    How to deform ovalish object
    70 Posts 5 Posters 9.8k Views 5 Watching
      rumcajs
      OK, but how can I change the object? Is there some plugin which can correct the object if I had draw a circle there?
      Similar situation - here I need to add circles to the body to create neck and shoulders shape:
      http://i45.tinypic.com/2585f9w.png
        So select only the part that you want modify
        Inverse Selection / Hide
        Just carreful some object are Groups, some are components !
        So when you modify a component all instances of this component will be change!
        Except if you make it "Unic"
        I need to add the circle one or two*.
        Ok Use this plugin ๐Ÿ˜‰
        I come back in few minute ๐Ÿ˜‰
          Extrusion Cross editing : it's free in the Training edition ๐Ÿ˜‰
          [flash=560,315:1i4goeba]http://www.youtube.com/v/11mhfNJlduE[/flash:1i4goeba]
            You can also use Zorro2! by Whaat ๐Ÿ˜Ž
            Just use the views front side top and camera parallel projection for have straight circle // existing circle
            if you trim a spheric form!
            Zorro2 don't create face inside the volume! ๐Ÿ˜Ž
            You can't "slide" the cross section like the previous tool !
            Move, scale, Rotate yes ๐Ÿ˜„
            So be sure to place it! ๐Ÿ˜‰
            Will be in the Menu Tool !
              rumcajs
              That plugin is really cool. I've seen face editing. Cool. Thanks.
                rumcajs
                It works, but I have problem with the neck. I have did a mistake when I scaled a neck and saved it. The neck had torned off. I needed to rescale it, but it did not connect with the body already. How to connect it? I cannot draw on it until it is connected back.
                http://i47.tinypic.com/2evpz7l.png
                  Impossible to answer without file ๐Ÿ˜„
                  (save as V6)
                    rumcajs
                    I had a dream about SU during I slept (Yes, I work during my sleep!). It was that I could draw soft edges or smooth edges directly. I realized, that I don't know if is it possible? Acually I don't know much about soft edges, I've just look for help and found Soft edges dialog box:
                    http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114940
                    But where can I found this box? I had seen it somewhere days ago.
                    Next thing I have in my brain now is that, it could be good if we could have a mode for interference for segments. For example, I want to find some segment and must click it before I can resize/rescale it. Would not be much better to click directly on the ends of segment? Just idea.
                    I did not yet check the last plugin.
                    Here is the file:
                    human body v6.skp
                      @rumcajs said:
                      ...Yes, I work during my sleep!...
                      Interesting. I have something similar: I sleep during my work! ๐Ÿ˜ฎ
                      ...It was that I could draw soft edges or smooth edges directly...
                      Maybe with this plugin? http://forums.sketchucation.com/viewtopic.php?t=37359
                        The box is here :Menu WIndow / Soften edges ๐Ÿ˜‰
                        Else subdivision modeling for Sketchup is here ๐Ÿ˜‰
                        Artisan by Whaat (39$ )
                        A free very basic is here by Rick Wilson
                        or more recent with another concept by guitar list
                        http://www.guitar-list.com/files/styles/article-pic/public/gearpics/Smooth-glass.jpg
                        http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=26902;image
                        All for segments and vertex is here : Vertex Tools by Thomthom (20 $)
                          About the neck
                          Why do you say that is not more part of the body ?
                          Seems it is ๐Ÿ˜„
                          In front view inside the level of the group / component
                          Just make a box selection from right to left (so else who touch this box is selected) on the "cone neck"
                          then right click / reverse faces
                          When you move a segment of the neck it moves also the body, so it's makes part of the body ๐Ÿ˜„
                            rumcajs
                            The color. Why the neck has blue color and the body is white?
                            • N Offline
                              numbthumb
                              Reversed faces.
                              Comfortably numb...
                                Yep reverse face : blue can't receive the light of sun (so internal faces - backface)
                                White = receive the light of sun (so external faces)
                                Useful for the render program !
                                If you select one face of a volume* then right Click / Orient faces (different than Reverse faces !!! )
                                all faces of the volume will take the "work's color" (blue or white) of the first face clicked!
                                • if the volume is well built ๐Ÿ˜‰
                                  rumcajs
                                  I've got it.
                                  Any suggestions how to correct shoulders muscles, up on collar bone? So called posterior lateral triangle of Trapezius muscle? This is the muscle which leads from top of shoulder up to neck.
                                  http://4.bp.blogspot.com/-QSWjVVJqt0k/T_W7sQDyQJI/AAAAAAAAA0E/rkmUw573Jis/s1600/8_31_10-shoulder+muscles.jpg
                                  Also I tried the Cross Section tool to add a circle bellow neck from Tgi3D, but it writes to me: Cannot resolve cross section. This is after I reversed the neck faces. I don't know if it is the cause, because this should not have effect. I click just outside the neck. Try.
                                  Question:
                                  Do you know some video tutorial how to model head from the sphere or oval? This head does not look good at all. I don't need to model face, but just the main proportions of the head.
                                  human body v6.skp
                                    rumcajs
                                    Q: When I try to rotate arms, should I rotate it outside or inside model? I see my model's arms are not exactly in same (mirrored) position.
                                      If you want really sculpt anatomy, maybe Sketchup is not the best tool for that ๐Ÿ˜‰
                                      of course you can use the Vertextools but...it's "old school" polygon sculpting! ๐Ÿ˜‰
                                      [flash=560,315:uck4kicz]http://www.youtube.com/v/xfM02PleFMg[/flash:uck4kicz]
                                      Try more Sculptris, a free crazzy one !
                                      Or if you want more elaboate body in SU use the Free Make Human and imort it inside SKetchup ! โ˜€
                                      That is the method of Orgelf! ๐Ÿ˜‰
                                        If it's component themselves : rotate it outside the component else all other componant (mirrored) will rotate also!
                                        I have not this one so can't answer ๐Ÿ˜ณ
                                        add some segments and move them but it's very difficult work!
                                        About video
                                        type sculpt face modeling in youtube ๐Ÿ˜‰
                                        or this one ๐Ÿ˜‰
                                          rumcajs
                                          Yeah, that is exactly that case as I mention here:
                                          http://forums.sketchucation.com/viewtopic.php?f=323&t=47752
                                          That when I rotated the arms (outside of component), they were not correct (same angles), but I did not see that. Even now after correction, they are not on 100% same angles. I would like to see some plugin for situation like this.
                                            rumcajs
                                            You are right, I have seen this and they use mirroring function.
                                            http://www.youtube.com/watch?v=LFqopkUTO0Q&feature=relmfu
                                            • 2 / 4
