    How to deform ovalish object
    70 Posts 5 Posters 11.3k Views 5 Watching
      rumcajs
      Yeah, that is exactly that case as I mention here:
      http://forums.sketchucation.com/viewtopic.php?f=323&t=47752
      That when I rotated the arms (outside of component), they were not correct (same angles), but I did not see that. Even now after correction, they are not on 100% same angles. I would like to see some plugin for situation like this.
        rumcajs
        You are right, I have seen this and they use mirroring function.
        http://www.youtube.com/watch?v=LFqopkUTO0Q&feature=relmfu
          No need of plugin for that πŸ˜„
          Just take this who is in good position then make a "scale -1" in the direction wished!
            rumcajs
            Q: When I try to rotate arms, should I rotate it outside or inside model?
            I see my model's arms are not exactly in same (mirrored) position.
            If it's component themselves : rotate it outside the component else all other component (mirrored) will rotate also!
            Sure I did so. But it is rotation like in y1=60Β°; y2=-60Β°; x1=13Β°; x2=-13Β°; and so ... it is mirrored...
            So when I started to rotate the arm, so I had to rotate 1st arm and then the 2nd arm. So there is result that they are not same angle. Because I did not check the angle, when I started to do it. Now it looks like it is better then it was before.
              rumcajs
              I rotated head and removed the sides because they were deformed. I try to close the head now but when I draw the circle so it does not fit. Do you have idea why and what to do with it?
              human body - head v6.skp
                rumcajs
                Or better I should take the ovalish head first and scale it to make rounded head... But how to fix that. Sizes are 0,23x0,21m and I want 0,23x0,23. But with tape I can only change the scale with ratio 1:1...
                http://i50.tinypic.com/70c014.png
                  rumcajs
                  True, I don't know why I did not think about that (scale one direction). It should work. I'll test tomorrow.
                    Scale tool by one direction ?
                    Draw a line with the good measure for snap on it
                    About the close circle in the file you post
                    Just draw a diameter πŸ˜„
                    That close it !
                      rumcajs
                      http://i50.tinypic.com/2nlztxi.png
                        Yes In general drawing any line who close an "hole plane surface" close this surface an make it "physic" πŸ˜‰
                        I have not this tool
                        what is the meaning of S, H, G, W, E ,L, C ?
                          Thx πŸ˜„
                            rumcajs
                            I have this as point of start. I have changed the position of components (was incorrect) and height (radius is 23 cm , 0,23m ), I will rescale when the head will be done.
                            Well, here we go. I will start according the video frames.
                            head 7 proportions v6.skp
                              rumcajs
                              I need to create the blue sphere, but I cannot success. The best result I got is the sphere on right! I cannot to get the edges to be exactly on the axis. I created 12x16 sphere, but as you can see, there is always one extra face on the axis! Please help.
                              http://i49.tinypic.com/34f1ymd.png
                              The face modeling in SU looks prety simple, if you go according the frames from the video.
                              Pilou, that is the Pen Tool + as Gayieus recommended to me. See your link before. It is after the post when I said, I head dream about SU, that I was drawing soft lines directly. The shortcuts are S like soften edges, H like hidden edges... Guide, Weld, Edge, Line ...
                              head v6.skp
                                rumcajs
                                In the last version of the file I uploded, there is the change. I did deleted the middle strip, and from the half I made component. According the frames from video, this fits:
                                See this:
                                http://i48.tinypic.com/16c2gsj.png
                                It's exiting!
                                  about your sphere 12*16
                                  As the follow-me must have a segment perpendicular
                                  And you don't have it with these number of arc segments!
                                  So you must make other thing πŸ˜„
                                  Like this you have a sphere 12 *16 πŸ˜‰
                                  I come back with the good image πŸ˜„
                                    See above for your sphere 12 * 16 with the vertices on the axes πŸ˜‰
                                      rumcajs
                                      OK, I can use that technique next time. Right now, it is going well. I have finished the front (just basic shape).
                                      head 8 front v6.skp
                                        Have you remark that the blue one is like Iron man! πŸ˜‰
                                          rumcajs
                                          Blue color of the skin? Or what?
                                          I have found one complication. Because the scull if rounded - the faces are rounded. But the at front, there are two rectangles (vertically) - 1) nose and eye corner 2) month and chin ... and then he draw on this places he has them streight like rectangle. But I have to create triagles instead. So I separate every rectangle to 2 triangles. This slows down. If there would be any feature to simplify work - to make the 4 edges of rectangular parallel to create rectangle, then it would be much more simple. This takes a lot of time, still. I use construction lines, but they are from "From" view so they don't fit from Top down view. That also slows down the work. Many of zooming into very detail, then I place the starting point of new line onto edge (still in "From" view). Then zoom out "Zoom extents" then finish line.
                                            rumcajs
                                            I also found some 3D eye maybe in French? Now I moved one line to form eye whole and add the eyes. You can check. I will check the plugin sure.
                                            I wanted to learn to draw, so this way of working with 3D modeling on simplified models, that's for me the right thing to learn to understand and remember human body proportions and perspective.
                                            Edit:
                                            The video. This way of editing is very inaccurate. Even he did not use human photo. I would rather need plugin to simplify faces.
                                            So if you have triangles like that:
                                            _______
                                            I would hover over that those triangles, and then I would click force the edges to form rectangular. That would be really great simplification for that what I would like to. Because there are many rectangle shapes, on which you can draw next rectangle shapes. But I don't have that. I have triangles. And that s*ks..
                                            Edit2:
                                            http://science.howstuffworks.com/environmental/life/human-biology/eye1.htm
                                            Although small in size, the eye is a very complex organ. The eye is approximately 1 inch (2.54 cm) wide, 1 inch deep and 0.9 inches (2.3 cm) tall.
                                            head 13 eyes 3D move (green axis) v6.skp
                                            • 2 / 4
