    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
      juliogonz
      tak2hata
      This is awesome! thank u!
      • sumasterS
        sumaster
        First thank you for made this plugin . . . . ,
        how i add previous toolbar . . . . ?
        its very Helpful. . . .
        Thank you,
        SUmaster
        • T
          tak2hata
          @sumaster said:
          Hi,sumaster.
          I changed all dialogs to one webdialog in version1.0+.
          So I worried many icons in the toolbar become obstructive.
          And older dialogs is not valid now.
          I can create toolbar with many icons like older.
          It will open webdialog with specified class(ex. STEEL_COLUMN,RC_GIRDER,etc).
          Please wait.
          Thanks.
          by TAK2HATA
          • C
            CTMan
            Hi Tak2hata
            Thanks for you Building Structures Tools - it's a very useful plug-in
            I'm putting the UK steel sections into the CSV file which works very well for UBs and UCs
            Channels ( [ ) have tapered flanges on your PROFILE NAME SCHEMA
            Is there a way to put PFC profiles into the database
            Thanks Again for your great Plugins
            CTMan
            Parallel Falnge Channels
            • sumasterS
              sumaster
              @tak2hata said:
              @sumaster said:
              Hi,sumaster.
              Please wait.
              Thanks.
              yes its interesting . . . . πŸ‘ πŸ˜„
              Thank you,
              SUmaster
              • sumasterS
                sumaster
                HI,
                I try to add some shortcuts " extend to face, extend to structure, Grow to face, Combine each "
                and extend to face & extend to structure not working good . . . .
                Thank you,
                SUmaster
                • sumasterS
                  sumaster
                  CHK
                  Thank you,
                  SUmaster
                  • T
                    tak2hata
                    Hi,CTman.
                    You are welcome!
                    If you upload the PFC profile file here , I will create link to your post in top of thread.
                    Your PFC profile file will help users of BST!
                    Hi,Sumaster.
                    I also checked the bug.
                    I will fix the problem within several days.
                    And I will update here.
                    Thanks.
                    by TAK2HATA
                    • sumasterS
                      sumaster
                      @tak2hata said:
                      Hi,Sumaster.
                      Thanks.
                      Yes WAiTING . . . .
                      THANK YOU . . . πŸ˜‰
                      Thank you,
                      SUmaster
                        DavidATCW
                        Hi All,
                        New the SU but finding it very useful.
                        Thanks to Tak2hta for the BST plugin. I looks realy good.
                        I'm using SU8 Pro on Window 7 OS.
                        In the PlugIns menu under building structure tool I don't seem to have the 'Add New Profile'. The tutorial video seems to indicate it should be there??
                        Appreciate any help.
                        • T
                          tak2hata
                          I update this in Sep 05,2012.
                          Bugfix about extending to face with selecting single bst entity.
                          Hi,Sumaster.
                          Adding toolbar like previous version has not done well yet.
                          I gave priority to correction of a bug and update.
                          wait while.
                          Hi,david.
                          "Add new profile" was disable since version1.0.
                          Because the adding to CSV with ruby script has problem.
                          The text code is defferent between languages.
                          So the character peculiar in the language included in csv will be modified strange when ruby overwrite the csv file.
                          Please edit CSV file with application like Excel or open office calc.
                          Thanks.
                          by TAK2HATA
                            DavidATCW
                            Hi TAK2HTA,
                            Thanks for the reply.
                            I presume modifying CSV file allows new sizes for existing profile to be added. This is not what I want to do.
                            Like CTMan I would like to add new profile shape for beams, similar to CTMan's PFC profiles. Instrucion on how to this would be apprecated. We need to be able to customise to get the most out of this realy useful plugin.
                            • beginnerB
                              beginner
                              Hi Guys,
                              I would like to draw your attention to the 'shapes' in tak2hata's plugin - look at the Class SHAPE and the profiles defined as *.SKP files.
                              You can draw any complex shape as long is contained within single face - sample below.
                              Regards, SU 'beginner'
                              • sumasterS
                                sumaster
                                @tak2hata said:
                                Hi,Sumaster.
                                wait while.
                                Hi Tak2hata,
                                wow nice update . . . . πŸ‘
                                Extend to Face tool is working perfectly . . . . but
                                Extend to Structure is not working properly . . .
                                CHK
                                I add some items in plugin menu . . . πŸ˜‰
                                please add all previous item in plugin menu
                                tst_main_menu = UI.menu("Plugins").add_submenu("#{langconv( 'BS Tool - 1.0' )}")
                                tst_main_menu.add_item("#{langconv('>> Extend to Face')}") { Sketchup.active_model.select_tool TST1_class_extend_face.new( false ) }
                                tst_main_menu.add_item("#{langconv('>> Extend to Structure')}") { Sketchup.active_model.select_tool TST1_class_extend_str.new }
                                tst_main_menu.add_item("#{langconv('>> Growup to Face')}") { Sketchup.active_model.select_tool TST1_class_grow_face.new( false ) }
                                tst_main_menu.add_item("#{langconv('>> Combine Each')}") { Sketchup.active_model.select_tool TST1_class_chamfer.new }
                                tst_main_menu.add_separator
                                And thank you so much for this plugin . . . . πŸ˜„
                                i use your plugin daily . . . .
                                its save my basic modeling time . . . too good . . . .
                                Thank you,
                                SUmaster
                                • V
                                  victor hugo
                                  Does anyone know where to find more RC_WALL options for the BST, when I installed it (which is very useful BTW) it only shows 4 options?
                                  Thanks.
                                  • C
                                    CTMan
                                    @tak2hata said:
                                    Hi,CTman.
                                    You are welcome!
                                    Hello Tak2hata - please find attached csv file for British Steel Beams and Columns
                                    Hi,Sumaster.
                                    Thanks.
                                    • T
                                      tak2hata
                                      Hi,CTMan.
                                      I add link to your reply in the top of thread.
                                      Thanks a lot for uploading your profile list of UK STEEL.
                                      Channel([) have tapered flanges when the schema is like "[-100x50x5x7.5x8x4"
                                      Channel([) have not tapered flanges when the schema is like "[-100x50x5x7.5"
                                      So If you want to not tapered flange Channel,the schema is like "[-AxBxCxD".
                                      Hi,sumaster.
                                      "Extend to structure" tool works extending the structure to the other structure.not to face.
                                      extending to structure.
                                      Using "Extending to Face" to extend like this picture takes time and effort.
                                      So "Extend to Structure" exists for that purpose.
                                      I see the "undo" problem.
                                      I will fix it few days.
                                      Thanks.
                                      by TAK2HATA
                                      • sumasterS
                                        sumaster
                                        @tak2hata said:
                                        Hi,CTMan.
                                        Hi,sumaster.
                                        [attachment=0:165mbbk2]<!-- ia0 -->extending_to_structure.JPG<!-- ia0 -->[/attachment:165mbbk2]
                                        Thanks.
                                        yes
                                        and another problem facing here . . .
                                        i upgrade your new version but when i OPEN my OLD version file means (i was working your old BS tool) and exend to face and other 3 tools are not working good . . .
                                        Pleas CHK
                                        Thank you,
                                        SUmaster
                                        • T
                                          tak2hata
                                          @sumaster said:
                                          yes
                                          Pleas CHK
                                          Hi,Please upload your data include problems.
                                          The part to limit the problem entities.
                                          by TAK2HATA
                                          • sumasterS
                                            sumaster
                                            @tak2hata said:
                                            @sumaster said:
                                            yes
                                            Pleas CHK
                                            Yes . . .
                                            Please CHK the Compound wall . .
                                            Sept11 2012 _3 (For Tak2hata) .skp
                                            Thank you,
                                            SUmaster
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
