    [Plugin] Lamella Roofs
    63 Posts 25 Posters 53.9k Views 25 Watching
    • V Offline
      victor hugo
      I dropped the lamella_roof.rb to the plugins folder and nothing happens, restarted SU and is not on the list?
      Any one has the same issue.
      I also like the big hangars made of concrete by the designer an italian eng-arch Pier Luigi Nervi.
      Thanks.
        What did you expect to happen? Did "Lamella roof" show up in the Plugins menu?
        Go back to the Plugins folder and make sure lamella_roof.rb is there with the correct extension and that you didn't put it in some other Plugins folder.
        • V Offline
          victor hugo
          pasted in the C:\Program Files\Google\Google SketchUp 8\Plugins.
            Let's see if I can drag some useful information out of you so we can help you. πŸ˜’
            And after you close and reopen SketchUp does the plugin show in the Plugins menu? Do you really have XP as your profile indicates?
            • V Offline
              victor hugo
              Not shown after reopen.
              yes XP
                Post a screen shot of your Plugins folder showing the file installed. Make sure extensions are being shown.
                And you did actually close SketchUp and reopen it? You didn't just minimize it?
                • V Offline
                  victor hugo
                  Dave.
                  I had some extensions unloaded........ load them and restarted SU and is working now...
                  Thanks.
                    There's no way in the world we could have helped you without knowing that. πŸ˜’
                    I'm glad it's working now.
                      timwarner
                      Hi Dave R,
                      My understanding from this exchange is that the problem was related to Victor Hugo's plugin folder, but is there anything I should do to make this plugin more robust?
                        Hi Tim,
                        No, your plugin is just fine. There's nothing you could do in your script to prevent a user from unticking boxes in the Extensions list under Preferences. V.H.'s problem wasn't specific to your script. It just happened yours is the one he was trying to use when he discovered he had a problem.
                          prousteilcalamaro
                          Hi Tim,
                          Your plugin seems very nice, however I've a problem in executing it.
                          After the two windows for the parameters (I leave them as default), the plugin stops working, no drawing is produced and the Ruby Console shows an error as follows:
                          Error: #<NoMethodError: undefined method make_unique' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/lamella_roof.rb:289:in lamella_roof'
                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/lamella_roof.rb:1038
                          I'm using SU 8 and the new version of your plugin.
                          Is something wrong with my SU preferences? I've a lot of plugins loaded.
                          Let me know how to solve the problem (I'm not a programmer).
                            There's nothing wrong with Tim's plugin. It works just fine on SU 8. Considering that there's not much to installing it, I suspect you have another plugin that is causing the problem. There are some plugins that are known to cause other plugins to fail. SketchyPhysics is one.Matchbox_r1.1 is another. There are more. Perhaps you could post a screenshot of your Plugins directory and we'll be able to tell you which one it is.
                              Sounds like SketchyPhysics to me - that is known to mess with the base class/methods - like 'group.copy' which should return a reference to the 'new-group' but after the ill-advised reworking it returns 'nil'... so then when some legit code tries to do something to the copy
                              [like '.make_unique'] it fails because now it's 'nil' and not 'new_group'.
                              It could be relatively easy to fix this but the authors of this and some other 'rogue' scripts have either lost interest, or simply don't care about others and their legit tools, which expect the API to work as it ought...
                                prousteilcalamaro
                                Thank you very much!
                                I had SketchyPhysics in my Plugins folder. I removed that plugin (I don't need it for my actual project) and Lamella Roof works fine: it's a great plugin.
                                  timwarner
                                  Nice surprise to go away into the Ontario wilderness for a week's canoeing, and come back to find a problem has been raised and resolved without my doing anything. Thx, all!
                                  • flyer50F Offline
                                    flyer50
                                    @tig said:
                                    If you implement these general changes this has the basis of a useful toolset...
                                    Sorry if I disturbe you . I try to make all your suggestions but I can't solve the problems. my file seems to be different and I can't update it.
                                    My poor knowledge is also a big problem.
                                    My program also don't give any results, may be it is an incomplete version.
                                    Can you please upload the correct file that you are using already updated?
                                    Tanks a lot
                                    Flyer
                                    • Chris FullmerC Offline
                                      The file is attached to the post here:
                                      404 Not Found
                                      (sketchucation.com)
                                      The very first post in this thread. Download it and install it. Look on youtube or somewhere for plugin installation help. Good luck!
                                      • flyer50F Offline
                                        flyer50
                                        404 Not Found
                                        (sketchucation.com)
                                        Thank for your replay
                                        I use win7 and SU8
                                        I have already installed many time the program and also the one from the link you suggest but I have always the same problem:
                                        I can't see any drawing on the screen
                                        I did these tests :
                                        on the screen I draw one only component (cube) and when I select lamella.rb from the plugins list.
                                        the component (cube) disappear from the screen,
                                        the data input masks are anabled and I use the default settings,
                                        from the rubi console I can see that the program il working but it does not finish the job.
                                        on the rubi console I have this report:
                                        http://www.filedropper.com/lamellabroken
                                        I removed all plugins ( they are a lot ) except lamella.rb :
                                        the program can complete its job,
                                        at the end I can see on the screen the component (cube) that was previous cancelled,
                                        in the rubi console I have the following report :
                                        http://www.filedropper.com/lamellacomplete
                                        but still I don't see the drawing of the program
                                        After I reinstall all the plugins one by one but when I reinstall sketchyphisics the lamella plugin stops again.
                                        Now sketchyphisics is removed
                                        thanks a lot for your help
                                        • flyer50F Offline
                                          flyer50
                                          I have solved and now it is working
                                          the problem was on the dimentions
                                          Ciao Flyer
                                            Works fine! 😎
                                            You must put an alert message when 0Β° is entered for the Screw Angle as nothing is done! πŸ€“
                                            Funny things arrive when you take Screw Angle = 1Β° πŸ˜„
                                            • 2 / 4
