    Help Making a trestle base for table
    18 Posts 8 Posters 1.7k Views 8 Watching
      Yes this one is terrific! 😎 FredoScale
      http://forums.sketchucation.com/download/file.php?id=87786
      or a variation
      http://forums.sketchucation.com/download/file.php?id=87785
        cmartin
        @dave r said:
        Ah. I see. So what's the situation on using plugins? Fredo's FredoScale plugin has a very helpful tool for making the diagonal legs. if the exact width of the legs is important.
        I can install some, but I have to have our tech install them. I'm not allowed to do it. And then, if a computer needs to be reimaged, usually they need to be reinstalled. So, anything that I can do with the regular tools easily, i would rather do it that way if possible. That said, I do use some tools. We use the lines to cylinder tools when we do our park project. If it really can't be done easily without tools, I will use them.
          @cmartin said:
          ...Flickr is blocked here, so I'll have to wait till I get home to take a look at the photo...
          @dave r said:
          Sorry about the photo...
          Dave, for God's sake, why are you not attaching your images straight to the posts? We have so many "dead topics" (even yours) because of people "cleaning up ~unused~ or ~unnecessary~ photos" on their external storage space. 😞
            One reason is because there's a limit to the number of images I can upload for a single post. The tutorial I did the other night would be spread over three or four posts. I do sometimes upload them directly.
              Dave, please, let me know how many images you want to attach and i will be glad to fix the allowed number (actually, it is quite high now as this issue turned up when attaching the needed number images to the speed modelling contest was problematic). The current number of allowed attachments is 20. This should be enough for most of the tutorials IMO but if you need more, we can talk about it in BC. πŸ˜‰
              But you know what? On the new site, you will be able to easily create tutorials in seconds and you will only link back to them on the forums. (That is when we also introduce this feature). πŸ˜„
              (And on the new forums, you can keep adding attachments with that + sign which is broken here so there is no excuse) πŸ˜‰
                πŸ‘Ž Flickr
                Slow to load....very slow
                Sorry Dave, but when I see Flickr embeds I go make coffee
                  Funny. They are slow for me and this is the first time I've ever had anyone tell me that. I've been using Flickr for many years but only now does it seem to be a problem. I'll refrain from posting images until the new site is active, then. It should all be fast then.
                    That is two days from now. Please, save them and keep them at hand. πŸ˜‰
                      DanYHKim
                      I have a similar problem. I do not have admin rights on the lab computers, and so cannot install plugins. It turns out, if the lab computers have SketchUp installed, you can run a different instance of SketchUp from a USB drive.
                      On my home computer, I install SketchUp, plugins, components and materials bonus packs and other stuff that I want. After installation, I copy the "Google SketchUp 8" folder onto my flash drive. I also copy the Preferences.dat file that I generated when I created custom keyboard shortcuts, since I like having my shortcuts with me, but they do not get transferred automatically.
                      On the lab computer, I can run Sketchup.exe from the flash drive, and I have my plugins and components libraries available to me. I think this only works if my USB Flash version of SketchUp is a good match for the version already installed on the lab computer. Still, it works pretty well. It can be a little slow for some functions, because the computer is accessing the USB drive for the program, instead of the hard drive, but I can live with it. I think, if you do not have Admin rights, you can still copy your customized SketchUp program folder onto the computer desktop or some other location where you have access, then run the Sketchup.exe file from there, or even create a shortcut to the alternate location.
                      I made a video showing how I do this. It is a boring video, and I don't really get to the meat of the matter until 5:40. I seem to be the only one who does this. If it works for you, please report it on this thread. Thanks
                      [flash=425,344:3feltu5m]https://www.youtube.com/v/0VQmkz-MraA[/flash:3feltu5m]
                        DanYHKim
                        Getting back to the initial question: You're trying to make a trestle table base using rectangles that are of the same width?
                        If I am not misunderstanding things, I would figure that I would:
                        1. Make a single rectangle to represent one leg. Make it extra long.
                        2. Make this rectangle into a group
                        3. Use my Rotate tool to rotate this rectangle group about its center
                          1. Press the CTRL key to make this a Rotate-Copy action
                          2. Rotate the copy of the rectangle to the desired angle
                          3. Do this again for the opposite leg
                        4. Edit the rectangle groups
                          1. Adjust their lengths
                          2. Trim the angled ones so they are flat and horizontal on top and bottom
                          3. Push/Pull them to make them 3D
                        This would be a useful classroom exercise that demonstrates:
                        1. Isolation of geometries using groups
                        2. Use of Rotate tool and use of CTRL to modify a Rotate into a Copy/Rotate action
                        3. Editing within a Group
                        4. External Guidelines to guide editing in a group
                        (sorry, I'm too lazy to learn how to do list formatting)
                        • Jean LemireJ Offline
                          Jean Lemire
                          Hi Dave, hi folks.
                          To avoid the problem of multiple images I choose the multi scenes skptutorial files.
                          This means that I have to upload only one file.
                          Just ideas.
