    How to deform ovalish object
    70 Posts 5 Posters 9.8k Views 5 Watching
      Q: When I try to rotate arms, should I rotate it outside or inside model?
      I see my model's arms are not exactly in same (mirrored) position.
      If it's component themselves : rotate it outside the component else all other componant (mirrored) will rotate also!
      Also I tried the Cross Section tool to add a circle bellow neck from Tgi3D,
      I have not this one so can't answer 😳
      Any suggestions how to correct
      add some segments and move them but it's very difficult work!
      About video
      type sculpt face modeling in youtube πŸ˜‰
      or this one πŸ˜‰
        rumcajs
        Yeah, that is exactly that case as I mention here:
        http://forums.sketchucation.com/viewtopic.php?f=323&t=47752
        That when I rotated the arms (outside of component), they were not correct (same angles), but I did not see that. Even now after correction, they are not on 100% same angles. I would like to see some plugin for situation like this.
          rumcajs
          You are right, I have seen this and they use mirroring function.
          http://www.youtube.com/watch?v=LFqopkUTO0Q&feature=relmfu
            No need of plugin for that πŸ˜„
            Just take this who is in good position then make a "scale -1" in the direction wished!
              rumcajs
              If it's component themselves : rotate it outside the component else all other component (mirrored) will rotate also!
              Sure I did so. But it is rotation like in y1=60Β°; y2=-60Β°; x1=13Β°; x2=-13Β°; and so ... it is mirrored...
              So when I started to rotate the arm, so I had to rotate 1st arm and then the 2nd arm. So there is result that they are not same angle. Because I did not check the angle, when I started to do it. Now it looks like it is better then it was before.
                rumcajs
                I rotated head and removed the sides because they were deformed. I try to close the head now but when I draw the circle so it does not fit. Do you have idea why and what to do with it?
                human body - head v6.skp
                  rumcajs
                  Or better I should take the ovalish head first and scale it to make rounded head... But how to fix that. Sizes are 0,23x0,21m and I want 0,23x0,23. But with tape I can only change the scale with ratio 1:1...
                  http://i50.tinypic.com/70c014.png
                    rumcajs
                    True, I don't know why I did not think about that (scale one direction). It should work. I'll test tomorrow.
                      Scale tool by one direction ?
                      Draw a line with the good measure for snap on it
                      About the close circle in the file you post
                      Just draw a diameter πŸ˜„
                      That close it !
                        rumcajs
                        http://i50.tinypic.com/2nlztxi.png
                          Yes In general drawing any line who close an "hole plane surface" close this surface an make it "physic" πŸ˜‰
                          I have not this tool
                          what is the meaning of S, H, G, W, E ,L, C ?
                            Thx πŸ˜„
                              rumcajs
                              I have this as point of start. I have changed the position of components (was incorrect) and height (radius is 23 cm , 0,23m ), I will rescale when the head will be done.
                              Well, here we go. I will start according the video frames.
                              head 7 proportions v6.skp
                                rumcajs
                                I need to create the blue sphere, but I cannot success. The best result I got is the sphere on right! I cannot to get the edges to be exactly on the axis. I created 12x16 sphere, but as you can see, there is always one extra face on the axis! Please help.
                                http://i49.tinypic.com/34f1ymd.png
                                The face modeling in SU looks prety simple, if you go according the frames from the video.
                                Pilou, that is the Pen Tool + as Gayieus recommended to me. See your link before. It is after the post when I said, I head dream about SU, that I was drawing soft lines directly. The shortcuts are S like soften edges, H like hidden edges... Guide, Weld, Edge, Line ...
                                head v6.skp
                                  rumcajs
                                  In the last version of the file I uploded, there is the change. I did deleted the middle strip, and from the half I made component. According the frames from video, this fits:
                                  See this:
                                  http://i48.tinypic.com/16c2gsj.png
                                  It's exiting!
                                    about your sphere 12*16
                                    As the follow-me must have a segment perpendicular
                                    And you don't have it with these number of arc segments!
                                    So you must make other thing πŸ˜„
                                    Like this you have a sphere 12 *16 πŸ˜‰
                                    I come back with the good image πŸ˜„
                                      See above for your sphere 12 * 16 with the vertices on the axes πŸ˜‰
                                        rumcajs
                                        OK, I can use that technique next time. Right now, it is going well. I have finished the front (just basic shape).
                                        head 8 front v6.skp
                                          Have you remark that the blue one is like Iron man! πŸ˜‰
                                            rumcajs
                                            Blue color of the skin? Or what?
                                            I have found one complication. Because the scull if rounded - the faces are rounded. But the at front, there are two rectangles (vertically) - 1) nose and eye corner 2) month and chin ... and then he draw on this places he has them streight like rectangle. But I have to create triagles instead. So I separate every rectangle to 2 triangles. This slows down. If there would be any feature to simplify work - to make the 4 edges of rectangular parallel to create rectangle, then it would be much more simple. This takes a lot of time, still. I use construction lines, but they are from "From" view so they don't fit from Top down view. That also slows down the work. Many of zooming into very detail, then I place the starting point of new line onto edge (still in "From" view). Then zoom out "Zoom extents" then finish line.
                                            • 2 / 4
