    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.3k Views 107 Watching
      SUFractal
      tak2hata:
      I have what I hope is a simple question. How do I change the color of any beam, column, etc. before placing/drawing it? In the webdialog box, the option default is black. No matter which color I type into the box, the color remains a light blue color.
      Thanks,
      SUfractal
        tak2hata
        I am too busy.So I can not improve my plugins.
        Multiple "Grow to face" will be added.
        I will consider applying "Grow" for "MWALL".
        @sufractal said:
        tak2hata:
        The color is material.
        Beams material is created from "FRONT FACE MATERIAL" and "BACK FACE MATERIAL".
        It appears random color when the materialnames in "FRONT FACE MATERIAL" and "BACK FACE MATERIAL" is not existed in sketchup model.
        So you may set sketchup templete with the materials.
        Thanks.
        by TAK2HATA
          SUFractal
          That makes sense!
          Thanks.
          @sufractal said:
          tak2hata:
          Thanks.[/quote]
          • Z Offline
            ZFRPS
            Dear tak2hata:
            We all love you always,Life is the most important,Wish you need not too busy work!
            THANKS AGAIN!
            sketchup is bim
              Conan8717
              good~~i like it!
              • irwanwrI Offline
                irwanwr
                Arigatou gozaimasu. ありがとうございます。
                👍 this is one of my "must have" plugin.
                • V Offline
                  victor hugo
                  Hello.
                  I installed the tools and when i select the slab class i get the attached error.
                  Can anyone tell me how to fix this?
                  Gracias.
                  • mitcorbM Offline
                    mitcorb
                    I do not know for sure, but could there be a conflict between BST1.1e and 1001BitTools?
                      tak2hata
                      Hi,hugo , mitcorb and everybody.
                      It is bug,and I fixed it.
                      It happened according to sending double quotation in webdialog.
                      The length is shown with double quotation.When sketchup "units" is "Architecture" or etc.
                      And I re-add function "extending" multiple walls to face."growing" also.
                      Thanks.
                      by TAK2HATA
                        juliogonz
                        tak2hata
                        This is awesome! thank u!
                        • sumasterS Offline
                          sumaster
                          First thank you for made this plugin . . . . ,
                          how i add previous toolbar . . . . ?
                          its very Helpful. . . .
                          Thank you,
                          SUmaster
                            tak2hata
                            @sumaster said:
                            Hi,sumaster.
                            I changed all dialogs to one webdialog in version1.0+.
                            So I worried many icons in the toolbar become obstructive.
                            And older dialogs is not valid now.
                            I can create toolbar with many icons like older.
                            It will open webdialog with specified class(ex. STEEL_COLUMN,RC_GIRDER,etc).
                            Please wait.
                            Thanks.
                            by TAK2HATA
                              CTMan
                              Hi Tak2hata
                              Thanks for you Building Structures Tools - it's a very useful plug-in
                              I'm putting the UK steel sections into the CSV file which works very well for UBs and UCs
                              Channels ( [ ) have tapered flanges on your PROFILE NAME SCHEMA
                              Is there a way to put PFC profiles into the database
                              Thanks Again for your great Plugins
                              CTMan
                              Parallel Falnge Channels
                              • sumasterS Offline
                                sumaster
                                @tak2hata said:
                                @sumaster said:
                                Hi,sumaster.
                                Please wait.
                                Thanks.
                                yes its interesting . . . . 👍 😄
                                Thank you,
                                SUmaster
                                • sumasterS Offline
                                  sumaster
                                  HI,
                                  I try to add some shortcuts " extend to face, extend to structure, Grow to face, Combine each "
                                  and extend to face & extend to structure not working good . . . .
                                  Thank you,
                                  SUmaster
                                  • sumasterS Offline
                                    sumaster
                                    CHK
                                    Thank you,
                                    SUmaster
                                      tak2hata
                                      Hi,CTman.
                                      You are welcome!
                                      If you upload the PFC profile file here , I will create link to your post in top of thread.
                                      Your PFC profile file will help users of BST!
                                      Hi,Sumaster.
                                      I also checked the bug.
                                      I will fix the problem within several days.
                                      And I will update here.
                                      Thanks.
                                      by TAK2HATA
                                      • sumasterS Offline
                                        sumaster
                                        @tak2hata said:
                                        Hi,Sumaster.
                                        Thanks.
                                        Yes WAiTING . . . .
                                        THANK YOU . . . 😉
                                        Thank you,
                                        SUmaster
                                          DavidATCW
                                          Hi All,
                                          New the SU but finding it very useful.
                                          Thanks to Tak2hta for the BST plugin. I looks realy good.
                                          I'm using SU8 Pro on Window 7 OS.
                                          In the PlugIns menu under building structure tool I don't seem to have the 'Add New Profile'. The tutorial video seems to indicate it should be there??
                                          Appreciate any help.
                                            tak2hata
                                            I update this in Sep 05,2012.
                                            Bugfix about extending to face with selecting single bst entity.
                                            Hi,Sumaster.
                                            Adding toolbar like previous version has not done well yet.
                                            I gave priority to correction of a bug and update.
                                            wait while.
                                            Hi,david.
                                            "Add new profile" was disable since version1.0.
                                            Because the adding to CSV with ruby script has problem.
                                            The text code is defferent between languages.
                                            So the character peculiar in the language included in csv will be modified strange when ruby overwrite the csv file.
                                            Please edit CSV file with application like Excel or open office calc.
                                            Thanks.
                                            by TAK2HATA
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 17 / 17
