    [Plugin] Q JS ALIGN TOOLBAR
    63 Posts 35 Posters 113.3k Views 35 Watching
    • bagateloB
      bagatelo
      I change the plugin to show menus in "Plugins" Menu. Now we can set keyboard keys, is very useful to me.
      I thought about a function of "smart drop" for all of the possible directions of the axis, like this, the aligned objects if they would not fix in the most distant part of the object of alignment reference, but they would collide in the surface. Look image example. It would be as the plugin drop, but it would work in all possible directions by axes(9 possibilities, or 6, if we not consider middle). Maybe some keys like SHIFT can change this behavior.
      jsAlign.zip
      • bagateloB
        bagatelo
        Two years later I had another idea. Could someone modify this script to reposition the axes of the selected objects? Maybe by pressing a modifier key on the keyboard, such as alt or shift.
        • V
          Vicspa
          very useful plug-in, thank you 👍
          • Bob JamesB
            Bob James
            There does not seem to be a way to select which object the others are to align with. I've tried selecting #1 first and then #2, but get the same result if I select #2 first then #1.
            It would be very helpful if you could effectively say "make the other(s)" align with "this one"
            • PixeroP
              Pixero
              The script was written to work like many 2d align functions. Aligning to min, max or center, but for each axis.
              My original script (without the toolbar has some added functionality like that you can choose "custom" and enter a value (position) in one axis and align to that. When using a group you can choose if the groups max, center or min should align to the value.
              Not exactly what your after but might be useful sometimes.
              Here is the original script (without toolbar).
              JS Align
              • P
                Prevayl
                This tool is very useful. i just have one suggestion and im not sure if it was already mentioned but do to busy schedule,forgive if this was already suggested.
                But an added feature That functions similar to illustrator would be great where you an evenly distribute the objects(groups) between a distance.
                For example In adobe illustrator you can create 10 boxes and align them to a straight line but then you can equally distribute the spaces in between them based on the box furthest to the left and furthest to the right.
                That feature would make it easy to create a patio for instance with a gap in between each 2x4 and have it evenly spaced
                • F
                  function
                  it was brought up about a week ago
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=36006
                  I couldn't get d.bur's suggestion to distribute evenly, so I don't think it's been created yet- I am a huge fan of the adobe style align/distribute box, and I use the OP's mod all the time! Hopefully someone can complete the package sooner or later.
                  remember you can distribute the same object by moving and typing '/#' in the dimension box
                  on a side note:
                  d.bur's align script wouldhowever be a fine addition to this toolbar pack, "Align Along Line" for when ortho just can't do it - 👍
                  • F
                    fatihbarut
                    thanks alot
                    I really needed this
                    • F
                      fatihbarut
                      max
                      can we arrange something like this
                      align first clicked group/component to second one?
                      Not moving the second one.
                      Because otherwise it is really not possible to stay the things where they are and have to arrange the position of first and second object everytime we aling...
                      • bagateloB
                        bagatelo
                        I've been watching the tools to align objects in Photoshop, and I thought it would be really cool to have some additional tools to align in Sketchup. I use this plugin "Q JS TOOLBAR ALIGN" too much and I not use the toolbar, because I assign keyboard shortcuts for each function. I think the coolest would be to distribute equally spaced objects in a given axis by objects that would be in extreme.
                        • pbacotP
                          Here's one I've been using for the last umpteen years (PowerCADD). This is in addition to align commands for basic alignments. In any case, if you LOCK an object the rest must align to it. If an object's sides encompass the rest, the others align to it etc. (See picture)
                          The options in the pull down menu are:
                          To each other
                          To next mouse
                          To specified point
                          To Grid
                          (though I don't remember ever needing the last 3--easier just to use move)
                          I think it has a nice clarity but it's only 2d!
                          • CadFatherC
                            CadFather
                            yes, that is a good way to align/distribute objects in SU. unfortunately my programming skill are nowhere for this. 😞
                            maybe i'll start a new thread to see if any of the masters feels like taking this on.
                              Don't you feel like having a go at this? It's a great project to learn.
                              If you start, then if you get stuck, make a thread and the collective hive will assist. 😄
                              • CadFatherC
                                CadFather
                                Master Thom, you know i'm ok tweaking things...sometimes...after all it is just mechanics.. but this stuff is for people still endowed with the corpus callosum......
                                i'd rather keep using your plugins and keep my lobotomy safe...
                                • Bob JamesB
                                  Bob James
                                  How about Pixero? Didn't he create JS Algn orginally?
                                  • C
                                    caronte01
                                    Great plugin, just what I was looking for. I´m always amazed by the plugins to be found for whatever one needs.
                                    Thanks a lot for your work and keep it up!!!!
                                    Santiago
                                    • OsamaAlshamiO
                                      OsamaAlshami
                                      I disable "AD Block plus" but I can't see the Links 😡
                                        ROHIT532
                                        i use 2D graphic softwares like illustrator/corel new to SU.... want to learn how to use Q JS Align tool...
                                        • BoxB
                                          Hmmm, not a tool I have used before so I installed it. As the first post in the thread shows a toolbar I simply looked for a toolbar after installing it and would you believe it, it was just sitting there smugly waiting for me.
                                          • frascatiF
                                            frascati
                                            "smugly"? There's a whiff of Freudian slip there. Depressingly common of these threads when someone gets a little over the top frustrated like myself. Pile on even if you don't have anything really substantial to add such as help to find and use the plugin, or some more elegant method of accomplishing this very fundamental task in Sketchup.
                                            No link in my toolbar. Is there another "bar" i'm missing? Is it the toolbar along the side as "toolbar" would suggest? Or is it in the menus?
                                            It almost does not matter. I looked, again, for solutions to this crap and was once again utterly demoralized by discovering threads I started as long as six months ago that never did eventually address this. For a program like Sketchup not to be able to do this with it's basic functions, and then require an addon script that heaps layers of complexity on top of my principle, oft stated, need is just mind bending.
                                            So Box, with 1600 posts here, and never finding the need for this plugin, would you mind sharing with me your method of accomplishing the following...?
                                            I have two objects on the screen.
                                            neither occupy the same x,y,or z plane.
                                            I want to be able to click a point (a if you will) on both objects and fasten them, or move one to the other, in one move or click. Easy enough at this point with the move tool.
                                            ...click point 'b' on the second object, click any point along the same plane on the first objcet, and align them together on that axis with a single click or move.
                                            ...click point 'c' on the second object, click on any point along the same plane in the first object and with this third operation align them precisely within all axes.
                                            Better yet, by far, would be some method of selecting one object, selecting the second object with the shift or alt key so that they were both selected but understood to be related in the next move, and then having ONE dropdown command under tools to "align objects x,y,z.
                                            So all bad blood aside, please, someone tell me that my request has simply been misapprehended or misworded all along and I am, in fact, able to do this with sketchup wit a few simple commands.
                                            The couple of videos on youtube that address this need to align two objects are JOKES. Moving one point to an anchor on the second object and then fiddling around with the rotate tool, hit or miss, to bring the next two axis points into alignment. Watch these. It's actually laughable.
                                            • 2 / 4
