    Component browser default view
    12 Posts 5 Posters 599 Views 5 Watching
    • pbacotP Offline
      Whenever I open a SU file the component window (when it is opened) shows a component library I made long ago. Is there a way to make it show what I wish by default?--Such as the model components, or an empty or sparse library?
      • beginnerB Offline
        beginner
        On the same note...
        Is it possible to set SU to open last 'visited/saved to' folder.
        Each time goes to my 'Documents' folder ❓
        Regards, SU 'beginner'
        • Paul RussamP Offline
          Paul Russam
          I'd love to know if this is possible, additionally the how about getting the materials palette to open at a specific library ( or home)
          Paul Russam
          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
          • mitcorbM Offline
            mitcorb
            Can you not set a default filepath in Window> Preferences> Files?
            • TIGT Online
              My Material Browser always opens using the last visited subfolder in a Materials collection... It's remembered in the PC's Registry...
              It's the same with the last visited subfolders in the Components and Styles Browsers...
              Other 'default' File locations are as the user sets them in the Preferences > Files options...
              If one of those set folders doesn't exist then it will default to the user's 'Documents' folder.
              • beginnerB Offline
                beginner
                We are using the path for styles, materials etc. but it doesn't help us with the models.
                Our modelsare saved based on job numbers and stored on the network = we don't have one central location for models 😞
                • TIGT Online
                  Can't be done as it uses the 'Models' path value entered in the Preferences dialog.
                  Changing that is fixed till the user changes again.
                  It set on exit from Sketchup: so you can't write any code to reset it in the Registry whilst in Sketchup, because although it might change in the Registry entry whilst Sketchup is open, Sketchup uses the path loaded at start up or last set in the Preferences dialog, and on a close the Registry is updated with that version overwriting what you might have just reset in code.
                  You could set it to one folder up on the network - e.g. "P:/Projects/" so you only need to select the project-folder from the list presented - assuming that the projects are in subfolders in that main location...
                  You could write a cunning Ruby tool that writes the current SKP path into a 'Temp' file as Sketchup closes a SKP [onQuitObserver?], then when Sketchup is NOT active a parallel system-based tool reads the path's value in the 'Temp' file, it then deletes that file.
                  It checks for the files existence frequently - when that file reappears we know Sketchup has closed and we rewrite the Registry again etc... Unfortunately multiple instances of Sketchup will result in a false change because the last SKP to close wins...
                  Perhaps it could use 'HotKeys' ?
                  BUT this seems incredibly convoluted and prone to error...
                  • pbacotP Offline
                    Doesn't default to last-sued for me. Component folder view, is as I noted, an old folder that I haven't used in a long time...
                    "Preferences > Files options..."? never seen it.
                    But I have to look up the directory you show. Be back soon.
                    • beginnerB Offline
                      beginner
                      The folders structure is more complex but it's easy to use on **'project by project'**basis:
                      1. Network Drive:
                      1.1 Projects
                      1.1.1 2008
                      1.1.2 2009
                      1.1.3 2010
                      1.1.4 2011
                      1.1.5 2012
                      1.1.5.1 Presentations
                      1.1.5.1.1 Models
                      1.1.5.1.1.1 SketchUp
                      1.2 Enquiries
                      1.2.1 2008
                      1.2.2 2009
                      1.2.3 2010
                      1.2.4 2011
                      1.2.5 2012
                      1.2.5.1 Presentations
                      1.2.5.1.1 Models
                      1.2.5.1.1.1 SketchUp
                      and so on...
                      • TIGT Online
                        Well you are knacked then unless you get a HotKeys exe and the onQuit Ruby working together...
                        • beginnerB Offline
                          beginner
                          TIG,
                          Never mind.
                          I always saved them 'manually' where I have to save - it would be few years by now and it works. 😄
                          Thank you.
                          • TIGT Online
                            I slept on it and have a few observer/vbs ideas... I'll continue this by PM... if I have time to come up with anything.
