    Problem exporting animation?
    19 Posts 4 Posters 705 Views 4 Watching
      Please don't double-post... as a new member have patience with your first two or three posts as 'the system' needs to be sure you are not a spambot etc... Also avoid too much profanity ๐Ÿ˜ฎ
      Do you have v8 pro ?
      Has it reverted to 'free' after some hours' of trial-use, thereby maybe deactivating its pro Animation option etc ?
      Have you set up the SKP to allow animation ?
      • GaieusG
        The free version can export animation since version 6 so Pro/Free should not be an issue.
        Have you created scene tabs at all?
        • G
          Gorilla_mean_2
          Yees i have and its still not working?
          Think i should reinstall?
            Probably not.
            Perhaps you could post the SKP file?
            • G
              Gorilla_mean_2
              SKP? Whats that?
                The SketchUp file.
                • G
                  Gorilla_mean_2
                  hOW I DO THAT?
                    Click on Upload attachment below the text window and select your SKP file for the SketchUp model you're trying to make the animation of. ๐Ÿ˜’
                    • G
                      Gorilla_mean_2
                      wONT LET ME? it takes like 4 mins to load and it says
                      "Bad Request
                      Your browser sent a request that this server could not understand.
                      Apache/2 Server at localhost Port 80"
                        How big is this SKP ?
                        Can you Purge it under Model Info > Statistics, then zip it, and then try to attach the zip file... assuming it is <=4Mb...
                        • G
                          Gorilla_mean_2
                          Doesnt show me zip it shows me purge unused and Fix problem? wtf like my computer retarded?
                            I don't think it's your computer. ๐Ÿ˜’
                            You need a utility to create the ZIP file. It's not part of SketchUp. You can use 7zip. It's free.
                            • G
                              Gorilla_mean_2
                              Ughh i dont know any of this im only 13? ur like 18-20?
                                Yeah. About that old. ๐Ÿ˜’
                                Get 7zip here. Go to that page and download the file and install it. If you were able to install SketchUp you can install 7zip.
                                After it is installed, find the SKP file for your SketchUp model. Right click on its name and choose 7zip>Add to filename.zip where filename is the name of the SketchUp file.
                                I would suggest you make a simple little model and try animating that. Since your current file is too large to upload here, I would gather it's rather complex. It sounds to me as if you're trying to run a marathon before you've learned to walk. That's a sure way to frustration. Don't make it hard on yourself.
                                • G
                                  Gorilla_mean_2
                                  Done i zipped it and it is a bookshelf? and its name is sniper into?
                                  I think that 7zip is winrar
                                  • G
                                    Gorilla_mean_2
                                    Mhh still cant export then animation? #profanity removed#
                                    • GaieusG
                                      Dan, how big is your skp ("SketchUp") file when you save it?
                                        Good grief!
                                        No! 7zip is not winrar. ๐Ÿ˜’
                                        Creating the zip file was only intended to make it small enough that it could be uploaded here.
