    IES light not showing
    renderpluginsextensions
    11 Posts 5 Posters 5.3k Views 4 Watching
    • panixiaP Offline
      panixia
      have you turned your vray light into a component? that's a known issue..
        @billychaics said:
        is it compulsary to put an ies file for the input ?
        Yes, you must specify an IES file - that is the whole point of that light type.
        • ? Offline
          A Former User
          πŸ‘Š i had tried to put in IES file and enabled lights and default lights in Options as well and put my scene to 2300 time so it would appear in night to test out my IES light but unfortunately I failed to see any lights
          my IES light is not grouped nor making it component or exploded. i just having one ies in my empty scene.
          • panixiaP Offline
            panixia
            can you share your IES file so that other users can test it?
              +1
                ccs1987
                Sorry it's my mistake for not sharing up the IES light.
                Here's the ies light
                ies
                Sketchup 8 pro
                Vray
                Intel Xeon W3520 2.67Ghz
                12Gb Ram
                Nvdia Quadro FX 1800
                • panixiaP Offline
                  panixia
                  simply it'weak.
                  it works, but as you can see in the attachment, this is the result in a test scene with walls 300cm high, max power wich apparently is 1e+06 😲 (digit 999999 and try to rise further πŸ˜• )
                  the size of ies light is default vray and also standard visopts..
                  try another file there are some great ies file in the same free collection you downloaded πŸ˜‰
                  i think this one is intended for some mini led or something, but not for light a whole empty scene..
                    ccs1987
                    Thanks for the info.
                    But one silly question, if i dun put any ies file in the input that means there will be no light at all though i put my power to 5e6 for example
                    Sketchup 8 pro
                    Vray
                    12Gb Ram
                    • andybotA Offline
                      andybot
                      It will show a very faint sphere, but the power setting doesn't seem to make a difference.
                        ccs1987
                        Thanks guys. i finally got my IES light working
                        Sketchup 8 pro
                        Vray
                        12Gb Ram
