    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      Maybe you must post some file skp for more helps πŸ˜„ (save as V6)
      And one image before / after πŸ˜„
        alexpacio
        few days is that I do not work anymore fredoscale.
        fredoscale using the center of the object (CTRL), I scale the entire object and not expanding the center.
        What has happened?
        What should I change?
        thanks
        Solved.
        Updated files and everything ok
        thanks anyway 😍 😍 😍
          alexpacio
          My screen capture
          https://www.dropbox.com/s/hvahftfqaf3d6f6/scale 1.jpg
          https://www.dropbox.com/s/68rq6gsyc26plhy/Scale 1b.jpg
          https://www.dropbox.com/s/fae0p3kc5p46tuf/Scale 2.jpg
          not scale
          final result
            Roberto, these DB images do not load here this way (it actually links to a page where they are inserted). Could you rather attach them to your post?
              alexpacio
              Sorry,
              I solved it.
              I reinstalled and fredoscale libfredo and now everything is ok.
              Thanks anyway. πŸ‘ πŸ‘
              compliments for the speed of responses. This forum is a really quick. πŸ˜„ πŸ˜„
              sorry for my English (using Google translate) but my only language is Italian. πŸ‘Š πŸ‘Š
                We have an Italian subforum at the bottom (I have added you now). It's not the busiest forum but still, if you get stuck, there are a couple of Italians here...
                  alfabenedict
                  Thank you! This SketchUp Bending rocks! 😎
                    local
                    Hi!
                    I have a little problem with this plugin. If the stretching device provided by the component or group, then the attribute does not change the size.
                    Sorry, this turned out to google.
                      I think I understand what you wrote, local, but it isn't entirely clear.
                      It is true that if you stretch a component or group, you only change the appearance of that entity but it doesn't change the definition not does it change any other instances of the component in the model. This happens with the native Scale tool as well. To change the definition (attributes) you need to open the component or group for editing and modify the geometry inside.
                        Could it be that he's referring to Dynamic Components?
                          local
                          This component consists of several group.
                          • pbacotP Offline
                            I am not sure of the question but the stretching tool alters the component itself,unlike the scale tool.
                            If more than one instance of the component is in drawing, stretching creates a new component definition--so the original component is unchanged.
                            • pjbazelP Offline
                              pjbazel
                              Hello all,
                              This is my first post, but I have spent countless hours reading this forum and it has been the the most amazing SU resource. Im just learning, and I would have a fraction of my current knowledge/ability without this forum, not to mention the developers who make scripts for SU (thank you Fredo!!!) Im amazed how much effort and energy the individuals in this community are willing to give. Truly amazing!
                              I now have my first question, or at least a question I could not answer simply by reading. I tried to search for the answer, I did not find it, but im sure its simple.
                              Using Fredo scale box scaling, when I grab/drag a handle and scale it jumps from 1.0 to 1.05, and I can not get it to scale in this range (1.0-1.05) without typing the values. It would be very nice to stop this, and have it scale in this range without it jumping from 1.0 to 1.05.
                              Is there a way to change this?
                              thanks...
                                Hm. I tried both with the native Scale tool and FredoScale and I can easily move my mouse in a way that it smoothly "grows" the numbers by 0.01 increments.
                                • pjbazelP Offline
                                  pjbazel
                                  When I use the native scale tool it scales by .01 increments. But, when using Fredo Scale it jumps to 1.05, and then scales up from there at .01 increments. Very frustrating. There is a similar issue when using target mode with small (not minute, but small) distances.When using scaling handles I can type in the values between 1 and 1.05, but with target mode there is no way to get the scaling through the small distance.
                                  If anyone has any ideas please tell me what you think. There didn't seem to be anything in the settings to correct this.
                                    Can you share the model file (or at least the problematic part) you are working with?
                                      I see it too on a simple box. When the scale handle first moves it is either to 1.05 or 0.95. That's really no a big deal, though. If you want a precise scale factor, just type the desired value including 1.01 or whatever you really want.
                                      • pjbazelP Offline
                                        pjbazel
                                        I could upload a file, but Im not sure it would help. This is the behavior all the time. There is not particular file or problem area. It behaves like that all the time.
                                        Should I upload a file? Will that help?
                                        Again, its only with the Fredo Scale, not the native scale.
                                        Let me know if you think it will help ill post one, but it appears to be the script, not a particular file/operation.
                                        Thanks for the help guys
                                        • pjbazelP Offline
                                          pjbazel
                                          Exactly, yes that's what mine does. Very frustrating.
                                          yes, I can type it in, but this is not as useful as there is no real-time feedback/deformation. If its possible to change it I would love to know how.
                                          Also, possibly more urgent is that fact that in target mode this 'jump' prevents the operation from occurring at all. Neither draging the handle, or typing in parameters produces a result when scaling in this small range.
                                          Perhaps its a script issue?
                                          • fredo6F Offline
                                            @pjbazel
                                            There is a parameter for fixing the minimum amount of scaling when dragging. Unfortunately, I did not make available for setting in the Default Parameters...dialog box.
                                            I think I will in a next release.
                                            In the meantime, you can modify the line 180 of file bootstrap_FredoScale.rb, which is:
                                            LIMIT_InferenceScale = 0.05
                                            Just change the value, for instance 0.01.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 56
                                            • 57
                                            • 21 / 57
