    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 388.3k Views 92 Watching
      Version 1.1.4 Released
      • Merge Close tolerance wasn't remembered.
      • Toggle Select didn't work for new vertices after using Extrude Edges.
      • panixiaP Offline
        panixia
        man, doesn't work for me.. ๐Ÿ˜ž
        i re-installed version 1.1.3 and it works fine again..
          โ“
          Can you be specific please?
          • panixiaP Offline
            panixia
            so.. when i install the .rbz the tool stops to work at all, the regular sketchup 1 button toolbar shows, but when you clik it, the floating vertex tols toolbars doesn't appear at all.
            same thing on my laptop and desktop pc.
            i pulled off the .rb and the folder from plugins directory and reloaded the 1.1.3 version and works fine again on both machines.
            that's it
            i even tried to open ruby console but i can't understand how to use it, but i noticed that on version 3 it only says: "quietly_force_sync_mats_cb just called"
            when i opened it calling v4 it was continuosly scrolling tons of error messages.. i don't know..
              Those error messages are the most important pieces of information to report. Please post back the error messages as I am not able to reproduce this.
              Also, what OS, OS version and SketchUp version do you have.
              If you open the Ruby Console and type TT_Vertex.debug_info - what is the result of that?
              That is related to V-Ray for SketchUp.
              • panixiaP Offline
                panixia
                don't ask me why but now i reinstalled 1.1.4 and it works fine again..
                sketchup m3 on win7home premium, anyway
                also i notice in the credits it is not v 1.1.4 but 1.2.0 and also have this cool merge to point button, so the upgrade works..
                  Why don't you update SketchUp to M4?
                    ๐Ÿ˜ฎ ๐Ÿ˜ฒ Oh crap!
                    My head is still a mush after the field trip with the office - lack of sleep. I built the experimental development build instead of v1.1.4! ๐Ÿ˜ณ
                    Pulled and uploaded the correct version!
                    Oh well - 15 people got some secret experiment to play with. (Another thing to add to the check list...)
                    • panixiaP Offline
                      panixia
                      i'm not on mac, i'don't use layout, i don't have any problem at the moment with M3, the toolbars are stable (2 months!! record!!!) i enjoy the old logo, everything is fine, i'm lazy.. it's that enough? ๐Ÿ˜„
                      • panixiaP Offline
                        panixia
                        ๐Ÿ˜†
                          A good thing you got that error for whatever reason - otherwise I'd probably not have noticed for a very long time! ๐Ÿ˜•
                          • panixiaP Offline
                            panixia
                            this is luck, man ! ๐Ÿ˜› i'm proud to test this experiment!!! looks cool anyway! ๐Ÿ‘
                            • Bob JamesB Offline
                              Bob James
                              I've just finished using Vertex Tools (and Artisan) in a four-day effort in vertex movements to weld a 12 square mile set of Google Earth terrains into one seamless terrain.
                              I found that I very often needed to switch between the gizmo and the little circle that can only be activated by a series of actions. Would it be possible to set up the icons as shown in the attached picture.
                              โ€ข The arrow works as usual to select one or more vertices
                              โ€ข The circle activates that tool to allow continuous selection and moving individual vertices.
                              โ€ข The Gizmo allows immediate access to the gizmo to both select and move.
                              • pbacotP Offline
                                Bob,
                                I don't quite understand what your icons would do but I have some concerns that are probably similar. It took reading your post and thinking on my own issues to realize I can set tool hotkeys using the menu items for vertex tools. I change back and forth a lot with the two edit functions in VT tools.
                                I would wish to be able to orbit without losing the tool or selection, but hotkeys will help. If only SU were more generous in what we can use for hot keys.
                                I would be interested in your GE project: How large were the sections (set to get optimal texture?). Does joining them affect texture quality? Did you use overlap? So you can't just splice and dice, you had to adjust geometry? Artisan helped too? How did it go? etc.
                                  Bob James
                                  I tried using shortcuts as explained in the manual, but ran into a lot of problems so I abandoned that.
                                  As you can see from the attached pictures, the sections are of varying sizes with the largest (and lower fidelity) sections furthest from the main facilities. I did not actually join them into one huge terrain, but kept the original sections and provided smooth transitions between them. I kept the overlap to a bare minimum opting to provide an open area between them and using the sandbox tools to provide the transitions. That way I could control the textures.
                                  I had to severely sculpt the geometry around the facilities as you can see by the highly sub-divided areas (this is where I used Artisan the most). The sculpting was done to match the real topography as closely as possible.
                                  I found myself using the little circle tool most often. You have to โ€œSelect Noneโ€ in the right-click menu, then select the move tool, and, finally, select and move the vertex. This wastes a lot of time over several days: thatโ€™s why Iโ€™d like immediate access to the circle tool. On occasion the gizmo was the most efficient tool to use, but that has to be unhidden from the right-click menu: so, once again, it would be very useful to have it as a top level icon.
                                  Full ~3.5 miles x ~3.5 miles
                                  The central area where the main facilities are
                                  The location of the main facility. The open (green) area is where it goes. I keep that in a separate file and merge it in Thea. The other facility (launch site)is handled the same way. Buildings that don't belong to us are left in low-fidelity.
                                    You can get to the quick-select (little circle) very quickly by deselecting. Either use the menu item, a shortcut, or just click in empty space.
                                    That would be when you click on the Orbit tool - instead of using the middle mouse button?
                                    (Was it you I talked about this?)
                                      What kind of problems where that? Something misbehaving?
                                      Once you where in quick-select mode (the little circle) did you then have to switch back and forth?
                                      I'm just trying to work out how the extra buttons you proposed end up with less clicks.
                                      • pbacotP Offline
                                        Bob,
                                        Thanks for sharing. That looks like an impressive terrain--so I guess no room for the building in SU.
                                        I hope it wasn't me! ๐Ÿ˜ณ I'll check it out. My setup here doesn't have a mouse that works like that, so I got in the habit of just using "O". Didn't know it mattered. Thanks
                                        Happy Birthday, thomthom! Have fun in Colorado! Peter
                                          Bob James
                                          Some times I wanted to start out using the "little circle". If there were a "little circle" icon I wouldn't have to [right click, set "select none", click the move icon] to get it.
                                          Sometimes I wanted to start out with the gizmo. If there were a gizmo icon I wouldn't have to right-click and unhide the gizmo. And then hide it again.
                                          Then, of course, there were the times that I'd start out with one and want to switch to the other in the course of correcting a set of vertices: right-click, select ....... ๐Ÿ˜’
                                          When I tried the shortcuts they got all mixed up with the standard SU shortcuts ("M" for move, etc.). The manual said that once in VT the shortcuts would not get confused with the standard ones. Not so in my experience.
                                          This is such a great tool: it's just that I felt like I was wasting a lot of time clicking menues.
                                            Bob James
                                            "You can get to the quick-select (little circle) very quickly by deselecting. Either use the menu item, a shortcut, or just click in empty space."
                                            (what happened to being able to identify this as a quote?)
                                            I'm sorry, but I don't understand this at all.
                                            • Deselect what?
                                            • Using menu items requires one or more extra clicks
                                            • Empty space where?: in the icon bar?
                                            • 11
                                            • 12
                                            • 13
                                            • 33
                                            • 34
                                            • 11 / 34
