    Using the Cancel btn, to return to previous menu?
    22 Posts 5 Posters 971 Views 5 Watching
      Make each inputbox work from within its on method.
      When the 2nd one fails the 1st one is reused...
      def dialog1()
        @results1=inputbox...
        if @results1
          dialog2()
        else
          return nil
      def dialog2()
        @results2=inputbox...
        if @results2
          #do stuff with @results2
        else
          dialog1()
      πŸ˜•
        tomot
        TIG: I have been struggling with applying your code: Would you be so kind to attach your code to my simple example, TIA!
        =begin
        # Name;           Cancel
        # Description;    Initiate Canel routine in Dialog Box #2
        #                 returning user back to Dialog Box #1
        # Date;           2012/21/08
        =end
        require 'sketchup.rb'
        module CANCEL
                #Set default settings
                @height = 9.feet if not @height # floor to floor height
                @riser = 16 if not @riser       # no. risers total
            def self.cancel
                # Dialog box #1
                prompts = ["Floor/Floor Height ", "No. Risers"]
                values = [@height, @riser]
                results = inputbox prompts, values, "Dialog Box #1"
                return if not results
                @height, @riser = results
                @riserheight=@height/@riser  # riser height
                # Dialog box #2
                prompts = ["My RiserHeight  ", "--------"]
                values = [@riserheight, @any_entry]
                results = inputbox prompts, values, "Dialog Box #2"
                @riserheight, @any_entry = results
            end #self.cancel
        end #module CANCEL
            if( not file_loaded?("cancel.rb") )
                UI.menu("Plugins").add_item("Cancel") { CANCEL.cancel }
            file_loaded("cancel.rb") # load"cancel.rb"
        [my plugins](http://thingsvirtual.blogspot.ca/)
        tomot
          Reread my example.
          Change the method names to suit yourself.
          Change the two 'inputbox...' parts to suit your own prompts/values/titles etc...
          The way it works is straightforward.
          If you OK dialog1 it maybe does stuff like set @ values to the @results1 and then runs dialog2
          BUT if you Cancel dialog1 [i.e. @results1==nil] it stops processing [== return nil] and dialog2 never runs.
          If id does and you OK dialog2 it does stuff with those @ results from maybe both dialogs.
          BUT if you Cancel it then it'll reopen dialog1 and you can start the loop again...
          Please don't make modules methods like CANCEL.cancel() - it's very confusing πŸ˜•
            Jim
            Not often used, but Ruby has a loop statement. Just break out of the loop when proper input is entered.
              tomot
              This example has nothing to do with the user entering improper input. The results of the
              of the 1st dialog box are entered into the 2nd dialog box. Its really a very poor example of a calculator, in Ruby. Ideally I would like the division to take place and displayed in 1st dialog box.
              tomot
                tomot
                Short of tearing my hair out, of which I already have too few to part with. I don't seem to be able to get any menu to appear each time I add @results to my cancel.rb script. Neither does the ruby console identify any errors.
                I suppose part of my problem is not understanding how "OK" and "Cancel" magically become part of any dialog box. There is no specific Ruby code identifying either of those terms, in the script.
                =begin
                # Name;           Cancel
                # Description;    Initiate Cancel routine in Dialog Box #2
                # Date;           2012/21/08
                # revised         2012/03/09 not working!
                =end
                module CANCEL
                    def self.cancel
                        # Dialog box #1
                        def dialog1()
                            @results1 = inputbox prompts, values, "Dialog Box #1"
                            if @results1
                                dialog2()
                            else
                                return nil
                        return if not @results1
                        @height, @riser = @results1
                        # Dialog box #2
                        def dialog2()
                            @results2 = inputbox prompts, values, "Dialog Box #2"
                            if @results2
                            else
                                dialog1()
                        return if not @results2
                        @riserheight, @any_entry = @results2
                    end #self.cancel
                end #module CANCEL
                tomot
                  You haven't followed my template πŸ˜’
                  Try this...
                      =begin
                      # Name;           Cancel
                      # Date;           2012/21/08
                  TIG'd 201201003 !
                      =end
                      module CANCEL
                          def self.cancel
                              # Dialog box #1
                              def dialog1()
                                  if @results1
                                      dialog2()
                                  else
                                      return nil
                              # Dialog box #2
                              def dialog2()
                                  if @results2
                                      puts "Got here !"
                                      [@height,@riser,@riserheight,@any_entry].each{|e| puts e}
                                  else
                                      dialog1()
                                      return nil
                          end #self.cancel
                          unless file_loaded?(__FILE__)
                          file_loaded(__FILE__)
                          # load"cancel.rb"
                      end #module CANCEL
                  • Dan RathbunD Offline
                    Dan Rathbun
                    dialog not menu. A menu is a list of items, that drops down from the application menubar, (or pops up when you click the right mouse button.)
                    (1) It's a standard Windows API function, that the SketchUp API wraps in a Ruby method.
                    (2) You are discussing a certain sub-type of dialog box, called an inputbox, which always gets an OK and Cancel button.
                    Because if the user cancels, the return value evals false, otherwise the return value is an array (even if the user changed nothing,) which evals as not false. (Even an empty array and an empty string in Ruby will eval logically as not false.)
                    This is why we always do
                    return unless results
                    or
                    if results
                    just after the results = UI.inputbox( ... ) call.
                    Another sub-type of dialog box, is the messagebox. With that you CAN specify the button set, using constants that begin "MB" (such as MB_OK, MB_YESNOCANCEL, etc.)
                    With a messagebox, you DO check the integer return value against the constants IDYES, IDNO or IDCANCEL, etc.
                    I'm not here much anymore.
                      tomot
                      Try this...
                      I tried your code, but it does not produce an on screen dialog either 😒
                      tomot
                        tomot
                        Dan thanks for your comments. which raises one question. Would it then be possible to construct a single dialog box with a 3rd button ie. Calculate btn? Which in my example would calculate the division.
                        tomot
                          Learn web-dialogs and then you can have any buttons you want, called anything you want, doing anything you desire... πŸ˜•
                            Dan Rathbun
                            You only have two choices to construct dialogs with custom controls:
                            (1) Write native code for the platform your on, making system calls. (Very low-level nitty gritty advanced programming.)
                            (2) Write a WebDialog and use a HTML form.
                            @TIG EDIT: PUNCHBUG!
                              tomot
                              There is a (3) option. Maybe Trimble will add some more stuff to the SketchUp Ruby API, however I'm not holding my breath!
                              tomot
                                tomot
                                Luckily I have shortened my list of things that I desire. However if I were, and if I was my 20's, I would not waste my time learning web-dialogs. I'd learn COBOL, an almost extinct language, yet COBOL still runs 90% of the worlds financial programs. And since there are almost no COBOL programmers left, since most have or are retiring. One could make a great deal of money learning COBOL instead of Web-dialogs. πŸ˜„
                                However that still does not answer my followup question: why does the Cancel dialog not display with your included revisions?
                                tomot
                                  Dan Rathbun
                                  OMG! I had to take COBOL in college. I hated it.
                                  I always wanted to have a "COBOL Sucks!" T-shirt made.
                                    Here's an example I know works as I have tested it...
                                    require('sketchup.rb')
                                    module CANCEL_TEST
                                    	def self.run()
                                    		self.dialog1()
                                    	# Dialog box #1
                                    	def self.dialog1()
                                    		if @results1
                                    			self.dialog2()
                                    		else
                                    			return nil
                                    	# Dialog box #2
                                    	def self.dialog2()
                                    		if @results2
                                    			puts "Got here !"
                                    		else
                                    			self.dialog1()
                                    			return nil
                                    		UI.menu("Plugins").add_item("Cancel") { CANCEL_TEST.run() }
                                    	# load"CANCEL_TEST.rb"
                                    end#module
                                    IT is now properly structured to loop back into itself is needs be... πŸ˜’
                                      tomot
                                      Thanks TIG:
                                      I would never have been able to figure out the self.run routine on my own! πŸŽ‰
                                      tomot
                                      • 2 / 2
