    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • T
      tak2hata
      I am too busy.So I can not improve my plugins.
      Multiple "Grow to face" will be added.
      I will consider applying "Grow" for "MWALL".
      @sufractal said:
      tak2hata:
      I have what I hope is a simple question. How do I change the color of any beam, column, etc. before placing/drawing it? In the webdialog box, the option default is black. No matter which color I type into the box, the color remains a light blue color.
      The color is material.
      Beams material is created from "FRONT FACE MATERIAL" and "BACK FACE MATERIAL".
      It appears random color when the materialnames in "FRONT FACE MATERIAL" and "BACK FACE MATERIAL" is not existed in sketchup model.
      So you may set sketchup templete with the materials.
      Thanks.
      by TAK2HATA
        SUFractal
        That makes sense!
        Thanks.
        @sufractal said:
        tak2hata:
        Thanks.[/quote]
        • Z
          ZFRPS
          Dear tak2hata:
          We all love you always,Life is the most important,Wish you need not too busy work!
          THANKS AGAIN!
          sketchup is bim
          • C
            Conan8717
            good~~i like it!
            • irwanwrI
              irwanwr
              Arigatou gozaimasu. ありがとうございます。
              👍 this is one of my "must have" plugin.
              • V
                victor hugo
                Hello.
                I installed the tools and when i select the slab class i get the attached error.
                Can anyone tell me how to fix this?
                Gracias.
                • mitcorbM
                  mitcorb
                  I do not know for sure, but could there be a conflict between BST1.1e and 1001BitTools?
                  • T
                    tak2hata
                    Hi,hugo , mitcorb and everybody.
                    It is bug,and I fixed it.
                    It happened according to sending double quotation in webdialog.
                    The length is shown with double quotation.When sketchup "units" is "Architecture" or etc.
                    And I re-add function "extending" multiple walls to face."growing" also.
                    Thanks.
                    by TAK2HATA
                      juliogonz
                      tak2hata
                      This is awesome! thank u!
                      • sumasterS
                        sumaster
                        First thank you for made this plugin . . . . ,
                        how i add previous toolbar . . . . ?
                        its very Helpful. . . .
                        Thank you,
                        SUmaster
                        • T
                          tak2hata
                          @sumaster said:
                          Hi,sumaster.
                          I changed all dialogs to one webdialog in version1.0+.
                          So I worried many icons in the toolbar become obstructive.
                          And older dialogs is not valid now.
                          I can create toolbar with many icons like older.
                          It will open webdialog with specified class(ex. STEEL_COLUMN,RC_GIRDER,etc).
                          Please wait.
                          Thanks.
                          by TAK2HATA
                          • C
                            CTMan
                            Hi Tak2hata
                            Thanks for you Building Structures Tools - it's a very useful plug-in
                            I'm putting the UK steel sections into the CSV file which works very well for UBs and UCs
                            Channels ( [ ) have tapered flanges on your PROFILE NAME SCHEMA
                            Is there a way to put PFC profiles into the database
                            Thanks Again for your great Plugins
                            CTMan
                            Parallel Falnge Channels
                            • sumasterS
                              sumaster
                              @tak2hata said:
                              @sumaster said:
                              Hi,sumaster.
                              Please wait.
                              Thanks.
                              yes its interesting . . . . 👍 😄
                              Thank you,
                              SUmaster
                              • sumasterS
                                sumaster
                                HI,
                                I try to add some shortcuts " extend to face, extend to structure, Grow to face, Combine each "
                                and extend to face & extend to structure not working good . . . .
                                Thank you,
                                SUmaster
                                • sumasterS
                                  sumaster
                                  CHK
                                  Thank you,
                                  SUmaster
                                  • T
                                    tak2hata
                                    Hi,CTman.
                                    You are welcome!
                                    If you upload the PFC profile file here , I will create link to your post in top of thread.
                                    Your PFC profile file will help users of BST!
                                    Hi,Sumaster.
                                    I also checked the bug.
                                    I will fix the problem within several days.
                                    And I will update here.
                                    Thanks.
                                    by TAK2HATA
                                    • sumasterS
                                      sumaster
                                      @tak2hata said:
                                      Hi,Sumaster.
                                      Thanks.
                                      Yes WAiTING . . . .
                                      THANK YOU . . . 😉
                                      Thank you,
                                      SUmaster
                                        DavidATCW
                                        Hi All,
                                        New the SU but finding it very useful.
                                        Thanks to Tak2hta for the BST plugin. I looks realy good.
                                        I'm using SU8 Pro on Window 7 OS.
                                        In the PlugIns menu under building structure tool I don't seem to have the 'Add New Profile'. The tutorial video seems to indicate it should be there??
                                        Appreciate any help.
                                        • T
                                          tak2hata
                                          I update this in Sep 05,2012.
                                          Bugfix about extending to face with selecting single bst entity.
                                          Hi,Sumaster.
                                          Adding toolbar like previous version has not done well yet.
                                          I gave priority to correction of a bug and update.
                                          wait while.
                                          Hi,david.
                                          "Add new profile" was disable since version1.0.
                                          Because the adding to CSV with ruby script has problem.
                                          The text code is defferent between languages.
                                          So the character peculiar in the language included in csv will be modified strange when ruby overwrite the csv file.
                                          Please edit CSV file with application like Excel or open office calc.
                                          Thanks.
                                          by TAK2HATA
                                            DavidATCW
                                            Hi TAK2HTA,
                                            Thanks for the reply.
                                            I presume modifying CSV file allows new sizes for existing profile to be added. This is not what I want to do.
                                            Like CTMan I would like to add new profile shape for beams, similar to CTMan's PFC profiles. Instrucion on how to this would be apprecated. We need to be able to customise to get the most out of this realy useful plugin.
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
