    White Living
    25 Posts 18 Posters 3.6k Views 18 Watching
      pibuz
      I'd very like to post my last work.
      It's some contest which came up in the Indigo Renderer site: the exercise was about setting materials and lighting. The white base scene was given, but I totally revised that. I must give credit to the mate Indigo/SkIndigo user FoXar/Roo Evans which converted the original file into a much more handy SketchUp scene.
      Cheers!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • alvisA Offline
        alvis
        ๐Ÿ˜ฎ OMG! This was done with Sketchup? 99.9% as a photo
        • locoL Offline
          loco
          Very very impressive, it is just like a photo..fantastic work ๐Ÿ˜ฒ
          Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
          • DanielD Offline
            Daniel
            you are to be congratulated, Pibuz; they look excellent.
            My avatar is an anachronism.
              mystix89
              wow ๐Ÿ˜ฒ
                pibuz
                Hi pals! Thank you a lot, really! The appreciation of the community means a lot to me!
                The entire scene is done with sketchup (and I wouldn't exclude the possibility to share it all in short time, if it can be useful to anyone), but some of the hipoly models included (the two plants e.g.) are obj "external references", supported by the great SkIndigo (another cool trick by Dale Martens AKA Whaat). All the rest is only a patchwork of good models I found browsing the web. I worked a little on the lamps, which were imported as 3ds files found in the websites of the specific firms (they're quite common models, easy to find). A big THANK YOU and all the credit for the books is dedicated to Teofas (drawn from the beautiful "architect's office" scene), who saved my a** once again.
                • novenaN Offline
                  novena
                  wow! your work is just fantastic... could you talk a little bit about rendering times???
                  http://hdzarkitektur.wordpress.com/
                  • beginnerB Offline
                    beginner
                    Executed to perfection ๐Ÿ‘
                    Prefer the 2nd with lights ON
                    Regards, SU 'beginner'
                      pibuz
                      Hi Novena!
                      Render time was quite long, due probably to the original render high resolution (which was 8500pixels wide) and the number of light layers (one for each lightsource, so that I could adjust them during the rendering). The total rendering time was 60hours or so.
                      I must say that I let it cook over my old and faithful q6600 (quad core, 2.44GHz I think), an up-to-date hardware configuration could have done it in 24 hrs I think.
                      • N Offline
                        ninopiamonte
                        I've seen it already in the forum, and it was
                        You just really deserve to win with that result!
                          Really nice PR render, fantastic. Any chance you could share the file/model? No worries if not I reckon a few people would like the chance to see what their render engine could produce fom it is all. Really nice mate.
                          • CarlohC Offline
                            Carloh
                            woooow...that ground texture looks fantastic!!
                            • cheddaC Offline
                              chedda
                              excellent job
                              Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                pibuz
                                @chedda
                                Thanks a lot!
                                @carloh
                                Hi mate! The wooden planks come from CGtextures, great texture although I had my "fun" making it seamless ๐Ÿ˜† Bump and exponent maps are directly drawn from that (2 fast passes in PS)
                                @MikeAmos
                                I'll upload the model ASAP. Keep in mind that there could be "false" geometry, used as dummy for higher poly external and internal models. Rendering with something different from Indigo will certainly produce different outputs.
                                @ninopiamonte
                                Thanks my friend. ๐Ÿ˜‰
                                  cuttingedge
                                  Great work.. I love the floor and the ceiling. Looks so natural, not flat like how I usually do it. Lighting is perfect. The only 2 things which would
                                  rather not look real is the curtain nearest to the camera, and 2nd the throw pillows. Otherwise all models seem to be good enough for a perfect render.
                                  • soloS Offline
                                    ๐Ÿ‘
                                    Awesome render, you captured the mood well, a true homage to what a good unbiased render engine is capable of in the right hands.
                                    • hellnbakH Offline
                                      hellnbak
                                      One of the best I've seen on these forums ๐Ÿ‘ ๐Ÿ‘
                                        pibuz
                                        @cuttingedge
                                        Hi pal! I was never convinced by the exact same things, but the time was running out and I had none to spend to fix those. They're not "photorealistic" but still "acceptable".. Maybe I'll be able to work on that in a couple of weeks. Thanks a lot by the way!
                                        @solo
                                        Thanks a lot mate! A compliment like this from a pro like you really flatters me.
                                        @hellnbak
                                        Thanks a lot!
                                        • john2J Offline
                                          john2
                                          wow!!. Indigo render produces such awesome effects!! ๐Ÿ‘ superb!! i thought vray was the most photorealistic one. ๐Ÿ˜‰
                                          Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                          • Bryan KB Offline
                                            Excellent render. Indigo, huh? Wow.
