a dummy sometimes...should have payed more Attention!, great work!
            • GarethG
              Gareth
              i have been using Shape Bender for over a year now and I love it..
              ....i can't remember ever thanking you, so, if i haven't, here it is >>>> Thanks mate...!! πŸ‘
                Rince
                After many tries I give up. I get to the green preview part, click enter and... nothing happens. Any ideas ? Someone had this problem before ?
                  Rince
                  Apparently I am very tired. Everything works perfectly. The bended shape was created about 50 meters up and out of sigh. Thanks Chris, amazing plugin, my new friend in work.
                    Don't give up without a fight !
                    Clear thousands of users can't be wrong, and you be right... YOU must be doing something wrong... [or at least something is conflicting and tripping you up...]
                    Run it with the Ruby Console open... are there any error messages as you use it?
                    Does the 'green preview' look like what you want / expect ?
                    What exactly happens / is left when you press <enter> ? Is it really 'nothing' ?
                    Is the object you are trying to bend very tiny or very small ?
                    Extremely tiny facets can't be made by SketchUp / OpenGL.
                    If you scale the object up x100 does it then work?
                    You can always scale down afterwards...
                    πŸ˜•
                    • P
                      PSP
                      Hi, I have downloaded the Shape Bender plug in but an unable to install it by moving it into the plug in folder or through preferences than extensions. When I drop it into the plug in folder and re-start Sketchup i get an error message and when trying to add through preferences the "rb" file is not able to be selected.
                      I have done some googling, is this because Sketchup 8 needs a "rbz" file??? I think this is the case.
                      If so what is the way around this.
                      many thanks in advance.
                        You are misconstruing things.
                        Version 8 CAN automate the installation of tools that are packaged as RBZ archives.
                        BUT this in no way precludes you from manually installing RB/RBS or any files or subfolders of files that have been properly extracted from a ZIP archive [an RBZ is simply a ZIP file with its filetype suffix changed!] Thomthom has made a v8 'Simple Plugins Installer' that automates the installation of all such file/archive types - get it from the Resources > Plugins Index. It'll stop you over thinking things.
                        This tool here comes packaged as a ZIP archive - so thomthom's tool can auto-install its contents for you. Alternatively you can rename it with a '.RBZ' suffix and the Preferences > Extensions button will then let you find it and install it that way... I still recommend thomthom's solution as it applies to all types with little effort/though on your part...
                        If you gave us the error message you got it means we don't need telepathy πŸ˜‰
                        I suspect that you have not installed the additional 'progressbar.rb' from Smustard.com that is clearly explained and linked on this tool's download page...
                        Once you have somehow successfully placed ALL of the required file[s]/related subfolder of support files, into the Plugins folder, then on a restart there should be an additional Preferences > Extensions item for the tool - so firstly this needs activating.
                        When this is activated its new View > Toolbars toolbar can be activated - thus allowing you to use the tool - provided of course that you have selected a suitable group/component-instance, a line that's parallel to the red-axis and a curve to bend around [the last two should be separate geometry, not touching any other geometry in the model...]
                        If you are still having issues check that you have FULL access-rights to the Plugins folder - simply being an Admin might still not give you enough access-rights - e.g. to add files or subfolders of files to the Plugins folder...
                        Also note that the required 'plugins' folder is the one in the HD Lib path and NOT the similar one in the Users Lib path...
                        • L
                          leadalchemist
                          hi there
                          this has been a PAIN to install...the final thing that worked was CREATING a folder plugins on the apple directory...it wasnt there before, then it showed up...
                          I hope that when 9 comes out they raise the price and put these plugin in the program
                          wish i had the time to learn Form Z which I own, luckily i have work to do
                          be well all
                          alan
                            Well, it's unfortunate that you didn't look at the thread on installing plugins first. You'd have found that the Plugins directory already exists so you don't need to create one. SketchUp comes with some files already included in the Plugins folder. πŸ˜’
                              That doesn't sound correct... πŸ˜• Here's a guide: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                              • T
                                thegoodguy
                                Thanks for this waaaaay clever and useful script Chris.
                                  alexxur
                                  Christian: este es uno de los mejores plugins que eh visto por aquΓ­. Es gratificante ver hasta donde puede llegar el ingenio humano. Felicidades y gracias..
                                  • N
                                    ningsiman
                                    I'm doing a natural trail in su and I hope this can help! Thank you so much!
                                    • F
                                      Flowrellik
                                      By far the best plugin I've seen. This reminds me very well of the Days at highschool when I practiced AutoCAD. Thank you very much.
                                      • Chris FullmerC
                                        Thanks everyone. Its nice to hear from people when it works, and not just from people who can't figure out how to install it. πŸ˜„
                                        • L
                                          Leon1217
                                          This is really amazing! Thank you a lot! β˜€
                                            alexxur
                                            Upss ... I forgot to download "progressbar.rb" as they say in the beginning. perhaps this requirement should be highlighted or larger font.
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 63
                                            • 64
                                            • 54 / 64
