Default sides for circles and arches
Does anyone know how to change the default sides (segments) on circles and arches?
I know, that once I click on the arch icon I can type the # of segments that I want and it will maintain that setting until I close the model (or by using the entity info if the arch has been created already). What I want to do is have as a default 24 segments in my arches as soon as I open sketchup (instead of 12).
I haven't checked because it's not an issue for me, but have you tried saving the setting with your preffered template?
Short answer: you can't.
This isn't something you can change via a setting.
It's hard coded.
This was discussed a while ago...
On a PC only... if you write a script that auto-loads and runs itself that includes some WScript calls to make key-strokes it can be done, but it's a cludge...
http://forums.sketchucation.com/viewtopic.php?f=323&t=39837&p=352123&hilit=wscript+circle#p352123 -
It doesn't work... I tried that already
@tig said:
It's hard coded.
http://forums.sketchucation.com/viewtopic.php?f=323&t=39837&p=352123&hilit=wscript+circle#p352123Hmmm... Thanks for the link! it makes sense
