    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
      sags
      thank you for the shape bender sir.. 👍
      • H
        huntress_ss
        Hey Chris,
        I've tried ading this plug-in to my sketch-up but it's not working. Show's up with error load with "Error Loading File clf_shape_bender_loader.rb
        no such file to load -- progressbar.rb"
        Any suggestions on how to get this working?
        • GaieusG
          Please, read the instructions carefully. Chris clearly wrote that you (also) need to install progresbar.rb.
            mwm5053
            Not sure if this has been covered but getting error when using Shape bender with a slew of plugins in plugin folder when all are removed but
            Shape Bender it works fine screen shot on ruby console
            Thanks in advance.
            2011 iMac
            SU 2015 Pro, 2017 Make
            V2 Twilight
            macOS Sierra 10.12.5
              This is an odd error... it relates to a variable that should be set to a number by one of the tool's methods in line #676, clearly it's failing to do that hence the 'nil' error message when its used for a '/' divide calculation...
              @offset = **@y_total** / 6
              This is set around line #641, as either
              @y_total = @line_y - @ymin
              or
              @y_total = @ymax - @ymin
              So it seems the get_max_y method is failing somehow.
              That is turn is called from the get_geom_ents method; which is in turn called in line #249 when the user has picked the required objects to trigger the 'bending'...
              This suggests that if there's no error in the script [used without issue by thousands?] then perhaps another script is making an 'unwrapped' call of its method[s] with similar names and thereby causing the issue - unlike the usual rogue scripts which redefine how Sketchup treats Groups etc, which is far more awkward...
              A 'fix' could be to do a find/replace on all of the code in the script [using Notepad osa], so that all of the get_max_y become say get_max_y_CLF and get_geom_ents become get_geom_ents_CLF - then any clash with other scripts might be averted...
                Hasn't that error been described and explained earlier in this thread? Think it comes up pretty often. Might be a bug in the code itself. Might be worth adding it to the first post (when we work out what it was again.)
                Wasn't there something about the orientation of the geometry?
                • C
                  cris_santiago
                  hell yeah 👊
                  • V
                    VictorB
                    I'm hoping you guys might be able to help me out on this crash I'm getting while using Shape Bender. I'm trying to make a bangle/cuff bracelet for a friend's bday. I've designed the bracelet as a flat bar, and then was going to use shape bender to curve it into a bracelet shape. When I run Shape Bender, it says that it's calculating the curve and angles, and that it's breaking the component into 13 pieces, and then shortly after it starts processing, it just crashes.
                    I've tried rescaling the component so that it's true to size, and I still get the same crash. I'm at a stand still right now and don't know if it's a problem with SketchUp or Shape Bender. I'm still a total design newb (this is only the 2nd thing I've designed), so there is a great chance there is a flaw with my work.
                    I've attached the file I'm working with if anyone wants to try to bend it and see if they get the same crash. Any help or words of wisdom are greatly appreciated.
                    RB component.skp
                      Where's the curve to which you want the thing bent? It's a lot of geometry to deal with. Perhaps you could split it into smaller chunks and process them one at a time?
                      It looks like you could do a lot of clean up. Delete coplanar edges and correct the face orientation.
                        Ok...
                        A few pointers.
                        It has some very small facets so works at say x100 scaled up, then scale down back to 'real size'.
                        Small facets can exist but making/manipulating them is problematical.
                        Presumably the bracelet is for 3d printing ?
                        It'll probably needs to be a 'solid'...
                        You have several reversed faces - make all seen-faces off-white and all unseen back-faces the blue - use 'reverse' or 'orient'.
                        You have several 'nested' parts - e.g. the letters - these need exploding into one set of 'raw' geometry inside the 'container'.
                        Some of these letters will have coincident edges with the 'studding' below them and probably inner faces when merged - therefore these edges will have more than 2 faces - the requirement for a solid - the form is edges/faces only and all edges in the form have only 2 faces [now more no fewer]. You'll need to do some editing to relocate or remove these so it will be 'solid'...
                        I assume you want to bend it with the lettering on the outside - it might therefore be easier to set the object on its side and bend it around that way ?
                        The model is far from a disaster - you can readily fix it up, and bend it as needed, with a little thought and effort... 🤓
                        • V
                          VictorB
                          Thanks for the input guys. I think what I'll do is start from scratch and try to do things the proper way. Again, this was only my 2nd design ever on SU and in 3d at all. I'm going to take everyone's advice here and see if I can make this new version much, much cleaner.
                          Thanks for the input! I appreciate it.
                            As I said it quite salvageable as it is... just relocate slightly and explode the nested bits, reverse some back-faces, use section-cuts to see inside and erase 'partitions' etc, erase coplanar edges [several free tools for that] - Entity Info reports it as a "solid" when it's fixed; scale up x100, then orient the object on its side and shape-bend it... finally scale down.
                              markitekt
                              I haven't read through every post here, but I am unable to get this script to work in version 8. It works fine in version 7 but I'm unable to make it work in 8. It may be due to other plugins since I use quite a few. I was just wondering if anyone else had run into problems with other plugins or if its a version 8 issue.
                              Mark
                                Hi Mark. Long time, no see.
                                I use it on SU8 without problems. Does anything happen for you when you try to run it? Do you get anything in the Ruby console if you have it open while trying to run it?
                                  markitekt
                                  Hi Dave,
                                  I've attached the error from the ruby console. I have no clue what it means as I'm not a ruby guy.
                                  I have a feeling it must be related to some other plugin.
                                  Thanks for any help,
                                  Mark
                                  Error.pdf
                                    Thanks for posting that. Can you temporarily rename your Plugins folder and create a new one? Then add only the Shape Bender plugin to it and reopen SketchUp. See if it will run, then.
                                      markitekt
                                      Thanks Dave,
                                      I went back to a clean install plugins folder with the shape bender and all is working. Now, I just have to figure out which plugin is the culprit.
                                      Mark
                                        I'm glad that worked but with a large number of plugins, the trick is sorting out which one is the culprit. Copy half of them and put them into the new Plugins folder and see what happens. If it still works, copy half of the remaining ones and put them in. When it quits working again you'll know you got the conflicting plugin. There have been a few plugins mentioned as being problematic. I'll try to find them for you.
                                        Edited to add: I see that Walt had the same error messages you have but I don't see the resolution. Perhaps he'll see this and chime in.
                                          rendermaster
                                          my test
                                          http://img209.imageshack.us/img209/1522/spiralm.jpg
                                          thanks for the plugins
                                          • N
                                            nebin asharaf
                                            hi...........same problem here......selecting...selecting but its not getting selected....tried many times....
                                            gone through your forums.....just like you said i tried right click..yes now the line is getting selected but the function is not working...........................please help i really like this plugin...wanna try something.....help helpppppppppp
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 63
                                            • 64
                                            • 51 / 64
