    [Plugin] SectionCutFace
    569 Posts 171 Posters 541.2k Views 170 Watching
    • K
      kai350191439
      Thank you so so much !!!!
        juanchiarq
        Hey guys, I'm trying to use this plugin but I'm not getting any result, when I move/copy the object after making adding Section-CutFace I get the same one complete without the Section I've made, can anyone help me with this??, thanks.
          I think you're expecting something this plugin doesn't do nor is it intend to do. This plugin doesn't modify the existing entity it just creates a new one which is the face on the section plane. If you expect to end up with the entity actually cut, you need Zorro instead.
            juanchiarq
            Thank you Dave, that worked almost perfectly for me, the only bad thing is that I have to fill every wall to get a black filled effect when I uses de Section Cut, and also when I do a manual cut the SketchUp crash, I don't know why... πŸ˜•
              Not without seeing your model.
              • Y
                yi_design
                awsome!
                • W
                  whitelock
                  Hi, I love this tool however I occasionally get a problem when trying to add section cut face. It will sometimes only fill in the faces of a few of the objects, and then some faces are left open. Is this a glitch? has anyone else experienced this and does anyone know a workaround.
                  Luke
                    If you are having intersecting objects it can't always double-guess which should be solid and which should be void.
                    This was discussed not so long ago. http://forums.sketchucation.com/viewtopic.php?p=406295#p406295
                    It'd be impossible to have an algorithm that'd be right 100% because what you see as solid might be more logically void and vice versa...
                    If you leave the option ON to keep all edges a manual fix is relatively straight forward.
                    Sometimes tiny or gigantic objects cause intersection issues too, but that's rare...
                    • W
                      whitelock
                      I have a question, sometimes when using this plugin I take the section view into Layout and when I try and Dimension the section the Dimension tool will not snap to any points around where there is a cut face. Am I doing something wrong?
                        There are no edges on a native Section-cut, so you can't snap to anything.
                        The SectionCutFace tool adds edges/faces to the selected Section-cut, but by default unfaced edges will be removed - so set 'Keep Un-Faced Edges'==Yes to keep them.
                        Also all edges are 'hidden' by default, so they are not there to snap to either - so set 'Hide Edges'==No so you can see them.
                        Then you should have some edges to snap on to in the Section-cut...
                          MartinK
                          Thanks TIG, This just saved a colleague a ton of time.
                            Jorocco
                            Thanks TIG for this excellent plugin.
                            I have a section in my drawing that creates two separate closed shapes. You could imagine a plane sectioning a donut. SectionCutFace creates the section face for only one of these shapes. The other one is left alone. I was wondering if there were any options or workarounds to get the other shape filled in with a face.
                            Thanks,
                            John
                              Thanks,
                              John
                              I must imagine the form.. if you have two overlapping shapes the tool has to decide which parts are solid and which are void.
                              There's a discussion and example images in an earlier post in this thread.
                              Sometimes it guessing wrong when there are several possibilities.
                              If your forms don't overlap, or are properly intersected solids without ambiguous 'internal partitions' then you won't get this.
                              However, it is relative simple to fix in a post process...
                              Set the options to include unfaced edges, show edges etc.
                              After the section-face is made temporarily set your view to Monochrome mode; then edit its container [group] and remove any unwanted faces by selecting them + delete OR to add missing faces over-draw an edge to auto-form a face etc where it's wanted. Because all of the edges are coplanar they should all potentially auto-face with an edge-over-draw... but sometimes SketchUp can't cope with complex outlines and you'll have to add temporary 'diagonal lines' across the required face outline to form several facets; when you have all of the face pieces made you can erase the unwanted coplanar temporary edges to merge them back into a single face.
                                Jorocco
                                Thanks,
                                John
                                Well, my donut example was maybe not the best because I created such a shape as a test, and the sections were added perfectly. I have attached my actual drawing. There are three closed shapes in this section, and the plugin has correctly filled two in red. However the shape that's like an upside down 'U' has not been filled in. I will experiment with the instructions you've given in your reply (I'm having a little trouble following it but maybe with some practice...) but wanted to clarify the problem.
                                Thanks,
                                John
                                a section with three closed portions
                                  John
                                  I'm unsure why this might be failing - indeed it looks like it ought to work πŸ˜•
                                  It's not perfect, but if you use the settings I suggested then you should get something that is quickly editable/fixable...
                                  • N
                                    nramadhiny
                                    installed the plugin in the right location and the ruby console have successfully loaded it, but when I clicked 'Add section cut face' on the right-click menu, it wouldn't show the dialog option. Even resulted that the command "add section-cut face-parameter" vanished when I moved my cursor somewhere. Help me!
                                      Which Mac version? Do you have both read and write permissions set for the Plugins folder for your username?
                                        Put the .rb file in the root HD.../plugins folder, NOT the 'users' equivalent.
                                        The 'plugins' folder needs to have full read+write permissions.
                                        I don't understand what you say about the Ruby Console πŸ˜•
                                        Once the script is in the correct plugins folder and you restart Sketchup you need do no more...
                                        It auto-loads.
                                        When you have just one Section-Plane selected, then a context-menu entry [which will run the tool] is added to the context-memu's list of commands.
                                        Do NOT try to [re]load or run it from the Ruby Console - this will break things !
                                        On picking the tool from the context-menu... a dialog appears and you choose options, on OK it processes and adds a SectionCutFace group [obviously you need to be cutting through something to get a face forming etc]... πŸ˜’
                                        • C
                                          caronte01
                                          Thanks TIG. I use this plugin a lot with Layout.
                                            duchuy2001
                                            first of all thank you TIG on this ruby, but I have one small problem like the one below!please fix it, I used SU8
                                            http://i589.photobucket.com/albums/ss336/duchuy1303/sectioncutface04_zps445e13ed.gif
                                            • 11
                                            • 28
                                            • 29
                                            • 9 / 29
