    Using the Cancel btn, to return to previous menu?
    22 Posts 5 Posters 1.8k Views 5 Watching
    • T
      tomot
      Its something code wise I never was concerned about. Since there would normally be no reason to return to a previous menu. Presently the second menu on OK initiates the drawing routine, and on Cancel does nothing. 😞
      Here is the code for Dialog box in question
              # Dialog box
              railg = ["Both Sides", "Right only", "Left only", "None"]
              rail = ["Both Sides", "Inner only", "Outer only", "None"]
              enums = [ "", railg.join("|"), rail.join("|")]
              prompts = ["My RiserHeight  ", "Rails + Glass", "Rails - Glass"]
              values = [@ssincrt, @railg, @rail]
              results = inputbox prompts, values, enums, "Railing; Pick one option Only"
              return if not results
              @ssincrt, @railg, @rail = results
      my plugins
      tomot
        Jim
        Have a look at the inputbox method in Sketchup.rb (Tools folder.) It shows an example of using begin..rescue..retry..end.
        • T
          tomot
          Since there are 2 inputboxes in my example, or maybe more depending on the complexity of a particular Ruby script. I still don't see how I can control revisiting any inputbox in a script. Is there no inputbox identity name, which I could use to control via Cancel the direction a particular ruby would branch to. At the moment the only alternative I have, is to restart the script.
          my plugins
          tomot
            Make each inputbox work from within its on method.
            When the 2nd one fails the 1st one is reused...
            def dialog1()
              @results1=inputbox...
              if @results1
                dialog2()
              else
                return nil
            def dialog2()
              @results2=inputbox...
              if @results2
                #do stuff with @results2
              else
                dialog1()
            πŸ˜•
            • T
              tomot
              TIG: I have been struggling with applying your code: Would you be so kind to attach your code to my simple example, TIA!
              =begin
              # Name;           Cancel
              # Description;    Initiate Canel routine in Dialog Box #2
              #                 returning user back to Dialog Box #1
              # Date;           2012/21/08
              =end
              require 'sketchup.rb'
              module CANCEL
                      #Set default settings
                      @height = 9.feet if not @height # floor to floor height
                      @riser = 16 if not @riser       # no. risers total
                  def self.cancel
                      # Dialog box #1
                      prompts = ["Floor/Floor Height ", "No. Risers"]
                      values = [@height, @riser]
                      results = inputbox prompts, values, "Dialog Box #1"
                      @height, @riser = results
                      @riserheight=@height/@riser  # riser height
                      # Dialog box #2
                      prompts = ["My RiserHeight  ", "--------"]
                      values = [@riserheight, @any_entry]
                      results = inputbox prompts, values, "Dialog Box #2"
                      @riserheight, @any_entry = results
                  end #self.cancel
              end #module CANCEL
                  if( not file_loaded?("cancel.rb") )
                      UI.menu("Plugins").add_item("Cancel") { CANCEL.cancel }
                  file_loaded("cancel.rb") # load"cancel.rb"
              my plugins
              tomot
                Reread my example.
                Change the method names to suit yourself.
                Change the two 'inputbox...' parts to suit your own prompts/values/titles etc...
                The way it works is straightforward.
                If you OK dialog1 it maybe does stuff like set @ values to the @results1 and then runs dialog2
                BUT if you Cancel dialog1 [i.e. @results1==nil] it stops processing [== return nil] and dialog2 never runs.
                If id does and you OK dialog2 it does stuff with those @ results from maybe both dialogs.
                BUT if you Cancel it then it'll reopen dialog1 and you can start the loop again...
                Please don't make modules methods like CANCEL.cancel() - it's very confusing πŸ˜•
                  Jim
                  Not often used, but Ruby has a loop statement. Just break out of the loop when proper input is entered.
                  • T
                    tomot
                    This example has nothing to do with the user entering improper input. The results of the
                    of the 1st dialog box are entered into the 2nd dialog box. Its really a very poor example of a calculator, in Ruby. Ideally I would like the division to take place and displayed in 1st dialog box.
                    my plugins
                    tomot
                    • T
                      tomot
                      Short of tearing my hair out, of which I already have too few to part with. I don't seem to be able to get any menu to appear each time I add @results to my cancel.rb script. Neither does the ruby console identify any errors.
                      I suppose part of my problem is not understanding how "OK" and "Cancel" magically become part of any dialog box. There is no specific Ruby code identifying either of those terms, in the script.
                      =begin
                      # Name;           Cancel
                      # Description;    Initiate Cancel routine in Dialog Box #2
                      # Date;           2012/21/08
                      # revised         2012/03/09 not working!
                      =end
                      module CANCEL
                          def self.cancel
                              # Dialog box #1
                              def dialog1()
                                  @results1 = inputbox prompts, values, "Dialog Box #1"
                                  if @results1
                                      dialog2()
                                  else
                                      return nil
                              return if not @results1
                              @height, @riser = @results1
                              # Dialog box #2
                              def dialog2()
                                  @results2 = inputbox prompts, values, "Dialog Box #2"
                                  if @results2
                                  else
                                      dialog1()
                              return if not @results2
                              @riserheight, @any_entry = @results2
                          end #self.cancel
                      end #module CANCEL
                      my plugins
                      tomot
                        You haven't followed my template πŸ˜’
                        Try this...
                            =begin
                            # Name;           Cancel
                            # Date;           2012/21/08
                        TIG'd 201201003 !
                            =end
                            module CANCEL
                                def self.cancel
                                    # Dialog box #1
                                    def dialog1()
                                        if @results1
                                            dialog2()
                                        else
                                            return nil
                                    # Dialog box #2
                                    def dialog2()
                                        if @results2
                                            puts "Got here !"
                                            [@height,@riser,@riserheight,@any_entry].each{|e| puts e}
                                        else
                                            dialog1()
                                            return nil
                                end #self.cancel
                                unless file_loaded?(__FILE__)
                                file_loaded(__FILE__)
                                # load"cancel.rb"
                            end #module CANCEL
                        • Dan RathbunD
                          Dan Rathbun
                          dialog not menu. A menu is a list of items, that drops down from the application menubar, (or pops up when you click the right mouse button.)
                          (1) It's a standard Windows API function, that the SketchUp API wraps in a Ruby method.
                          (2) You are discussing a certain sub-type of dialog box, called an inputbox, which always gets an OK and Cancel button.
                          Because if the user cancels, the return value evals false, otherwise the return value is an array (even if the user changed nothing,) which evals as not false. (Even an empty array and an empty string in Ruby will eval logically as not false.)
                          This is why we always do
                          return unless results
                          or
                          if results
                          just after the results = UI.inputbox( ... ) call.
                          Another sub-type of dialog box, is the messagebox. With that you CAN specify the button set, using constants that begin "MB" (such as MB_OK, MB_YESNOCANCEL, etc.)
                          With a messagebox, you DO check the integer return value against the constants IDYES, IDNO or IDCANCEL, etc.
                          I'm not here much anymore.
                          • T
                            tomot
                            Try this...
                            I tried your code, but it does not produce an on screen dialog either 😒
                            my plugins
                            tomot
                            • T
                              tomot
                              Dan thanks for your comments. which raises one question. Would it then be possible to construct a single dialog box with a 3rd button ie. Calculate btn? Which in my example would calculate the division.
                              my plugins
                              tomot
                                Learn web-dialogs and then you can have any buttons you want, called anything you want, doing anything you desire... πŸ˜•
                                • Dan RathbunD
                                  Dan Rathbun
                                  You only have two choices to construct dialogs with custom controls:
                                  (1) Write native code for the platform your on, making system calls. (Very low-level nitty gritty advanced programming.)
                                  (2) Write a WebDialog and use a HTML form.
                                  @TIG EDIT: PUNCHBUG!
                                  • T
                                    tomot
                                    There is a (3) option. Maybe Trimble will add some more stuff to the SketchUp Ruby API, however I'm not holding my breath!
                                    my plugins
                                    tomot
                                    • T
                                      tomot
                                      Luckily I have shortened my list of things that I desire. However if I were, and if I was my 20's, I would not waste my time learning web-dialogs. I'd learn COBOL, an almost extinct language, yet COBOL still runs 90% of the worlds financial programs. And since there are almost no COBOL programmers left, since most have or are retiring. One could make a great deal of money learning COBOL instead of Web-dialogs. πŸ˜„
                                      However that still does not answer my followup question: why does the Cancel dialog not display with your included revisions?
                                      my plugins
                                      tomot
                                      • Dan RathbunD
                                        Dan Rathbun
                                        OMG! I had to take COBOL in college. I hated it.
                                        I always wanted to have a "COBOL Sucks!" T-shirt made.
                                          Here's an example I know works as I have tested it...
                                          require('sketchup.rb')
                                          module CANCEL_TEST
                                          	def self.run()
                                          		self.dialog1()
                                          	# Dialog box #1
                                          	def self.dialog1()
                                          		if @results1
                                          			self.dialog2()
                                          		else
                                          			return nil
                                          	# Dialog box #2
                                          	def self.dialog2()
                                          		if @results2
                                          			puts "Got here !"
                                          		else
                                          			self.dialog1()
                                          			return nil
                                          		UI.menu("Plugins").add_item("Cancel") { CANCEL_TEST.run() }
                                          	# load"CANCEL_TEST.rb"
                                          end#module
                                          IT is now properly structured to loop back into itself is needs be... πŸ˜’
                                          • T
                                            tomot
                                            Thanks TIG:
                                            I would never have been able to figure out the self.run routine on my own! πŸŽ‰
                                            my plugins
                                            tomot
