    Using the Cancel btn, to return to previous menu?
    22 Posts 5 Posters 1.8k Views 5 Watching
    • T
      tomot
      TIG: I have been struggling with applying your code: Would you be so kind to attach your code to my simple example, TIA!
      =begin
      # Name;           Cancel
      # Description;    Initiate Canel routine in Dialog Box #2
      #                 returning user back to Dialog Box #1
      # Date;           2012/21/08
      =end
      require 'sketchup.rb'
      module CANCEL
              #Set default settings
              @height = 9.feet if not @height # floor to floor height
              @riser = 16 if not @riser       # no. risers total
          def self.cancel
              # Dialog box #1
              prompts = ["Floor/Floor Height ", "No. Risers"]
              values = [@height, @riser]
              results = inputbox prompts, values, "Dialog Box #1"
              return if not results
              @height, @riser = results
              @riserheight=@height/@riser  # riser height
              # Dialog box #2
              prompts = ["My RiserHeight  ", "--------"]
              values = [@riserheight, @any_entry]
              results = inputbox prompts, values, "Dialog Box #2"
              @riserheight, @any_entry = results
          end #self.cancel
      end #module CANCEL
          if( not file_loaded?("cancel.rb") )
              UI.menu("Plugins").add_item("Cancel") { CANCEL.cancel }
          file_loaded("cancel.rb") # load"cancel.rb"
      my plugins
      tomot
        Reread my example.
        Change the method names to suit yourself.
        Change the two 'inputbox...' parts to suit your own prompts/values/titles etc...
        The way it works is straightforward.
        If you OK dialog1 it maybe does stuff like set @ values to the @results1 and then runs dialog2
        BUT if you Cancel dialog1 [i.e. @results1==nil] it stops processing [== return nil] and dialog2 never runs.
        If id does and you OK dialog2 it does stuff with those @ results from maybe both dialogs.
        BUT if you Cancel it then it'll reopen dialog1 and you can start the loop again...
        Please don't make modules methods like CANCEL.cancel() - it's very confusing πŸ˜•
          Jim
          Not often used, but Ruby has a loop statement. Just break out of the loop when proper input is entered.
          • T
            tomot
            This example has nothing to do with the user entering improper input. The results of the
            of the 1st dialog box are entered into the 2nd dialog box. Its really a very poor example of a calculator, in Ruby. Ideally I would like the division to take place and displayed in 1st dialog box.
            my plugins
            tomot
            • T
              tomot
              Short of tearing my hair out, of which I already have too few to part with. I don't seem to be able to get any menu to appear each time I add @results to my cancel.rb script. Neither does the ruby console identify any errors.
              I suppose part of my problem is not understanding how "OK" and "Cancel" magically become part of any dialog box. There is no specific Ruby code identifying either of those terms, in the script.
              =begin
              # Name;           Cancel
              # Description;    Initiate Cancel routine in Dialog Box #2
              # Date;           2012/21/08
              # revised         2012/03/09 not working!
              =end
              module CANCEL
                  def self.cancel
                      # Dialog box #1
                      def dialog1()
                          @results1 = inputbox prompts, values, "Dialog Box #1"
                          if @results1
                              dialog2()
                          else
                              return nil
                      return if not @results1
                      @height, @riser = @results1
                      # Dialog box #2
                      def dialog2()
                          @results2 = inputbox prompts, values, "Dialog Box #2"
                          if @results2
                          else
                              dialog1()
                      return if not @results2
                      @riserheight, @any_entry = @results2
                  end #self.cancel
              end #module CANCEL
              my plugins
              tomot
                You haven't followed my template πŸ˜’
                Try this...
                    =begin
                    # Name;           Cancel
                    # Date;           2012/21/08
                TIG'd 201201003 !
                    =end
                    module CANCEL
                        def self.cancel
                            # Dialog box #1
                            def dialog1()
                                if @results1
                                    dialog2()
                                else
                                    return nil
                            # Dialog box #2
                            def dialog2()
                                if @results2
                                    puts "Got here !"
                                    [@height,@riser,@riserheight,@any_entry].each{|e| puts e}
                                else
                                    dialog1()
                                    return nil
                        end #self.cancel
                        unless file_loaded?(__FILE__)
                        file_loaded(__FILE__)
                        # load"cancel.rb"
                    end #module CANCEL
                • Dan RathbunD
                  Dan Rathbun
                  dialog not menu. A menu is a list of items, that drops down from the application menubar, (or pops up when you click the right mouse button.)
                  (1) It's a standard Windows API function, that the SketchUp API wraps in a Ruby method.
                  (2) You are discussing a certain sub-type of dialog box, called an inputbox, which always gets an OK and Cancel button.
                  Because if the user cancels, the return value evals false, otherwise the return value is an array (even if the user changed nothing,) which evals as not false. (Even an empty array and an empty string in Ruby will eval logically as not false.)
                  This is why we always do
                  return unless results
                  or
                  if results
                  just after the results = UI.inputbox( ... ) call.
                  Another sub-type of dialog box, is the messagebox. With that you CAN specify the button set, using constants that begin "MB" (such as MB_OK, MB_YESNOCANCEL, etc.)
                  With a messagebox, you DO check the integer return value against the constants IDYES, IDNO or IDCANCEL, etc.
                  I'm not here much anymore.
                  • T
                    tomot
                    Try this...
                    I tried your code, but it does not produce an on screen dialog either 😒
                    my plugins
                    tomot
                    • T
                      tomot
                      Dan thanks for your comments. which raises one question. Would it then be possible to construct a single dialog box with a 3rd button ie. Calculate btn? Which in my example would calculate the division.
                      my plugins
                      tomot
                        Learn web-dialogs and then you can have any buttons you want, called anything you want, doing anything you desire... πŸ˜•
                        • Dan RathbunD
                          Dan Rathbun
                          You only have two choices to construct dialogs with custom controls:
                          (1) Write native code for the platform your on, making system calls. (Very low-level nitty gritty advanced programming.)
                          (2) Write a WebDialog and use a HTML form.
                          @TIG EDIT: PUNCHBUG!
                          • T
                            tomot
                            There is a (3) option. Maybe Trimble will add some more stuff to the SketchUp Ruby API, however I'm not holding my breath!
                            my plugins
                            tomot
                            • T
                              tomot
                              Luckily I have shortened my list of things that I desire. However if I were, and if I was my 20's, I would not waste my time learning web-dialogs. I'd learn COBOL, an almost extinct language, yet COBOL still runs 90% of the worlds financial programs. And since there are almost no COBOL programmers left, since most have or are retiring. One could make a great deal of money learning COBOL instead of Web-dialogs. πŸ˜„
                              However that still does not answer my followup question: why does the Cancel dialog not display with your included revisions?
                              my plugins
                              tomot
                              • Dan RathbunD
                                Dan Rathbun
                                OMG! I had to take COBOL in college. I hated it.
                                I always wanted to have a "COBOL Sucks!" T-shirt made.
                                  Here's an example I know works as I have tested it...
                                  require('sketchup.rb')
                                  module CANCEL_TEST
                                  	def self.run()
                                  		self.dialog1()
                                  	# Dialog box #1
                                  	def self.dialog1()
                                  		if @results1
                                  			self.dialog2()
                                  		else
                                  			return nil
                                  	# Dialog box #2
                                  	def self.dialog2()
                                  		if @results2
                                  			puts "Got here !"
                                  		else
                                  			self.dialog1()
                                  			return nil
                                  		UI.menu("Plugins").add_item("Cancel") { CANCEL_TEST.run() }
                                  	# load"CANCEL_TEST.rb"
                                  end#module
                                  IT is now properly structured to loop back into itself is needs be... πŸ˜’
                                  • T
                                    tomot
                                    Thanks TIG:
                                    I would never have been able to figure out the self.run routine on my own! πŸŽ‰
                                    my plugins
                                    tomot
