    Any plugin to evenly space objects?
    24 Posts 10 Posters 12.1k Views 10 Watching
      So the line would define the line of alignment and distance over which the components would be spaced? Components placed by their origins? How would alignment be determined? Aligned to global axes? In Pathcopy the alignment can be tricky so sometimes for my use it is a bit of trial and error.
      • Didier BurD Offline
        Didier Bur
        Maybe this one (align 2D) ? http://rhin.crai.archi.fr/rld/plugin_details.php?id=12
        DB
          Didier rides to the rescue wearing a white hat! πŸ‘
          How hard would it be to add an option to space the components evenly along the line?
            This one ? πŸ’š
            http://forums.sketchucation.com/download/file.php?id=30068
            • CadFatherC Offline
              CadFather
              no such thing exists (yet) - 'js align' is the closest i've seen to play with the position of objects but of course does not space them. the fact that master Thom himself is asking, is unreasonably worrying... it really is needed.
              with all the trickery, surely this can't be too difficult..?
                Not really - it's not hard - just didn't want to reinvent the wheel. But alas, I never got around to make anything myself... 😳
                  CadFather
                  ok, i feel better now... (at least there's no intellectual property on the wheel!)
                  • JClementsJ Offline
                    JClements
                    I think it would be useful, but tricky to do in 3D.
                    For instance, equal spacing between objects/groups/components that have a depth, height, and width. Do you use the model axes or the axes of the group/component to determine the spacing in between them (assuming the measurements are taken orthogonally to the axes)?
                      If I had made it I would have had toggles for setting the axis it would work in: World, Local, Custom (Tool defining a custom working axis)
                        Why do you want not use my little "undrop" plug above? πŸ’š
                        Very rustic but works very well πŸ˜„
                        First "Align" (or not), "Drop" your objects selected with any plugs existing
                        Then "undrop" them with my little plug with any measures β˜€
                        And then rotate if wanted a special orientation "line" of them as you want !
                        All takes only seconds πŸ˜‰
                          sexypox69
                          Im kind of late to this topic but has anyone come up with a solution to this.....I come acroos this senerio almost every day with what i do. It would be wonderful to have a plugin which aligns selected objects along a path plus the option of along the axis, be able to specify the distance and have it spaced equally or at a given distant.....like in layout you can align, space and center selected objects......
                          • F Offline
                            function
                            sam da mitch makes exactly this.
                            http://sdmitch.blogspot.com
                            Align&Distribute - Align and space selected objects along an axis.
                            Haven't spent much time with it, but it wasnt the most intuitive interface, looks great if you follow the console
                              joshuabrew
                              hey!
                              any leads on a plugin for this?? looking for the same... basically the sketchup equivalent of the distribute and align tools common in adobe indesign and illustrator, but for 3D objects in sketchup.
                              thx!
                              j
                                @joshuabrew said:
                                hey!
                                thx!
                                j
                                Hey! Did you try the link in the post immediately above yours from 2014?
