    How to deform ovalish object
    70 Posts 5 Posters 11.9k Views 5 Watching
      About the neck
      Why do you say that is not more part of the body ?
      but it did not connect with the body already. How to connect it?
      Seems it is πŸ˜„
      In front view inside the level of the group / component
      Just make a box selection from right to left (so else who touch this box is selected) on the "cone neck"
      then right click / reverse faces
      When you move a segment of the neck it moves also the body, so it's makes part of the body πŸ˜„
        rumcajs
        The color. Why the neck has blue color and the body is white?
        • numbthumbN
          numbthumb
          Reversed faces.
          Comfortably numb...
            Yep reverse face : blue can't receive the light of sun (so internal faces - backface)
            White = receive the light of sun (so external faces)
            Useful for the render program !
            If you select one face of a volume* then right Click / Orient faces (different than Reverse faces !!! )
            all faces of the volume will take the "work's color" (blue or white) of the first face clicked!
            • if the volume is well built πŸ˜‰
              rumcajs
              I've got it.
              Any suggestions how to correct shoulders muscles, up on collar bone? So called posterior lateral triangle of Trapezius muscle? This is the muscle which leads from top of shoulder up to neck.
              http://4.bp.blogspot.com/-QSWjVVJqt0k/T_W7sQDyQJI/AAAAAAAAA0E/rkmUw573Jis/s1600/8_31_10-shoulder+muscles.jpg
              Also I tried the Cross Section tool to add a circle bellow neck from Tgi3D, but it writes to me: Cannot resolve cross section. This is after I reversed the neck faces. I don't know if it is the cause, because this should not have effect. I click just outside the neck. Try.
              Question:
              Do you know some video tutorial how to model head from the sphere or oval? This head does not look good at all. I don't need to model face, but just the main proportions of the head.
              human body v6.skp
                rumcajs
                Q: When I try to rotate arms, should I rotate it outside or inside model? I see my model's arms are not exactly in same (mirrored) position.
                  If you want really sculpt anatomy, maybe Sketchup is not the best tool for that πŸ˜‰
                  of course you can use the Vertextools but...it's "old school" polygon sculpting! πŸ˜‰
                  [flash=560,315:uck4kicz]http://www.youtube.com/v/xfM02PleFMg[/flash:uck4kicz]
                  Try more Sculptris, a free crazzy one !
                  Or if you want more elaboate body in SU use the Free Make Human and imort it inside SKetchup ! β˜€
                  That is the method of Orgelf! πŸ˜‰
                    If it's component themselves : rotate it outside the component else all other componant (mirrored) will rotate also!
                    I have not this one so can't answer 😳
                    add some segments and move them but it's very difficult work!
                    About video
                    type sculpt face modeling in youtube πŸ˜‰
                    or this one πŸ˜‰
                      rumcajs
                      Yeah, that is exactly that case as I mention here:
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=47752
                      That when I rotated the arms (outside of component), they were not correct (same angles), but I did not see that. Even now after correction, they are not on 100% same angles. I would like to see some plugin for situation like this.
                        rumcajs
                        You are right, I have seen this and they use mirroring function.
                        http://www.youtube.com/watch?v=LFqopkUTO0Q&feature=relmfu
                          No need of plugin for that πŸ˜„
                          Just take this who is in good position then make a "scale -1" in the direction wished!
                            rumcajs
                            If it's component themselves : rotate it outside the component else all other component (mirrored) will rotate also!
                            Sure I did so. But it is rotation like in y1=60Β°; y2=-60Β°; x1=13Β°; x2=-13Β°; and so ... it is mirrored...
                            So when I started to rotate the arm, so I had to rotate 1st arm and then the 2nd arm. So there is result that they are not same angle. Because I did not check the angle, when I started to do it. Now it looks like it is better then it was before.
                              rumcajs
                              I rotated head and removed the sides because they were deformed. I try to close the head now but when I draw the circle so it does not fit. Do you have idea why and what to do with it?
                              human body - head v6.skp
                                rumcajs
                                Or better I should take the ovalish head first and scale it to make rounded head... But how to fix that. Sizes are 0,23x0,21m and I want 0,23x0,23. But with tape I can only change the scale with ratio 1:1...
                                http://i50.tinypic.com/70c014.png
                                  rumcajs
                                  True, I don't know why I did not think about that (scale one direction). It should work. I'll test tomorrow.
                                    Scale tool by one direction ?
                                    Draw a line with the good measure for snap on it
                                    About the close circle in the file you post
                                    Just draw a diameter πŸ˜„
                                    That close it !
                                      rumcajs
                                      http://i50.tinypic.com/2nlztxi.png
                                        Yes In general drawing any line who close an "hole plane surface" close this surface an make it "physic" πŸ˜‰
                                        I have not this tool
                                        what is the meaning of S, H, G, W, E ,L, C ?
                                          Thx πŸ˜„
                                            rumcajs
                                            I have this as point of start. I have changed the position of components (was incorrect) and height (radius is 23 cm , 0,23m ), I will rescale when the head will be done.
                                            Well, here we go. I will start according the video frames.
                                            head 7 proportions v6.skp
                                            • 2 / 4
