    [REQ] Centerline of two curves
    15 Posts 8 Posters 2.3k Views 8 Watching
    • Arty2A Offline
      Arty2
      Duh! Just needed a push towards the right direction, it was right in front of my eyes after all.
      http://i49.tinypic.com/2a7j2bs.jpg
      Thank you Pilou!
        I see that you are using the V6 like me! 😎
        Welcome to the club! ☀
        • mitcorbM Offline
          mitcorb
          Are we talking about 2d here? What is wrong with Offset? I just did a spline simulation with offset both sides of the original on the xy ground plane.
            I think the OP is trying to get a mid line between two splines, not the other way round.
              Roger
              French Curve Tool
              How about the French-Curve Tool? Speaking of which reminds me that Monsieur Bezier was a French engineer working for Renault (?).
              http://www.azcreative.com
              • mitcorbM Offline
                mitcorb
                @Dave: Yes I see, now. 😳
                @Roger: I didn't realize that he worked for Renault. There's a heap o people really indebted to his invention, me for one.
                  Roger
                  I wrote a story for the Hitachi Data Systems magazine at one time about mainframe-based design and manufacturing systems and that was some of the data that I came up with. Also, if memory serves, one of the Renault brothers collaborated with the Nazis and after the liberation with beaten to death by a French soldier who used his helmet as a weapon.
                    If you close the ends of the two curves to form one face... then CurviLoft's Skinning tool will add a centerline, if you use the 'Generate intermediate edges' tool to make one central division...
                      Pierre Bézier
                      Comments are in English
                      See the drawings! 😉
                      Good page one
                      Good page two
                      (translated in English with Googletranslator 😉
                      http://www.christianboyer.com/jumieges/bezier1990.jpg
                        Michael, You can use either Bezier.rb or the BZ Spline Tools to make the original curves. After that, though, you appear to be getting the right screen to create the midline. All you need to do is change sampling to 2.
                          mrossk
                          Don't mean to hijack the thread- I tried this and when I run curviloft I don't get the same screen shown as the OP. I don't have the options for type of spline curve, nor for the number of segments. I've downloaded the most recent version of Curviloft as well as the Lib fredo directory. Does one also need the bezier curve plugin or something else. I apologize if I'm missing something obvious, thanks,
                          Michael
                          Edit: I think I discovered that the OP's screen shot is of the "Loft" function, not the "Skinning" function. Sorry to bother.
                          https://www.mkaplanfinefurniture.com/
                            mrossk
                            Thanks for the reply Dave. I get the curves drawn, but even when changing the sampling to "2", I still get many curved lines. I've only been able to get it to work by using the "loft" function.
                            At least I get a result...
                              Use the first icon on the toolbar
