    Cone
    14 Posts 3 Posters 470 Views 3 Watching
    • E Offline
      expart
      Dave, thank you very much..
      I'm almost there.. See attached screenshot - why on the left side it goes outside" not inside?
        Yes, you are close. Put another arc in opposite the first one. That should get you going.
        FWIW, I did it in two halves because the ellipses are split by the arcs joining them. It's an easy matter to explode them and make them into a new component if you need.
        • E Offline
          expart
          Thank you very much!!!
          • massimoM Offline
            massimo Moderator
            If you use Fredo's curviloft select everything (faces + path) and see the picture below. πŸ˜„
            • E Offline
              expart
              Messimo,
              I've tried this plugin but I'm getting some errors during program startup:
              Error Loading File bootstrap_Curviloft.rb
              uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
              uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
              uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
              uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
              uninitialized constant Curviloft::T6Error Loading File __loader.rb
              uninitialized constant Traductor
              Regards,
              expart.
                You didn't get it installed correctly. Go back to the thread and read the first post. Make sure the footprint matches. Also make sure you have installed LibFredo6...
                • massimoM Offline
                  massimo Moderator
                  Oh, just noticed you said elipses. So maybe you can try the "offset contour along the rail".
                  About Curviloft: have you followed the instructions contained in the first post for the installation? Better you ask directly in that thread anyway.
                  • E Offline
                    expart
                    I'm almost sure that I did.. What is the footprint?
                    • massimoM Offline
                      massimo Moderator
                      This is the footprint:
                      Have you read carefully the first post as suggested?
                      • E Offline
                        expart
                        [attachment=0:guwe8v3w]<!-- ia0 -->Cattura.JPG<!-- ia0 -->[/attachment:guwe8v3w]
                        I've copied files from directory.. Not directory itself.
                        Thank you for your help!
                        Best regards,
                        expart.
                          Does that mean you have it working now?
                          • E Offline
                            expart
                            Yes πŸ˜„
