    [Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
    137 Posts 49 Posters 145.8k Views 49 Watching
      banxee
      When I use the import, I get a 'Missing Textures- Unknown Texture' window. The model info comes in but no surfaces. The jpgs for the textures are in the Files folder of the KML but it can't seem to find it.
      Am I missing a step?
        Aerilius
        This is an error message from SketchUp's Collada importer, not from my plugin (and I unfortunately can't do anything about it).
        SketchUp supports a lot of the Collada standard (actually more than any other program) but not all. SketchUp doesn't understand how your source program specifies the textures. I have reported this as a bug some days ago.
          If you open the main file in a plain-text editor like Notepad++.exe then it will be 'readable'...
          See what the image-file parts says...
          Logically it should be a simple file-name [image.jpg], so that if the image-file kept with the main file it will be found.
          If it's a 'relative' file-path including a folder then you must keep the image-files in that specified folder [e.g. images/image.jpg] with the main file.
          If it's an 'absolute' file-path [i.e. with a drive letter etc] then you need to recreate that exact same folder for those image-files [e.g. c:/temp/images/image.jpg].
          When the importer runs on the main file it should then find the image-files where it's expecting them to be...
          If the image-file names in the imported file bear no relationship to the actual image-file names you have, then you are in trouble - but even then you could try copying and renaming the image-files to suit, if you know which one is which that is... 😕
            Aerilius
            Yes, TIG is right, that is the normal way to trouble-shoot plain-text file formats like Collada.
            Here it's probably not a problem with the file path, but the xml structure is different ( %(#000040)[<effect><profile_COMMON><image>]) from what SketchUp expects ( %(#000040)[<surface>,<sampler2D>,<library_images>...]). I fixed this once manually, but it's so complicated that you wouldn't want to do do it with more than one or two files.
              banxee
              Hi & thx for the quick reply.
              I had tried opening the files in a text editor, thinking it was a pathing issue. I duplicated the path found in the text, but it still gave me the missing texture warning.
              The difference in the XML structure seems to be the issue.
              Oh well. At least I get the surfaces in the correct places.
              Thanks again
                biba28
                hi,
                first thank you for this plugin it will help me a lot in my project,so I will make a 3D modeling of a city,
                I have a shapefile I have converted to KML using gvSIG and now I want imported the kml file in google sketchup
                I insert your plugin, but that nothing is imported 😞
                I want to know if there is a structure ( balises or something) that I should add it to kml file for the import is correct.
                please help me
                yhank you for any help 😐
                  Aerilius
                  The plugin tries to extract from kml files what it can import, so it does not aim to import all. Maybe you can pm me an example file so that I can take a look at it and adjust the plugin 😉
                    Aerilius
                    I fixed the issue and uploaded a new version. Thanks for reporting!
                      Anton_S
                      Behold!!! Aerilius with mighty plugins approaches!! ☀
                        CochranRB
                        I am new to SketchUp. I saved a GE path as KMZ and KML files, but SU will not import the KMZ. Your plugin may assist with this problem. How do I download it?
                          The very first post in this thread has the tool's ZIP that you must download: then instructions on its extraction, installation and copious info on its usage... 😄
                          It might not help, depending what the files contain...
                          If you still have problems perhaps post the file here with a bit more info... 😕
                          • Q Offline
                            qpik
                            First of all thank you for the plugin.
                            Have I just found a possible bug in kmlimport.rb, linestring method, line 422 - "<tesselated>" instead of "<tessellate>"?
                            I'm learning how to model a terrain using my mobile's GPS and Sketchup. Since the Symbian app I use (GPSmap, http://www.vikinggames.hu/product.php?id=7) logs only CSV/KML Waypoints and additionally uses commas instead of points, so I have to manually convert the values. I'm new to KML (and I'm not a programmer) so the easiest way I noticed so far was to just put all the coords into a <LineString> tag, but in Sketchup the altitudes are wrong (i.e. flat or clamped to GE terrain).
                            So I just go through your code and KML documentation to find a solution.
                            Edit: which is as simple as adding <altitudeMode>absolute</altitudeMode> inside <LineString> tag.
                              Aerilius
                              That looks indeed like a bug! Thanks for reporting!
                              • SygskyS Offline
                                Sygsky
                                Hi! I'm interesting in follow - how this scripts should/could work at all?
                                I installed it correctly (think so), restarted SketchUp, called menu of "KML Tools", pointed "Export KML file" item, spend some time to look at the modal dialog, at last clicked "Ok" button, created new export file name and what? Nothing occurs! No any file anywhere was created, no any messages typed, nothing. Module keeps silence 😮)
                                I have last version of free license SketchUp downloaded yesterday.
                                Thx in advance.
                                  Do you have permission to write files to the destination folder ?
                                  Try your Desktop...
                                  Is there any exportable geometry in the SKP you are trying to export... etc ?
                                  • SygskyS Offline
                                    Sygsky
                                    Try your Desktop...
                                    Yes, yes, yes and yes all times 😎 But suddenly I found the solve. Don't sure what was an origin for the problem, so only describe result:
                                    Rubi is not one of my multiple languages but throw the code I found that in some checks if any external/internal functions in module return nil, it exits without warnings. As last action I did is a file name pointing, I tried to set full file path manually in the input dialog field, e.g. "C:\Temp\1.kml", not only name as it show in system dialog itself ("1.kml"). And it worked! So as I can suppose, alone file name is used internally to be used with some standard prefix of directory different from one used in a real path, use din dialog.
                                    Why? Windows 64b 7 Professional and Rubi pair knows only/ So export problems is solved. Let me check import ones in next time 😮)
                                    Thx for the wishes to help for this small problem!
                                      KentD
                                      Hi Aerilius
                                      I´ve used your plugin now and it seems to really work.
                                      I have to export a whole modeled city and I want them to be separate models.
                                      Your plugin does the trick! I make components of every and each model an export them.
                                      BUT if I have to ROTATE any of my models they will be exported randomly(it seems) and NOT in their right position.
                                      Any good suggestion how to deal with this?
                                      Regards
                                      KentD
                                        Aerilius
                                        The plugin should consider the rotation of the group's/component's bounding box.
                                        If the group is rotated, the rotation will appear as a "heading" attribute in the KML file, while the Collada file contains the group's inner coordinate system. At least it should work that way. Can you send (pm) me a file where it doesn't work that way?
                                          SBMattingly
                                          When using this tool that I just downloaded, I get a small window first that says "Loading correct elevation data failed. Internet Explorer 8 (or higher) required." I have IE 8 and SU 8.
                                          Ruby console says the following: "fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=37.355313&lng=-108.385784&username=demo&style=full&callback=returnJson
                                          returned:
                                          {"status":{"message":"the deaily limit of 30000 credits for demo has been exceeded. Please use an application specific account. Do not use the demo account for your application.","value":18}}
                                          Please help. I would love for this plugin to work.
                                          Stan
                                          • H Offline
                                            humbertoanastasia
                                            Hi there! Thanks for the plugin.
                                            I'm having an issue, though.
                                            I try to export an object, the dialog box opens, everything ok, and then...
                                            Sketchup and the plugin just stop working.
                                            Any ideas??
                                            Tanhks!
                                            • 5 / 7
