    Spin Camera [Resolved: Use TIG's Rotate Plan View]
    9 Posts 3 Posters 1.4k Views 3 Watching
    • pbacotP Offline
      How might I do this.
      Is there away to spin the camera without orbit. I wish to set the ortho plan view (as in Command-1) but I want the orientation of the view (bottom of page) to be at a different angle, while keeping the straight down orthogonal camera. Orbit spoils the camera POV.
      Thank you, Peter
      (Besides the obvious thrill of a spinning camera.)
        Peter, there's a plugin that will set the camera for a plan view but with some other direction other than south being at the bottom. I'll look for it.
          I don't think this is the one I had in mind but try it. Maybe it'll work for you?
          404 Not Found
          (forums.sketchucation.com)
          • pbacotP Offline
            Thanks I'll try it. Peter
              Try my Rotate Plan View http://forums.sketchucation.com/viewtopic.php?p=313264#p313264
                That's the one I was trying to find. Thanks, TIG. It's not in the Plugins Index, at least under your name.
                  It was posted as a response to someone's, request making it harder to find - it is in the index though...
                    Now I see it. I was looking for it down in the R's
                    • pbacotP Offline
                      TIG that works excellently. Maybe it seems a small thing but it should make working in this project much better. Gives a perfectly aligned scene for LO. THANKS!
                      Peter
