    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.2k Views 107 Watching
    • Z Offline
      ZFRPS
      Dear tak2hata:
      However,I still have some ideas to speak out,Because I love too the plugin,I believe that your this plugin will produce very big help to BIM.
      1. **grow to face** only useful for "Z",but for **MWALL** is invalid;
      2. The shape of the face for ladder;**grow** or **extend** is invalid too;
      3. One-time much choose can greatly improve the efficiency of the modeling.
      THANKS AGAIN !
      sketchup is bim
      • H Offline
        Heven7_floor
        Very powerfull tool, this very very usefully for construction with sketchup, Thanks Tak2hata, your creative brough the good things come to other
          SUFractal
          tak2hata:
          I have what I hope is a simple question. How do I change the color of any beam, column, etc. before placing/drawing it? In the webdialog box, the option default is black. No matter which color I type into the box, the color remains a light blue color.
          Thanks,
          SUfractal
            tak2hata
            I am too busy.So I can not improve my plugins.
            Multiple "Grow to face" will be added.
            I will consider applying "Grow" for "MWALL".
            @sufractal said:
            tak2hata:
            The color is material.
            Beams material is created from "FRONT FACE MATERIAL" and "BACK FACE MATERIAL".
            It appears random color when the materialnames in "FRONT FACE MATERIAL" and "BACK FACE MATERIAL" is not existed in sketchup model.
            So you may set sketchup templete with the materials.
            Thanks.
            by TAK2HATA
              SUFractal
              That makes sense!
              Thanks.
              @sufractal said:
              tak2hata:
              Thanks.[/quote]
              • Z Offline
                ZFRPS
                Dear tak2hata:
                We all love you always,Life is the most important,Wish you need not too busy work!
                THANKS AGAIN!
                sketchup is bim
                  Conan8717
                  good~~i like it!
                  • irwanwrI Offline
                    irwanwr
                    Arigatou gozaimasu. ありがとうございます。
                    👍 this is one of my "must have" plugin.
                    • V Offline
                      victor hugo
                      Hello.
                      I installed the tools and when i select the slab class i get the attached error.
                      Can anyone tell me how to fix this?
                      Gracias.
                      • mitcorbM Offline
                        mitcorb
                        I do not know for sure, but could there be a conflict between BST1.1e and 1001BitTools?
                          tak2hata
                          Hi,hugo , mitcorb and everybody.
                          It is bug,and I fixed it.
                          It happened according to sending double quotation in webdialog.
                          The length is shown with double quotation.When sketchup "units" is "Architecture" or etc.
                          And I re-add function "extending" multiple walls to face."growing" also.
                          Thanks.
                          by TAK2HATA
                            juliogonz
                            tak2hata
                            This is awesome! thank u!
                            • sumasterS Offline
                              sumaster
                              First thank you for made this plugin . . . . ,
                              how i add previous toolbar . . . . ?
                              its very Helpful. . . .
                              Thank you,
                              SUmaster
                                tak2hata
                                @sumaster said:
                                Hi,sumaster.
                                I changed all dialogs to one webdialog in version1.0+.
                                So I worried many icons in the toolbar become obstructive.
                                And older dialogs is not valid now.
                                I can create toolbar with many icons like older.
                                It will open webdialog with specified class(ex. STEEL_COLUMN,RC_GIRDER,etc).
                                Please wait.
                                Thanks.
                                by TAK2HATA
                                  CTMan
                                  Hi Tak2hata
                                  Thanks for you Building Structures Tools - it's a very useful plug-in
                                  I'm putting the UK steel sections into the CSV file which works very well for UBs and UCs
                                  Channels ( [ ) have tapered flanges on your PROFILE NAME SCHEMA
                                  Is there a way to put PFC profiles into the database
                                  Thanks Again for your great Plugins
                                  CTMan
                                  Parallel Falnge Channels
                                  • sumasterS Offline
                                    sumaster
                                    @tak2hata said:
                                    @sumaster said:
                                    Hi,sumaster.
                                    Please wait.
                                    Thanks.
                                    yes its interesting . . . . 👍 😄
                                    Thank you,
                                    SUmaster
                                    • sumasterS Offline
                                      sumaster
                                      HI,
                                      I try to add some shortcuts " extend to face, extend to structure, Grow to face, Combine each "
                                      and extend to face & extend to structure not working good . . . .
                                      Thank you,
                                      SUmaster
                                      • sumasterS Offline
                                        sumaster
                                        CHK
                                        Thank you,
                                        SUmaster
                                          tak2hata
                                          Hi,CTman.
                                          You are welcome!
                                          If you upload the PFC profile file here , I will create link to your post in top of thread.
                                          Your PFC profile file will help users of BST!
                                          Hi,Sumaster.
                                          I also checked the bug.
                                          I will fix the problem within several days.
                                          And I will update here.
                                          Thanks.
                                          by TAK2HATA
                                          • sumasterS Offline
                                            sumaster
                                            @tak2hata said:
                                            Hi,Sumaster.
                                            Thanks.
                                            Yes WAiTING . . . .
                                            THANK YOU . . . 😉
                                            Thank you,
                                            SUmaster
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
