    [Request] A practical WALL tool
    21 Posts 6 Posters 2.2k Views 6 Watching
    • EdsonE Offline
      Edson
      they are both great plugins and very useful too. however, they are much more complex than I asked for. as far as I could see, none of them allows me to draw a wall by clicking continuously. it is either necessary to select a path or a shape to generate a wall.
      http://www.mahfuz.arq.br
      • rodrigonotorR Offline
        rodrigonotor
        Hi Edson, maybe this work for you:
        http://www.sketchupbim.com/Product.html
        β€’ [Sketchando.net](http://foro.sketchando.net/portal.php) β€’ www.arqcad.net β€’
        • pbacotP Offline
          You can with PB
          • EdsonE Offline
            Edson
            @cmd said:
            Edson,
            BuildEdge Plan just came out and it has a wall tool in combination with a roofing tool that you may want to test out.
            (www.buildedge.com)
            CMD
            I have watched the BuildEdge Plan videos and it is exactly what I wanted! its alignment feature is brilliant as it allows one to see it in action instead of trying to guess which side it will actually go in one's model.
            although it is windows-only now I have been assured there is a mac version on the way.
            • aarondietzenA Offline
              aarondietzen
              Good news! We are running the Mac version through it's final (pre-beta) paces. I will be launching a Beta version first thing next week!
              It has been a long road... but I can see an apple-shaped light at the end of the tunnel!
              "Imagination is more important than knowledge..."
              - Albert Einstein
              • pbacotP Offline
                Great news, πŸŽ‰ Aaron! πŸŽ‰
                  Seems to me that Double line by Didier Bur makes that you want at the first post πŸ˜„
                  And you was the first to aswer to him "fantastic gift, didier! thanks! " πŸ˜‰
                  Last version Double line2 By Didier Bur, Jim Foltz ! 😎
                  (in Draw menu)
                  Works also in inclined plane πŸ˜‰
                  So what is your reproaches about it ? πŸ˜„
                  And dig it or not following the round a clock rotation of your drawing! πŸ˜‰
                  So you can make windows with it in the same time πŸ˜„
                  A very cool one! πŸ‘
                  • EdsonE Offline
                    Edson
                    (in Draw menu)
                    pilou,
                    yes, you are quite right. I praised it in the past but recently I started having trouble using it. for some reason the walls started to grow downwards instead of upwards. as it was happening quite often and I could not find the any reason for its erratic behavior I decided to look for some other tool.
                    but thanks for insisting. perhaps DL deserves a second chance.
                      You must make a group (of the floor) if you build walls on something!!! πŸ€“ (not in the empty space)
                      And after
                      It's because you turn your creation walls in the wrong clock wise or not! πŸ˜‰
                      • EdsonE Offline
                        Edson
                        And after
                        I never try to build walls on empty space!
                        come to think of it, another reason for not using DL 2 was the fact it does not work 100% on mac: pressing Tab on mac does not invoke the parameters dialog. this reduces its functionality.
                          Sorry I have a PC πŸ˜„
                          Why not: it's very practical: you make some walls then you move them somewhere πŸ˜‰
                            aarondietzen
                            Hi All,
                            I just wanted to follow up here with a quick note that we have launched our Mac version (Beta).
                            http://forums.sketchucation.com/viewtopic.php?f=15&t=47904
                            Aaron
                            - Albert Einstein
                              Cool for the Macs users! πŸ˜‰ After the Iphone 5 they are lucky! β˜€
