    [Plugin] Ruby Console+ (3.0.2) – updated 30.10.2017
    61 Posts 18 Posters 40.9k Views 17 Watching
      Anton_S
      @jim said:
      Aerilius,
      Nice console, thanks.
      Anton,
      Why have you by-passed the installer and put the plugin in the Tools folder? The Tools folder is for SketchUp to use and it is recommended not to put anything there.
      Start by removing the ae_Console files and folder from SketchUp's Tools folder, and install the plugin correctly using the Windows > Preferences > Extensions > Install Extension button.
      LOL, did you monitor my comp?? 😲
      Exactly, I have it in tools folder. The reason is do to having 3 plugins folders: plugins draw - fredo tools+tt_lib+more, plugins game - sketchy physics, plugins testing - my plugins. I rename one of folders to plugins whenever I feel to use one of them. I jst wanted to eliminate the loading of all "plugins", and use the plugins that I want instead of loading all plugins. For me, the tools folder is like the "main plugins". Ruby console, window settings... is a good place for them - cause I use them in all plugins.
      Well, anyways thanks for pointing that out: moving it to plugins
        Aerilius
        I didn't get that error. I then tested on another computer where I had tested the beta version and got the error.
        You probably have the beta version installed and the registry (Sketchup 8\Plugins_ae\Console) contains an old/invalid value.
        The script errors in IE are very pertinacious. I'll try to validate the configuration before passing it into the webdialog.
          Anton_S
          Hmm... it still gives me that error!
          @aerilius said:
          I didn't get that error. I then tested on another computer where I had tested the beta version and got the error.You probably have the beta version installed and the registry (Sketchup 8\Plugins_ae\Console) contains an old/invalid value. The script errors in IE are very pertinacious. I'll try to validate the configuration before passing it into the webdialog.
          Errased, the beta, and all version, including this one, ran CCleaner, I guess I got it all removed using regedit, and it still gives me that error. How should error exist, when I cleaned-up after beta?
            Aerilius
            CCleaner doesn't do magic. I does a lot but I would be surprised if it (only) deleted HKEY_CURRENT_USER\Software\Google\SketchUp 8\Plugins_ae\Console.
            The problem is that the only way to bring data from Ruby to SketchUp (execute_script) doesn't handle invalid data, it can't catch and suppress parsing errors.
            I have a new version where I validate the data on the Ruby side before I pass it to the WebDialog. I'll upload it soon
              Anton_S
              @aerilius said:
              ...upload it soon
              That'll be great ❗
                Aerilius
                I uploaded a preliminary with the fix (1.0.2) to prevent this script error. I wanted to use my new webdialog communication system, but that isn't finished yet. It will come later.
                  Anton_S
                  @aerilius said:
                  I uploaded...
                  Good, good!! Thks 😄
                  • alexschreyerA Offline
                    alexschreyer Extension Creator
                    Ruby console on steroids! Very nice.
                    Cheers,
                    Alex
                    Author of "Architectural Design with SketchUp":
                    http://sketchupfordesign.com/
                      Aerilius
                      New features added:
                      inspector for SketchUp entities and many little improvements.
                        Anton_S
                        Thankyou, thnakyou, thankyou!!!
                        I use it all the time 👍
                        • Dan RathbunD Offline
                          Dan Rathbun
                          I have sizing issues on XP w/ IE8 installed. (SU v8.0M4)
                          I'm not here much anymore.
                            Aerilius
                            That is not (only) a sizing issue, the JavaScript does not run. Maybe something in the WebDialog-Ruby communication goes wrong and does not call the %(#000000)[initialize()] function?
                              Reind Brackman
                              Just installed Ruby Console+ and my productivity doubled already.
                              Also very good to avoid RSI, better known as 'lets load the damn script again command...'
                              Thanks - great work.
                                cesaro36
                                Could anyone solve this issue?
                                Same Problem
                                  Aerilius
                                  What same problem? What browser? What version of the plugin?
                                  Can you try the latest version?
                                  • rami_lpmR Offline
                                    rami_lpm
                                    All I'm getting is this.
                                    Win Vista Business 64
                                    Java 7 update 7
                                    IE 7 <--- is this a problem?
                                      Aerilius
                                      That might be the problem.
                                      Requirements:
                                      for now, it works only in the Windows version of SketchUp (IE8, IE9)
                                      (Does Internet Explorer 7 run on Vista??)
                                      • rami_lpmR Offline
                                        rami_lpm
                                        Was that 'requirements' line there all the time?
                                        Yes, IE7 was installed with my spanish version.
                                        I upgraded and it works fine.
                                          Anton_S
                                          I had the same problem as in the posts before. To resolve the problem you must delete the registry of original Ruby Console +: (Windows 7)
                                          [list:2x1uqeh5][:2x1uqeh5]Go to start menu and search, and open regedit.exe.[/Ⓜ2x1uqeh5]
                                          [:2x1uqeh5]Locate registry path: Computer\HKEY_CURRENT_USER\Software\Google\SketchUp[n][/Ⓜ2x1uqeh5]
                                          [:2x1uqeh5]Delete the following folders and registry:
                                          .\Extensions\Ruby Console+[ver
                                          • .\Plugins_ae\Console
                                          • .\WebDialog_AE_Console[/list⭕2x1uqeh5]]
                                          After delete, it must work!
                                          On other windows versions, the registry might be in similiar named locations.
                                            Anton_S
                                            Other than the registry the ruby console is outstanding! 😍
                                            Highligh entities, beatiful script highlightings, fast processing, and much more. 👍
                                            I only had to go to Plugins\ae_Console\jQuery\jquery-console-extensions.js and comment out all the DEBUG "puts" sections -- It disturbed me posting "resizing", and "finish resizing".
                                            Now the wish! Is there a way to add a "clear history" button, so it clears all the console history input queue? To clear, i can go to registry and clear it out manually, although it would be nice to have a button.
                                            • 1 / 4
