    How can a dialog be made modal on Mac
    16 Posts 4 Posters 1.9k Views 4 Watching
      Sisu
      I wish to have a modal password window, one that solicits a password, returns the user's input. The plugin then validates the password entered and until a valid password in entered nothing else can happen.
      Under windows this this can done via dialog.show_modal.
      But after playing around with Threads, join etc. I have yet to come up with a good method for doing this using dialog.show.
      Does anyone have ideas, suggestions or a simple sample they would share.
      • JJ
        driven
        hi,
        .show_modal is the prefered method for most WebDialogs on a mac.
        It does behave differently than on a PC.
        It will float the dialog on top of SU, but
        You cannot not Block the User from doing 'other' things. i.e. return to drawing, switching plugins, closing 'your' WebDialog.
        The rest is up to how your html 'controls' your plugin access.
        What are you attempting to block?
        Where would you check the credentials?
        I've done a lot of investigating into 'true_modal' (how to avoid it) and your better off using a UI.messagebox() if it's for blocking unregistered users from using a locally installed plugin.
          Sisu
          Thanks for the reply John, I was afraid that would be the answer. In my case password validation is done in the plugin and it is not meant to be absolute security. I have other windows that gather a lot of information about what the user wants to do next, and that information must be gathered before the user can progress. As you point out some of the UI method's are modal so it is possible to do this on the Mac just not with SU/ruby. I hope this will addressed in future releases of SU as I find it difficult to imagine developing a sophisticated user-driven application without being able to control the user's navigation.
          • TIGT Online
            Whether the dialog is modal or not is irrelevant... IF the web-dialog is a gateway to running a specific tool.
            Then if the user doesn't enter the correct password/license-code etc the tool simply goes no further and the dialog closes... The tool never runs.
            If you are trying to prevent the user from ever using Sketchup at all [!] then it's simply bypassed by the user doing something to the Plugins folder before trying ??
            The logic of your intent seems flawed - please disabuse me ??
              driven
              I know a number of plugins really don't like the user doing anything while performing ruby chores, so I have played with making 'faux modal' Webdialogs from time to time.
              My latest one is reasonably good at appearing to be 'Modal', although pressing escape cancels it. It could easily have a progress spinner if used to mask work being done, then resize on completion of tasks.
              full screen WebDialog with screencapture as background, text fields and buttons work
              I'll PM you my code if you want a look, but you need to test it on a mac, it has system calls for screen capture and size. Also uses HTML5 and CSS3
                That's the same thing I did for CleanUp. (The code is in TT_Lib2: http://www.thomthom.net/software/sketchup/tt_lib2/doc/TT/GUI/Window.html )
                  I see. Interesting.
                    driven
                    Thomas
                    I added a pic of Cleanup while you where posting
                      Sisu
                      Thanks for the all the replies. They have been very helpful. I have downloaded Thom's code and am working with it now.
                      I looked at John's fauxModal, but I had a hard time understanding the code.
                      John you said you would "PM you my code if you want a look, but you need to test it on a mac," I would like to look at it, think I can learn a lot from it. I do have a Mac - OS X 10.6.8, although I am far more familiar with Windows.
                      TIG, It's easier to think of my code not as a tool but as an application that uses SU as a graphics display engine, taking advantage of the SU classes and methods. The user communicates to the app by a series of dialog windows, modal and non-modal. With the dialogs the user to puts together combinations of parts. There are rules about how the parts can connect and the parts being connected must be compatible. All of which means that reducing assembly errors is a big part of the application. One example of the need for modal windows is when the user asks for an illegal combination, I need them to remain on the dialog window until they acknowledge the change I made for them or select a different option. There are other examples, but no need to cover them in this thread.
                      Many thanks - Sisu / JJ
                        driven
                        hi Sisu/JJ,
                        what I posted is what I would have PM'd, I decide to put it up for thomas to see how it was different from his.
                        however I just added some more commenting, and tidied up a few things so you may be able to follow it now. So I'll swop out the original above.
                        the css and html for the mochup 'Login' box is a little ruff and was just chucked in to suit your question.
                          driven
                          tried to edit this code block, but lost my original post.....
                          basicly shows the difference between mine and TT's versions...
                          # full screen webDialog
                           def fauxModal()
                           # first purge previous 'fauxModal' files using system calls
                           # system('rm ./tmp/grab_*')
                           # system('rm ./tmp/html_*')
                           # will return true if file existed false if it wasn't there.
                           `rm ./tmp/grab_*`
                           `rm ./tmp/html_*`
                           # dosen't bother returning, simply removes or not.
                          # create consistant frozen time stamp
                          =begin
                          > tm=(Time.now.usec).to_s.dup
                          512278
                          > tm
                          512278
                          =end
                          tm=(Time.now.usec).to_s.dup  # can't remember why I decided a duplicate was better, without seems to work?
                          # full screen image for background  http://developer.apple.com/library/mac/#documentation/Darwin/Reference/ManPages/man1/screencapture.1.html
                          # write image with usable name
                          system('screencapture -m -o -T 0 -x ./tmp/grab_' + tm + '.png') # if you use system() you can add the timestamp in the same line
                          # create a handle for the file produced
                          imgNew=("/tmp/grab_" + tm + ".png").to_s
                          # requires ruby to grab a handle for resulting file >> /tmp/grab_512278.png
                          # the other way I use sometimes.
                          =begin
                          `screencapture -m -o -T 0 -x /tmp/grab_`
                          # make usable name by adding the timestamp
                          File.rename("/tmp/grab_", ("/tmp/grab_" + tm + ".png"))
                          # but you still need to get the handle as File.rename returns 0 on success?
                          =end
                          # measure image for WebDialog size NB sips = system image processing on a mac and I use `` instead of system('')
                          wh=(`sips -g pixelWidth -g pixelHeight /private/tmp/grab_*.png`).split.to_a
                          w=wh[-3].to_i
                          h=wh[-1].to_i
                          # write the blank html file
                          snpHtmlPath=('./tmp/html_' + tm + '.html')
                          snpHtml=(File.open(snpHtmlPath, 'w+'))
                          content= <<TOP
                          <!DOCTYPE HTML>
                          <html>
                          	<head>
                          	<meta http-equiv="cache-control" content="no-cache" />
                          		<title>
                          TOP
                          more= <<MORE
                          </title>
                          <style>
                          #fauxBg {
                             margin; 0;
                             padding; 0;
                             width; 100%;
                             height; 100%;
                          MORE
                          rest= <<REST
                             background-repeat; no-repeat;
                             background-position; left, bottom;
                             background-size; 100%, 100%;
                             background-attachment; fixed;
                          	  /* from linked file;*/
                          body.overlaid {
                            -webkit-user-select; none;
                          body.overlaid div.overlay {
                            -webkit-transform; translateY(0);
                            div.overlay {
                              /* using display none to hide the overlay nullifies -webkit-transition */
                              -webkit-transform; translateY(-2000px);
                              position; fixed;
                              width; 100%;
                              height; 100%;
                              top; 0;
                              left; 0;
                              background-image; -webkit-radial-gradient(50% 0%, ellipse cover, rgba(0,0,0,0.4), rgba(0,0,0,0.6) 100%);
                              -webkit-user-select; auto;
                              div.overlay > div.wrap-outer {
                                position; relative;
                                width; 100%;
                                height; 100%;
                                display; -webkit-box;
                                -webkit-box-orient; horizontal;
                                -webkit-box-align; stretch;
                                -webkit-box-pack; center;
                                div.overlay > div.wrap-outer > div.wrap {
                                	-webkit-box-orient; vertical;
                                	/* -webkit-box-pack; center; */
                                  div.overlay > div.wrap-outer > div.wrap > * {
                                  	-webkit-box-flex; 0;
                                  	display; block;
                                  /* For this demo. Feel free to customize */
                          .my-dialog {
                          	/* width; 500px;
                          	resize; both; */
                          	background; #fff;
                          	overflow; auto;
                          	-webkit-border-radius; 10px;
                          	padding; 15px;
                          	-webkit-box-sizing; border-box;
                          	-webkit-box-shadow; 0 3px 6px rgba(0,0,0,1);
                          	background; -webkit-linear-gradient(#fff, #e6e6e6);
                          	font; 13px "Helvetica";
                          .my-dialog input {
                          	resize; none;
                          .my-dialog h1 {
                          	margin; 0 0 15px;
                          	font; bold 24px Helvetica;
                          ul {
                          	list-style-type; none;
                          </style>
                          	</head>
                          <body id="fauxBg" class="overlaid">
                           <div class="overlay">
                                <div class="wrap-outer">
                                  <div class="wrap">
                                    <div class="my-dialog">
                                      <h1>User Login</h1>
                                      <p>but only if you paid</p>
                                      <form>
                                        <ul id="list">
                                          <li>Username; <input type="text"></li>
                                          <li>Email; <input type="email"></li>
                                          <li>Password; <input type="password"></li>
                                        </ul>
                                        <p><a href="#" onclick="document.getElementById('list').innerHTML += '&lt;li&gt;Input; &lt;input&gt;&lt;/li&gt;';">Not registered yet? Click here</a></p>
                                      </form>
                                      <hr>
                                       <button onclick="#();">Login</button>
                                    </div>
                                  </div>
                                </div>
                              </div>
                          <!--  <p><button onclick="">Login</button> to trigger it</p> -->
                          </body>
                          </html>
                          REST
                          # fill in the 'blank' html
                          if File.exists?(snpHtml)
                          snpHtml.rewind
                          all=(content + tm + more + ('background; url(file;///' + imgNew + ');') + rest ) # this is the easiest way to include a correctly spaced path.
                          snpHtml.puts all
                          snpHtml.rewind
                          snpHtml.close
                          this=("fauxSu_" + tm)
                          fauxSu = UI;;WebDialog.new(this, false, this, w, (h), 0, 0, false); # I sometimes use (h-22)
                             fauxSu.set_file(snpHtmlPath)
                             fauxSu.show_modal
                          # TO RUN;  select all and paste into 'Ruby Console' (it's multi line on mac) and hit enter/return, then type  fauxmodal and hit enter/return again.
                          # hit esc key to exit on click to red button on menu bar.
                          cleanup and others
                            Sisu
                            Thom,
                            I can only get so far with your window class, I must be doing something wrong. On Windows I can make a modal window appear, but can't get my html/js loaded in it. On OS X, nothing seems to happen. Below is an example that is very simple: A window with an OK button. It works fine with the UI::WebDialog in doMsgBox, but I fail to get it to work in doTTMsgBox. I have tried many things from windows.rb and webdialog_patch.rb but to no success. What am I missing?
                            simple html/js:
                            <span class="syntaxhtml"><span class="syntaxdefault"><br /></span><span class="syntaxkeyword"><</span><span class="syntaxdefault">script&nbsp;language</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"javascript"</span><span class="syntaxkeyword">><br />function&nbsp;</span><span class="syntaxdefault">sendUserChoice</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">userInput</span><span class="syntaxkeyword">){&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">location</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">href&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">'skp;LTE_okBox@'&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">userInput</span><span class="syntaxkeyword">;<br />}<br /></span><span class="syntaxdefault"></script></span>&nbsp;&nbsp;&nbsp;&nbsp;<br /><body><br />&nbsp;&nbsp;&nbsp;&nbsp;<input&nbsp;type="button"&nbsp;value="Ok"&nbsp;onClick='sendUserChoice("OK")'/><br /></body></span>
                            <span class="syntaxdefault"><br />Sketchup</span><span class="syntaxkeyword">;;require&nbsp;</span><span class="syntaxstring">'TT_Lib2/core.rb'<br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;require&nbsp;</span><span class="syntaxstring">'TT_Lib2/webdialog_patch.rb'<br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;require&nbsp;</span><span class="syntaxstring">'TT_Lib2/gui.rb'<br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;require&nbsp;</span><span class="syntaxstring">'TT_Lib2/window'<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxstring">"TT_demo"</span><span class="syntaxkeyword">)<br /><br /><br /></span><span class="syntaxdefault">$_MSBReply&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"0"<br /></span><span class="syntaxdefault">module&nbsp;MYMB<br />def&nbsp;MYMB</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">doMsgBox</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"LTE_okbox"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"LTE"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_action_callback</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"LTE_okBox"</span><span class="syntaxkeyword">)&nbsp;do&nbsp;|</span><span class="syntaxdefault">web_dialog</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"user_action&nbsp;=&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">.include?&nbsp;</span><span class="syntaxstring">"OK"&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">$_MSBReply&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"1"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_file</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_support_file</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Plugins/jj/okbox.html"</span><span class="syntaxkeyword">))<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_modal</span><span class="syntaxkeyword">()&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bring_to_front<br />end&nbsp;</span><span class="syntaxcomment">#dMB<br /><br /></span><span class="syntaxdefault">def&nbsp;MYMB</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">doTTMsgBox</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Window</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">"LTE_okbox"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"LTE"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">10</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">10</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">220</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">220</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_action_callback</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"LTE_okBox"</span><span class="syntaxkeyword">)&nbsp;do&nbsp;|</span><span class="syntaxdefault">web_dialog</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"user_action&nbsp;=&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">user_action</span><span class="syntaxkeyword">.include?&nbsp;</span><span class="syntaxstring">"OK"&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">$_MSBReply&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"TT1"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;p2&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_support_file</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Plugins/jj/okbox.html"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#mbDlg.set_file(p2)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_html</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">p2</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_window</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mbDlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bring_to_front&nbsp;&nbsp;&nbsp;&nbsp;<br />end&nbsp;</span><span class="syntaxcomment">#dTTMB<br /></span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#m&nbsp;MYMB<br /><br /></span><span class="syntaxdefault">MYMB</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">doMsgBox<br />puts&nbsp;</span><span class="syntaxstring">"back&nbsp;from&nbsp;SU;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">$_MSBReply<br />MYMB</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">doTTMsgBox<br />puts&nbsp;</span><span class="syntaxstring">"back&nbsp;from&nbsp;TT;&nbsp;"&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">$_MSBReply</span>
                            Thanks for taking the time to look into this - JJ
                              Sisu
                              Please remove the "[color=...]" and "[/color]" from the code before trying - I've not used BBCode much and tried to get too fancy.
                                The reason being is that you cannot replace the HTML.
                                I've been building wrappers to create UI controls with Ruby code. I'll see if I can compile an example...
                                  Sisu
                                  Thanks guys, I sure between your 2 solutions and with bit of re-architecture, I'll be able to port to the Mac.
                                  Thom - I made some wrong assumptions about your code. I'd like to see a simple example.
                                  John/driven - fauxModal is very cool. Nice approach with the HTML, I never considered building it 'on the fly'.
                                  • JJ
                                    Ah, as it turns out - I made the modal feature only for TT::GUI::Inputbox. (What I use with CleanUp)
                                    My approach to "modal" was to push a Tool to the tool stack which will draw the dimming screen. It also detect if the user activates another tool which it takes as a cancel action to close the dialog. There is much to be improved with this method. (For instance, I think you can block the Orbit tool from activating)
                                    https://bitbucket.org/thomthom/tt-library-2/src/7462992bf4f3/TT_Lib2/modal_wrapper.rb
                                    In either case, my TT:GUI::Window class is something you can't easily swap in for UI::WebDialog. I have a set of Ruby classes for Button, Checkbox etc which generates the HTML and JS for you. As well as pre-defined styling. To add custom behaviour you must attach JS scripts. It's far from complete and likely to change.
                                    But for the sake of it - Hello World example of my TT:GUI::Window class:
                                    <span class="syntaxdefault"><br />module TT_Test<br /><br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">create_window<br />    options </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">title </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">'Hello Window'</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">resizable </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> false</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">width </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> 300</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">height </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> 200<br />    </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    window </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Window</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> options </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">theme </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Window</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">THEME_GRAPHITE<br />    <br />    button </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">GUI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Button</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Close'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">control</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">      control</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br />    </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    button</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">size</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> 75</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 28 </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    button</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">right </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 5<br />    button</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bottom </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 5<br />    window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_control</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> button </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    <br />    window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_window<br />    <br />    window<br />  end<br /><br />end </span><span class="syntaxcomment"># module<br />&nbsp;</span><span class="syntaxdefault"></span>
                                    I've found that instead of fighting against this problem I change the code flow to not require modal windows. Often it can be done - just needs a different thinking. Which is why I haven't worked further on the issue.
