    [Plugin] Solid Inspector
    303 Posts 99 Posters 368.4k Views 98 Watching
      Anton_S
      @thomthom said:
      All edges should have exactly 2 faces. Anything else and it's not a solid. No need to check for anything else.
      Wow, I was close! πŸ˜„
      @tig said:
      Although checking for nested objects like groups/images/instances also helps because they stop 'solidness' too... Guides...
      Thanks, good advice! πŸ‘ I guess that makes-up a complete defenition of a solid. πŸ˜„
        MYguel
        I have the following problem after installing solid inspector. When I start SketchUp I get the error dialog box:
        Error Loading File tt_solid_inspector.rb
        uninitialized constant TT;;GUI;;ToolWindow
        Does anyone encountered the same error previously? I use SketchUp 8 (the free version) from wine under linux, I do not think it could be related, but it is the only thing that is special considering my case.
        • sincerely,
        Myguel
          Did you also install TT_Lib2 as specified in the original post?
            MYguel
            Thanks for the quick answer. I copied the TT_LIB2 folder inside the Plugin folder of SketchUp. I suppose it's correctly installed so, but maybe I'm wrong?
            • sincerely,
              MYguel
              • sincerely,
                MYguel
              Can you post screenshot of the file and where they are located?
                MYguel
                All the files are in the .wine/drive_c/Program Files/Google/Google SketchUp 8/Plugins
                Here are the output of the command that list the content of the folders:
                $$>ls -1
                Examples
                examples.rb
                hideall.rb
                __MACOSX
                Ocean
                ocean_extension.rb
                samples_library
                samples_library_ext.rb
                TT_Lib2
                Utilities
                utilities.rb
                VolumeCalculator21.rb
                $$> cd TT_Lib2
                $$> ls -1
                Examples
                examples.rb
                hideall.rb
                __MACOSX
                Ocean
                ocean_extension.rb
                samples_library
                TT_Lib2
                Utilities
                utilities.rb
                manu@rebus;Plugins$ cd TT_Lib2/
                manu@rebus;TT_Lib2$ ls -1
                arc.rb
                attributes.rb
                babelfish.rb
                bezier.rb
                binary.rb
                bounds.rb
                CHANGELOG.txt
                color.rb
                core.rb
                cursor.rb
                cursors
                debug.rb
                definition.rb
                dimension.rb
                edges.rb
                entities.rb
                faces.rb
                geom3d.rb
                gizmo_manipulator.rb
                gui.rb
                image.rb
                inputbox.rb
                instance.rb
                integrity_list.dat
                javascript.rb
                json.rb
                libraries
                locale.rb
                materials.rb
                modal_wrapper.rb
                model.rb
                point3d_ex.rb
                point3d.rb
                progressbar.rb
                ray.rb
                README.txt
                selection.rb
                settings.rb
                simpletask.rb
                sketchup.rb
                system.rb
                toolbarwindow.rb
                toolwindow.rb
                uv_plane.rb
                uvq.rb
                version.rb
                webdialog
                webdialog_patch.rb
                win32.rb
                window.rb
                  MYguel
                  I confirm the problem comes from the wine install somehow. I install the plugin on a mac the same way as with the linux and it works perfectly.
                  I will ask for some help in the wine community.
                  Thanks for your answers so far.
                  • sincerely,
                  Myguel
                    @myguel said:
                    • sincerely,
                    Myguel
                    Let me know what you find out.
                    Maybe it could be encoding difference? I wonder if I recall someone on the forum mention something about line ending characters being an issue.
                      Soctrep
                      I'm a noob. Do I need SU PRO? I have SU 8, Mac OSX, dragged both TT_Lib2 2.6.0 and tt_solid_inspector to Google Sketchup 8 folder, tried unzipping in Terminal (says cannot find or open file even tho it's on desktop) and still can't find Solid Inspector in Tools. What else could it be?
                        Could be that you installed it incorrectly... not sure.
                        You might find it easier and more reliable to use this utility to install plugins:
                        http://sketchucation.com/forums/viewtopic.php?t=42315
                          Read and understand this http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/ and then this http://sketchucation.com/forums/viewtopic.php?p=426513#p426513
                          We could debate what files went into which folders... but if you follow this it will give you good results.
                          Also some tools are Extensions and need activating from the Preferences menu the first time you install them, and/or they have special submenus from which you can run them etc... Read the tool's usage notes to clarify this aspect...
                          • K
                            karel1962
                            Can't get to solid inspector work in Pro8 ???
                            .rbz plugins do work ... . rb plugins don't ??
                              You are somewhat cryptic in your error reporting...
                              I suspect that you are not installing the files properly.
                              Read the tool's download page again.
                              If you have v8 pro then the Preferences > Extensions > Installer tool will easily extract what's needed from the rbz archive and put it in the correct locations for you.
                              Note that this is an Extension and might require that it is one-time activated from 'Extensions', you might also need to restart SketchUp to get everything to auto-load the first time...
                              ALSO the tool needs a TT support Lib folder.
                              This is clearly explained on that page, there is a link to its download page...
                              Follow the instructions for the installation of that Lib too...
                              You'll probably have to restart SketchUp after the install to get everything working...
                              On a MAC the correct 'plugins' folder is the one at the root HD level NOT the 'users' one - this has been discussed in several threads in great detail...
                              To make installing tools' files and their support subfolders etc thomthom has also made a free Simple-Plugins-Installer, available via the Plugins Index. Once this is installed you can then easily install files and subfolders from rbz/zip archives and also individual rb/rbs files, without worrying about finding the correct folders etc...
                                What exactly "isn't working"?
                                Did you install the rb file correctly?
                                Here's an article on how to install plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                • mvollrathM
                                  mvollrath
                                  You sir are a godsend! Thank you so very much! πŸ˜„
                                  -Michael Vollrath
                                  • P
                                    Poffel
                                    @thomthom: With this tool and your fantastic tt_lib2 tools you are my hero! Before, I was almost desperated.
                                    πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                      amrossi
                                      Muito Obrigado!!!!
                                        a162042
                                        Outstanding tool . It took a little bit to figure out how to install on my MAC. What i found to be the problem was i did not have TT_Lib2 - 2.6.0.zip downloaded in my plugin folder once i loaded it i then loaded the solid inspector and it works great.
                                          apassemard
                                          Hello All
                                          I downloaded the Solid Inspector plugin on my Mac and it wasn't loading.. After some looking around I realized that I had put the plugin here:
                                          /Applications/Google SketchUp 8/SketchUp.app/Contents/Plugins
                                          Where it should have been put here:
                                          /Library/Application Support/Google SketchUp 8/SketchUp/plugins/
                                          Now it's working fine.
                                          Hopefully that help some of the Mac users out there who are having issues..
                                          Antony
                                            JBERGMAN
                                            This tool works great if you are trying to fix it yourself... I found this other plugin in the ruby library depot that not only identifies the problems, but corrects them too!
                                            http://rhin.crai.archi.fr/rld/plugin_details.php?id=793
                                            worked for me first try...
                                            • 15
                                            • 16
                                            • 7 / 16
