    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • Z
      ZFRPS
      Tak2hata:
      Thank you very much !
      I LOVE YOU !
      sketchup is bim
      • T
        tak2hata
        Hello
        After installing V 1.0a, I have the following error code. Not sure why.
        Thanks in advance for your plugins and help
        Ken
        Tak2hata
        Thanks for the update 1.1b. It fixed the above illustrated error. However, I notice now, that the beams selection will not make any beams that are vertical. It will make beams close to vertical but not exactly 90 degrees. As close as I can get to vertical is 0.067 degrees off vertical. I didn't see this problem on the first version.
        Again thanks for the quick response on the other error.
        Ken
        Hi,Ken.
        I want to see your description as picture.and parameters in webdialog.
        And I have an elementary question.
        "degrees" is units of distance?
        In my country ,distance is decimal.so I'm not used to be the degree as distance.
        Does 90 degrees equal to 1/4"?
        Thanks.
        by TAK2HATA
        • kenK
          ken
          The three illustration show a yellow background rectangle, 2'wide by 10' tall. Starting at the bottom at the center line closest I can get the 4x13 I beam to vertical is 9/64 off the center vertical line at the top. So right now I can not draw any beams exactly vertical.
          Hope this helps.
          Ken
            SUFractal
            Hope this helps.
            Ken
            Ken:
            For comparison's sake, I did a similar test and do not seem to have an issue with true verticality. I used the 'column' tool and my column was 12'-0" tall. I noticed that you used the term 'beam' ... are you by any chance using the beam tool to try to draw a vertical line as a column? Is that perhaps the cause?
            SUFractal
            • kenK
              ken
              Well yes, I am using the beam tool, along with the "bar, T-bar, pipe, angles and beams" None these selection will make a vertical object. Note, zooming in for a real close view, I can see that as long as the top (note going from the top to bottom doesn't make a difference) selection point is outside the area where the point will be snapped to the vertical I can make any of the above objects. However, if I let Sketchup snap take over and the point is snap to a vertical position, than the program will not make the selected object, "beam, bars, pipe angle or beams". See the attached file.
              Ken
              Vertical Test Ken.skp
              • T
                tak2hata
                Ken
                Hi,Ken,SUFracatal.
                I understand this problem.
                This is mistake of mine.
                I want to limit the drawing wall as vertical.(It make error certainly.)
                But this code is not so.
                I will fix this bug later.Now I am out of my computer.
                Sorry,Please wait.
                Thanks.
                by TAK2HATA
                • guanjinG
                  guanjin
                  tak2hata:
                  Thank you for your hard work
                  How to disappear other tools? icons, language change does not completely!
                  Click on the icon does not work
                  • T
                    tak2hata
                    H,All.
                    I update this.
                    ...KEN.
                    BUGFIX :about create nothing when clicks points as Vertical.
                    It will clear the problem.
                    ...guanjin.
                    Laungage .......
                    Wait deadly tried me.
                    or You can change word as you like If you can edit html.
                    It is more convenient to be both?
                    or If it is both, what will be troubled?
                    I can not know what makes problem from that text.
                    Good night. πŸ˜‰
                    by TAK2HATA
                    • Z
                      ZFRPS
                      tak2hata:
                      about create nothing when clicks points as Vertical,
                      in v1.1d not clear,
                      please try one times it ;
                      Thanks again !
                      sketchup is bim
                      • T
                        tak2hata
                        tak2hata:
                        in v1.1d not clear,
                        Thanks again !
                        Hi.
                        At first,when working with the class "wall" ,you can not pick second point to vertical.
                        I need to know more detailed information if this is not your case.
                        1. Screen shot of setting inBst dialog.
                        2. The axis the slope directing to.(x,y,z)
                        3. The message Ruby console shows when the error is exists.
                        4. I want to see the two picked points were truely vertical.
                        Please reply about lines above.
                        by TAK2HATA
                        • Z
                          ZFRPS
                          Dear tak2hata:
                          This my test,please try it again !
                          Your this plugin already very powerful,I wish it change more powerful πŸ‘
                            thanks again!
                          sketchup is bim
                          • T
                            tak2hata
                            Dear tak2hata:
                            [attachment=3:22lfhpqk]<!-- ia3 -->c01.jpg<!-- ia3 -->[/attachment:22lfhpqk][attachment=2:22lfhpqk]<!-- ia2 -->c02.jpg<!-- ia2 -->[/attachment:22lfhpqk][attachment=1:22lfhpqk]<!-- ia1 -->c03.jpg<!-- ia1 -->[/attachment:22lfhpqk][attachment=0:22lfhpqk]<!-- ia0 -->c04.jpg<!-- ia0 -->[/attachment:22lfhpqk]
                              thanks again!
                            Hi,zfrps.
                            "MWALL" is not able to create automatically from curves.
                            I will test "COLUMN" auto create.
                            tak2hata:
                            in v1.1d not clear,
                            Does this reply mean this problem?
                            Thnx.
                            by TAK2HATA
                            • Z
                              ZFRPS
                              Dear tak2hata:
                              Yes!
                              Especially about automatically created "column ";before it's nice,now it need strengthen.
                              β˜€
                              sketchup is bim
                              • T
                                tak2hata
                                Hi,zfrps and all.
                                I update BST version to 1.1e.
                                Bugfix about auto creating columns.
                                And improves.
                                BST becomes nice tool step by steps.
                                Thanks.
                                by TAK2HATA
                                • Z
                                  ZFRPS
                                  tak2hata:
                                  Maybe only need keep one of dialog box!
                                  sketchup is bim
                                  • Z
                                    ZFRPS
                                    tak2hata:
                                    now, a times only can choose one entity or face,Whether it can be a much choose?
                                    moreover, have extend to face already,so maybe show to face no need !?
                                    sketchup is bim
                                    • Z
                                      ZFRPS
                                      Dear tak2hata:
                                      However,I still have some ideas to speak out,Because I love too the plugin,I believe that your this plugin will produce very big help to BIM.
                                      1. **grow to face** only useful for "Z",but for **MWALL** is invalid;
                                      2. The shape of the face for ladder;**grow** or **extend** is invalid too;
                                      3. One-time much choose can greatly improve the efficiency of the modeling.
                                      THANKS AGAIN !
                                      sketchup is bim
                                      • H
                                        Heven7_floor
                                        πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                        Very powerfull tool, this very very usefully for construction with sketchup, Thanks Tak2hata, your creative brough the good things come to other
                                        πŸ‘ πŸ‘ πŸ‘
                                          SUFractal
                                          tak2hata:
                                          I have what I hope is a simple question. How do I change the color of any beam, column, etc. before placing/drawing it? In the webdialog box, the option default is black. No matter which color I type into the box, the color remains a light blue color.
                                          Thanks,
                                          SUfractal
                                          • T
                                            tak2hata
                                            I am too busy.So I can not improve my plugins.
                                            Multiple "Grow to face" will be added.
                                            I will consider applying "Grow" for "MWALL".
                                            @sufractal said:
                                            tak2hata:
                                            The color is material.
                                            Beams material is created from "FRONT FACE MATERIAL" and "BACK FACE MATERIAL".
                                            It appears random color when the materialnames in "FRONT FACE MATERIAL" and "BACK FACE MATERIAL" is not existed in sketchup model.
                                            So you may set sketchup templete with the materials.
                                            Thanks.
                                            by TAK2HATA
                                            • 16
                                            • 17
                                            • 8 / 17
