    [Tutorial] Modeling a Space Frame
    25 Posts 14 Posters 10.3k Views 14 Watching
    • boofredlayB Offline
      boofredlay
      Thanks Andrew.
      I use Hypercam2
      http://www.hyperionics.com/hc/
      Make sure you change the keyboard shortcuts (Hot Keys) because they can interfere with your SU ones and mess up your video. I found that out the hard way.
      After taking the video I used Windows Live Movie Maker to add text and edit it. Then uploaded to Youtube.
      Both Hypercam and WLMM are free.
      Attaching the Youtube to your post is best explained in Miguel's post here:
      http://forums.sketchucation.com/viewtopic.php?p=144086#p144086
      • utilerU Offline
        utiler
        Cheers, Boo
        Just Curious...
        • mitcorbM Offline
          mitcorb
          You think maybe Hypercam 2 will work on Win 7? The info stops at xp?
            boofredlay
            Yep. I use it at home and work on Win7.
            • mitcorbM Offline
              mitcorb
              Ok, thanks.
                Cool tut ☀
                Maybe you can use the Guides Tool by ThomThom for put the Spheres more quickly?
                Image by guanjin
                http://forums.sketchucation.com/download/file.php?id=84409
                • usenU Offline
                  usen
                  Thanks. 👍
                  http://www.sketchupturkiye.com/
                    shahriyar
                    Thanks Again
                    • brookefoxB Offline
                      brookefox
                      Thank you, Eric.
                      Now if we could only get the size and res of embedded vids jacked up so we can see what the plugin settings are that are being used (JPP in this case). Alas, at present, there seems not to be a way.
                      ~ Brooke
                        Why not go to Eric's YouTube page and watch it full screen?
                          I am pretty sure we can fix all sorts of video embedding issues soon. 😉
                            brookefox
                            I often have problems trying to go to the vid source: I click this way and that, nothing happens. Better not to have to do anything but watch the thing in front of you, I think.
                            Glad Gai's got it covered, pretty surely...
                            ~ Brooke
                              boofredlay
                              Here is a direct link.
                              Nothing special on the JPP settings. Unfortunately the highest resolution for this video is 480p.
                              • 2 / 2
