    [Plugin] Lamella Roofs
    63 Posts 25 Posters 54.8k Views 25 Watching
    • bmikeB
      bmike
      reply to keep this in my list of threads.
      i'll peek back once the ruby gets improved.
      nice looking plugin.
      • W
        watkins
        Dear Tim,
        You and your colleagues are to be congratulated on your achievement. How long did it take start to finish, and did you have building experience before starting the project?
        Kind regards,
        Bob
        • T
          timwarner
          @brookefox said:
          Will the routine allow the creation of in-line lamellas, without the slight offsets?
          Thank you much for sharing, Tim.
          (bmike, you didn't forget the bookmark feature here?)
          Simple answer, no. The plugin assumes the use of dimensional lumber and common bolt connectors, as in the original Zollinger concept, and in recent examples like the Rural Studio dog shelter http://apps.cadc.auburn.edu/rural-studio/Default.aspx?path=Gallery%2fProjects%2f2006%2fhalecoanimalshelter%2f. But it's a natural option, and easier to model. Thx for the (implicit) suggestion.
          PS I'm attaching a brief monograph on the underlying geometry.
          The Geometry of a Lamella Roof
          • T
            timwarner
            @watkins said:
            Dear Tim,
            Kind regards,
            Bob
            Thx Bob,
            This is actually a one-man show. I built a lamella roof (the one shown at the top of the thread) some years back, based on a crude, and actually wrong Excel model, but only worked out the exact geometry last year. Writing a plugin involved learning Ruby (OK, it shows!), and grappling with the SU documentation, which I have to say I find opaque in many ways. The plugin probably took about three months to work out.
            I'm not a builder at all, but I've done some simple construction work, if dry-stack walls count.
            • pep75P
              pep75
              Great plugin Tim!!
              πŸ˜‰
              • T
                timwarner
                I've corrected the plugin to reflect the very helpful community comments, and fix some minor errors in the way curved surfaces were being generated. Both the revised plugin and documentation are embedded in the original post to make them easier to find.
                I'm still puzzling over a couple of issues. First is the odd failure of the intersect_with method in at least one circumstance. (Posted elsewhere http://forums.sketchucation.com/viewtopic.php?f=180&t=46714). This wipes out a couple of faces in a lamella, but is rare, and easy to fix manually. Second, the geometry is off by a small (< 1mm) amount in terms of the components not lining up exactly. It doesn't feel like a rounding error, so my calculations may be incorrect. Practically this is not significant.
                Thx all, and TIG and Thomthom especially, for your advice.
                • KrisidiousK
                  Krisidious
                  Really appreicate the plugin... and even more so Tig and Thom for always checking all these plugins out for us and warning us before installing them.
                  By: Kristoff Rand
                  • T
                    timwarner
                    I've updated the plugin to allow the creation of a diagrid lamella roof, where the lamellas are co-planar, following brookefox's suggestion, and to add some error-checking and spinners on input. Updates are located with the original post.
                    Under some circumstances the upper surface of the lamella is not created properly, for reasons I still don't understand. The cutting instructions are correct, regardless.
                      Mra
                      Thanks Tim, hope I get to do a project with this kind of roof one day!
                      • V
                        victor hugo
                        I dropped the lamella_roof.rb to the plugins folder and nothing happens, restarted SU and is not on the list?
                        Any one has the same issue.
                        I also like the big hangars made of concrete by the designer an italian eng-arch Pier Luigi Nervi.
                        Thanks.
                          What did you expect to happen? Did "Lamella roof" show up in the Plugins menu?
                          Go back to the Plugins folder and make sure lamella_roof.rb is there with the correct extension and that you didn't put it in some other Plugins folder.
                          • V
                            victor hugo
                            pasted in the C:\Program Files\Google\Google SketchUp 8\Plugins.
                              Let's see if I can drag some useful information out of you so we can help you. πŸ˜’
                              And after you close and reopen SketchUp does the plugin show in the Plugins menu? Do you really have XP as your profile indicates?
                              • V
                                victor hugo
                                Not shown after reopen.
                                yes XP
                                  Post a screen shot of your Plugins folder showing the file installed. Make sure extensions are being shown.
                                  And you did actually close SketchUp and reopen it? You didn't just minimize it?
                                  • V
                                    victor hugo
                                    Dave.
                                    I had some extensions unloaded........ load them and restarted SU and is working now...
                                    Thanks.
                                      There's no way in the world we could have helped you without knowing that. πŸ˜’
                                      I'm glad it's working now.
                                      • T
                                        timwarner
                                        Hi Dave R,
                                        My understanding from this exchange is that the problem was related to Victor Hugo's plugin folder, but is there anything I should do to make this plugin more robust?
                                          Hi Tim,
                                          No, your plugin is just fine. There's nothing you could do in your script to prevent a user from unticking boxes in the Extensions list under Preferences. V.H.'s problem wasn't specific to your script. It just happened yours is the one he was trying to use when he discovered he had a problem.
                                          • P
                                            prousteilcalamaro
                                            Hi Tim,
                                            Your plugin seems very nice, however I've a problem in executing it.
                                            After the two windows for the parameters (I leave them as default), the plugin stops working, no drawing is produced and the Ruby Console shows an error as follows:
                                            Error: #<NoMethodError: undefined method make_unique' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/lamella_roof.rb:289:in lamella_roof'
                                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/lamella_roof.rb:1038
                                            I'm using SU 8 and the new version of your plugin.
                                            Is something wrong with my SU preferences? I've a lot of plugins loaded.
                                            Let me know how to solve the problem (I'm not a programmer).
                                            • 2 / 4
