    How can a dialog be made modal on Mac
    16 Posts 4 Posters 2.3k Views 4 Watching
      I see. Interesting.
        driven
        Thomas
        I added a pic of Cleanup while you where posting
          Sisu
          Thanks for the all the replies. They have been very helpful. I have downloaded Thom's code and am working with it now.
          I looked at John's fauxModal, but I had a hard time understanding the code.
          John you said you would "PM you my code if you want a look, but you need to test it on a mac," I would like to look at it, think I can learn a lot from it. I do have a Mac - OS X 10.6.8, although I am far more familiar with Windows.
          TIG, It's easier to think of my code not as a tool but as an application that uses SU as a graphics display engine, taking advantage of the SU classes and methods. The user communicates to the app by a series of dialog windows, modal and non-modal. With the dialogs the user to puts together combinations of parts. There are rules about how the parts can connect and the parts being connected must be compatible. All of which means that reducing assembly errors is a big part of the application. One example of the need for modal windows is when the user asks for an illegal combination, I need them to remain on the dialog window until they acknowledge the change I made for them or select a different option. There are other examples, but no need to cover them in this thread.
          Many thanks - Sisu / JJ
            driven
            hi Sisu/JJ,
            what I posted is what I would have PM'd, I decide to put it up for thomas to see how it was different from his.
            however I just added some more commenting, and tidied up a few things so you may be able to follow it now. So I'll swop out the original above.
            the css and html for the mochup 'Login' box is a little ruff and was just chucked in to suit your question.
              driven
              tried to edit this code block, but lost my original post.....
              basicly shows the difference between mine and TT's versions...
              # full screen webDialog
               def fauxModal()
               # first purge previous 'fauxModal' files using system calls
               # system('rm ./tmp/grab_*')
               # system('rm ./tmp/html_*')
               # will return true if file existed false if it wasn't there.
               `rm ./tmp/grab_*`
               `rm ./tmp/html_*`
               # dosen't bother returning, simply removes or not.
              # create consistant frozen time stamp
              =begin
              > tm=(Time.now.usec).to_s.dup
              512278
              > tm
              512278
              =end
              tm=(Time.now.usec).to_s.dup  # can't remember why I decided a duplicate was better, without seems to work?
              # full screen image for background  http://developer.apple.com/library/mac/#documentation/Darwin/Reference/ManPages/man1/screencapture.1.html
              # write image with usable name
              system('screencapture -m -o -T 0 -x ./tmp/grab_' + tm + '.png') # if you use system() you can add the timestamp in the same line
              # create a handle for the file produced
              imgNew=("/tmp/grab_" + tm + ".png").to_s
              # requires ruby to grab a handle for resulting file >> /tmp/grab_512278.png
              # the other way I use sometimes.
              =begin
              `screencapture -m -o -T 0 -x /tmp/grab_`
              # make usable name by adding the timestamp
              File.rename("/tmp/grab_", ("/tmp/grab_" + tm + ".png"))
              # but you still need to get the handle as File.rename returns 0 on success?
              =end
              # measure image for WebDialog size NB sips = system image processing on a mac and I use `` instead of system('')
              wh=(`sips -g pixelWidth -g pixelHeight /private/tmp/grab_*.png`).split.to_a
              w=wh[-3].to_i
              h=wh[-1].to_i
              # write the blank html file
              snpHtmlPath=('./tmp/html_' + tm + '.html')
              snpHtml=(File.open(snpHtmlPath, 'w+'))
              content= <<TOP
              <!DOCTYPE HTML>
              <html>
              	<head>
              	<meta http-equiv="cache-control" content="no-cache" />
              		<title>
              TOP
              more= <<MORE
              </title>
              <style>
              #fauxBg {
                 margin; 0;
                 padding; 0;
                 width; 100%;
                 height; 100%;
              MORE
              rest= <<REST
                 background-repeat; no-repeat;
                 background-position; left, bottom;
                 background-size; 100%, 100%;
                 background-attachment; fixed;
              	  /* from linked file;*/
              body.overlaid {
                -webkit-user-select; none;
              body.overlaid div.overlay {
                -webkit-transform; translateY(0);
                div.overlay {
                  /* using display none to hide the overlay nullifies -webkit-transition */
                  -webkit-transform; translateY(-2000px);
                  position; fixed;
                  width; 100%;
                  height; 100%;
                  top; 0;
                  left; 0;
                  background-image; -webkit-radial-gradient(50% 0%, ellipse cover, rgba(0,0,0,0.4), rgba(0,0,0,0.6) 100%);
                  -webkit-user-select; auto;
                  div.overlay > div.wrap-outer {
                    position; relative;
                    width; 100%;
                    height; 100%;
                    display; -webkit-box;
                    -webkit-box-orient; horizontal;
                    -webkit-box-align; stretch;
                    -webkit-box-pack; center;
                    div.overlay > div.wrap-outer > div.wrap {
                    	-webkit-box-orient; vertical;
                    	/* -webkit-box-pack; center; */
                      div.overlay > div.wrap-outer > div.wrap > * {
                      	-webkit-box-flex; 0;
                      	display; block;
                      /* For this demo. Feel free to customize */
              .my-dialog {
              	/* width; 500px;
              	resize; both; */
              	background; #fff;
              	overflow; auto;
              	-webkit-border-radius; 10px;
              	padding; 15px;
              	-webkit-box-sizing; border-box;
              	-webkit-box-shadow; 0 3px 6px rgba(0,0,0,1);
              	background; -webkit-linear-gradient(#fff, #e6e6e6);
              	font; 13px "Helvetica";
              .my-dialog input {
              	resize; none;
              .my-dialog h1 {
              	margin; 0 0 15px;
              	font; bold 24px Helvetica;
              ul {
              	list-style-type; none;
              </style>
              	</head>
              <body id="fauxBg" class="overlaid">
               <div class="overlay">
                    <div class="wrap-outer">
                      <div class="wrap">
                        <div class="my-dialog">
                          <h1>User Login</h1>
                          <p>but only if you paid</p>
                          <form>
                            <ul id="list">
                              <li>Username; <input type="text"></li>
                              <li>Email; <input type="email"></li>
                              <li>Password; <input type="password"></li>
                            </ul>
                            <p><a href="#" onclick="document.getElementById('list').innerHTML += '&lt;li&gt;Input; &lt;input&gt;&lt;/li&gt;';">Not registered yet? Click here</a></p>
                          </form>
                          <hr>
                           <button onclick="#();">Login</button>
                        </div>
                      </div>
                    </div>
                  </div>
              <!--  <p><button onclick="">Login</button> to trigger it</p> -->
              </body>
              </html>
              REST
              # fill in the 'blank' html
              if File.exists?(snpHtml)
              snpHtml.rewind
              all=(content + tm + more + ('background; url(file;///' + imgNew + ');') + rest ) # this is the easiest way to include a correctly spaced path.
              snpHtml.puts all
              snpHtml.rewind
              snpHtml.close
              this=("fauxSu_" + tm)
              fauxSu = UI;;WebDialog.new(this, false, this, w, (h), 0, 0, false); # I sometimes use (h-22)
                 fauxSu.set_file(snpHtmlPath)
                 fauxSu.show_modal
              # TO RUN;  select all and paste into 'Ruby Console' (it's multi line on mac) and hit enter/return, then type  fauxmodal and hit enter/return again.
              # hit esc key to exit on click to red button on menu bar.
              cleanup and others
                Sisu
                Thom,
                I can only get so far with your window class, I must be doing something wrong. On Windows I can make a modal window appear, but can't get my html/js loaded in it. On OS X, nothing seems to happen. Below is an example that is very simple: A window with an OK button. It works fine with the UI::WebDialog in doMsgBox, but I fail to get it to work in doTTMsgBox. I have tried many things from windows.rb and webdialog_patch.rb but to no success. What am I missing?
                simple html/js:
                <span class="syntaxhtml"><span class="syntaxdefault"><br /></span><span class="syntaxkeyword"><</span><span class="syntaxdefault">script&nbsp;language</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"javascript"</span><span class="syntaxkeyword">><br />function&nbsp;</span><span class="syntaxdefault">sendUserChoice</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">userInput</span><span class="syntaxkeyword">){&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">location</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">href&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">'skp;LTE_okBox@'&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">userInput</span><span class="syntaxkeyword">;<br />}<br /></span><span class="syntaxdefault"></script></span>&nbsp;&nbsp;&nbsp;&nbsp;<br /><body><br />&nbsp;&nbsp;&nbsp;&nbsp;<input&nbsp;type="button"&nbsp;value="Ok"&nbsp;onClick='sendUserChoice("OK")'/><br /></body></span>
                <span class="syntaxdefault"><br />Sketchup</span><span class="syntaxkeyword">;;require&nbsp;</span><span class="syntaxstring">'TT_Lib2/core.rb'<br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;require&nbsp;</span><span class="syntaxstring">'TT_Lib2/webdialog_patch.rb'<br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;require&nbsp;</span><span class="syntaxstring">'TT_Lib2/gui.rb'<br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;require&nbsp;</span><span class="syntaxstring">'TT_Lib2/window'<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxstring">"TT_demo"</span><span class="syntaxkeyword">)<br /><br /><br /></span><span class="syntaxdefault">$_MSBReply&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"0"<br /></span><span class="syntaxdefault">module&nbsp;MYMB<br />def&nbsp;MYMB</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">doMsgBox</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"LTE_okbox"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"LTE"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_action_callback</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"LTE_okBox"</span><span class="syntaxkeyword">)&nbsp;do&nbsp;|</span><span class="syntaxdefault">web_dialog</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"user_action&nbsp;=&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">.include?&nbsp;</span><span class="syntaxstring">"OK"&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">$_MSBReply&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"1"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_file</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_support_file</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Plugins/jj/okbox.html"</span><span class="syntaxkeyword">))<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_modal</span><span class="syntaxkeyword">()&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bring_to_front<br />end&nbsp;</span><span class="syntaxcomment">#dMB<br /><br /></span><span class="syntaxdefault">def&nbsp;MYMB</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">doTTMsgBox</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Window</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"LTE_okbox"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"LTE"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">10</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">10</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">220</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">220</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_action_callback</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"LTE_okBox"</span><span class="syntaxkeyword">)&nbsp;do&nbsp;|</span><span class="syntaxdefault">web_dialog</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"user_action&nbsp;=&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">.include?&nbsp;</span><span class="syntaxstring">"OK"&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">$_MSBReply&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"TT1"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;p2&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_support_file</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Plugins/jj/okbox.html"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#mbDlg.set_file(p2)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_html</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">p2</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_window</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bring_to_front&nbsp;&nbsp;&nbsp;&nbsp;<br />end&nbsp;</span><span class="syntaxcomment">#dTTMB<br /></span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#m&nbsp;MYMB<br /><br /></span><span class="syntaxdefault">MYMB</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">doMsgBox<br />puts&nbsp;</span><span class="syntaxstring">"back&nbsp;from&nbsp;SU;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">$_MSBReply<br />MYMB</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">doTTMsgBox<br />puts&nbsp;</span><span class="syntaxstring">"back&nbsp;from&nbsp;TT;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">$_MSBReply</span>
                Thanks for taking the time to look into this - JJ
                  Sisu
                  Please remove the "[color=...]" and "[/color]" from the code before trying - I've not used BBCode much and tried to get too fancy.
                    The reason being is that you cannot replace the HTML.
                    I've been building wrappers to create UI controls with Ruby code. I'll see if I can compile an example...
                      Sisu
                      Thanks guys, I sure between your 2 solutions and with bit of re-architecture, I'll be able to port to the Mac.
                      Thom - I made some wrong assumptions about your code. I'd like to see a simple example.
                      John/driven - fauxModal is very cool. Nice approach with the HTML, I never considered building it 'on the fly'.
                      • JJ
                        Ah, as it turns out - I made the modal feature only for TT::GUI::Inputbox. (What I use with CleanUp)
                        My approach to "modal" was to push a Tool to the tool stack which will draw the dimming screen. It also detect if the user activates another tool which it takes as a cancel action to close the dialog. There is much to be improved with this method. (For instance, I think you can block the Orbit tool from activating)
                        https://bitbucket.org/thomthom/tt-library-2/src/7462992bf4f3/TT_Lib2/modal_wrapper.rb
                        In either case, my TT:GUI::Window class is something you can't easily swap in for UI::WebDialog. I have a set of Ruby classes for Button, Checkbox etc which generates the HTML and JS for you. As well as pre-defined styling. To add custom behaviour you must attach JS scripts. It's far from complete and likely to change.
                        But for the sake of it - Hello World example of my TT:GUI::Window class:
                        <span class="syntaxdefault"><br />module TT_Test<br /><br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">create_window<br />    options </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">title </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">'Hello Window'</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">resizable </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> false</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">width </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> 300</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">height </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> 200<br />    </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    window </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Window</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> options </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">theme </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Window</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">THEME_GRAPHITE<br />    <br />    button </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Button</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Close'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">control</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">      control</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br />    </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    button</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">size</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> 75</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 28 </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    button</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">right </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 5<br />    button</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bottom </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 5<br />    window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_control</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> button </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    <br />    window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_window<br />    <br />    window<br />  end<br /><br />end </span><span class="syntaxcomment"># module<br />&nbsp;</span><span class="syntaxdefault"></span>
                        I've found that instead of fighting against this problem I change the code flow to not require modal windows. Often it can be done - just needs a different thinking. Which is why I haven't worked further on the issue.
