    STL Cleanup from Sketchup
    15 Posts 3 Posters 2.8k Views 3 Watching
      That is the Layer it is on.
      Does it just say Group?
      Can you share the SketchUp file? You can upload 4mb files here to the forum
      • N
        N15ck
        I cant really share it, it is 25mb haha, and I am unsure on how solidsolver works, I have got solid inspector to work but unsure on the solver also It says 'Group (1 in model)'
          If it say group and solid inspector is highlighting errors then it needs more clean up to heal it.
          • N
            N15ck
            Thanks, What would you suggest? I thought about exporting as STL and using an application to shrink wrap, but I dont know of any free versions πŸ˜•
              Free STL exporters or Free 3D apps that Shrink Wrap?
              Here's a free STL exporter/importer
              http://forums.sketchucation.com/viewtopic.php?t=24515
              Blender has a means of shrink wrapping meshes
              • N
                N15ck
                it is annoying as I used my normal methods of designing on sketchup (normally solid) but on this one it isnt solid πŸ˜•
                  How many errors is Solid Inspector showing?
                  There's also this...
                  http://forums.sketchucation.com/viewtopic.php?t=41289
                  which costs €22
                  • N
                    N15ck
                    which costs €22
                    Many, you can see lots of yellow circles
                      So, you either buy a plugin to try and fix
                      You fix it yourself manually
                      You try and learn how to add a Shrink Wrap in Blender
                      You hire someone to do the donkey work
                      You privately share the file with someone who could quickly identify the problem
                      Basically you need either pockets or time.
                      • N
                        N15ck
                        I will look into each one to see which is best, thanks for the help!
                          Why not the free Meshlab ? πŸ˜‰
                          It's the Mesh doctor! πŸ’š
                          http://t0.gstatic.com/images?q=tbn;ANd9GcS-mYuW4N9e40Tk4nIQEuhyDIlBTW-QWa-SZaD3Sz7IBoLxorUActDqle9e
                          • N
                            N15ck
                            downloading as I type 😍
