    SNAP OFF
    9 Posts 4 Posters 666 Views 4 Watching
    • fouronethirtyF Offline
      fouronethirty
      HI GUYS, can there be a way where we can stop of tik off the snaping in skethup??? i think its more easy to handle when modeling organic geometry than in snap on, ide try to tik it off on mm units but it just dont work, anyone pls,
        I guess you want to turn off the inference snaps? That's not an option.
        • Jean LemireJ Offline
          Jean Lemire
          Hi folks.
          Try turning off the Enable Length Snappingin Menu Window --> Model Info --> Units.
          This will disable snapping to an invisible grid.
          I personally very seldom use this feature since SU's inference engine and its move copy function are adequate for nearly all modeling operations that I need.
          Just ideas.
            fouronethirty
            Thanks a lot, i was thinking of a snap totally off, ide tried the enable lenght snapping off, it works, but the snap stills . yes its maybe the inferencing, i just wanna experience the no snap at all;) i thing it has more control when modeling in vetice mode, but anyway, thanks a lot guys.
              Without inferencing on you wouldn't be able to control where in the 3D space things are. Learn to use it correctly and you'll find that it works very well.
                more control when modeling in vertice mode
                you are correct that inferencing hinders point by point modeling. But you'll soon have this...
                [flash=600,450:3knfjqdh]http://www.youtube.com/v/xfM02PleFMg[/flash:3knfjqdh]
                ...which allows off axis vertex postioning with ease
                  fouronethirty
                  Ok. i'll try doing that, thanks sir,
                    fouronethirty
                    [flash=600,450:7evykuhm]http://www.youtube.com/v/xfM02PleFMg[/flash:7evykuhm]
                    wow. that's nice tools sir, i have one of those vertex tools, but its a little different than yours , it doesnt have that gizmo like yours , what version is that sir?? where can i get sme of that??
                      read the next edition of catchup πŸ˜‰
