    Question
    22 Posts 6 Posters 2.1k Views 6 Watching
      jorge2011
      thanks, but what I need is to have many scenes in the same file, and each scene to place components or groups in different positions
        OK. You don't need a plugin for that. Make copies of the components/groups placed throughout the model as needed. Create layers that can be associated with the scenes. Then assign the layers to the components/groups that you want to show in each scene.
        So you might have a component in Position 1 in Scene 1 and that component is associated with Layer 1. All other layers are turned off for Scene 1. Then in Scene 2, the component in Position 2 is on Layer 2 and all other layers are turned off.
        That's how I made this animation.
        [flash=640,510:2y2e33ww]http://blip.tv/play/AYLBv28A?p=1[/flash:2y2e33ww]
        http://blip.tv/designclick-build/lock-stitch-animation-5267339
          jorge2011
          Thank you very much for your explanation
          If this is how I work with the layer and components or groups. But it is more simple, just move objects and save your position in each scene.
          Keyframeanimator is a good plugin, but payment and more complex.
          I just want a simple tool that allows to keep the same object is different positions, different scenes
            I don't think you'llo get what you're after for free. You might as well buck up and get Keyframe.
            • HumpmetwiceH Offline
              Humpmetwice
              You might could try proper animation? http://forums.sketchucation.com/viewtopic.php?t=10946
                Mover ?
                Make animation of any object : start / End
                And you can of course use any movment of the scenes in the same time! β˜€
                What do you want more ?
                  jorge2011
                  Thanks for your reply
                  Pilou: only moves the plug to move or rotate objects, this plugin not support saving different positions for groups or components in different scenes
                  humpmetwice, this plugin is very good, but complex.
                  No need to animate objects. Only save different positions in different scenes
                  similar to:
                  http://www.youtube.com/watch?v=TokvZKmWLlQ&feature=plcp
                  I only need a funsion similar to the first part of the video that records the position of the groups
                  • brookefoxB Offline
                    brookefox
                    There may be some folks out there looking at your subject line and having questions of their own, like what does this guy think the subject line is for? Better to put some meat on that hook if you want to catch something. Otherwise they may think you don't mind wasting their time... Do you know what I mean?
                    ~ Curm β˜€
                    ~ Brooke
                      jorge2011
                      sorry, not understand. my English is a little bad
                        brookefox
                        I often struggle with it.
                        You were doing pretty well, though.
                        ~ Brooke
                          Humpmetwice
                          [flash=640,510:fx0xaozk]http://blip.tv/play/AYLBv28A?p=1[/flash:fx0xaozk]
                          All this was done with just different scenes and layers? If so amazing job and I bet very time consuming!
                            So what is the problem ?
                            SU makes that automatically no ?
                            You want an export image of each different position ?
                            Have you an example of what do you want exactly ?
                              jorge2011
                              thanks for their answers.
                              Pilou
                              Forexample.
                              1 - I want to make an office and try 10 different ways to arrange the furniture. After show my client and titrated in 3d it the most interesting options.
                              I do not need the image, I need the 3D options, then go adjusting the most interesting.
                              This can be done by creating groups and components, duplicate, and show different layers and different scenes. But this makes duplicate geometries and is a bit annoying to go hiding and showing.
                                brookefox
                                You are right about the duplicates but not about the annoying. Once you create the different scenes there is no delay to speak of and the hiding and showing is all done for you. You can have transitional effects and animate it if impressing is in your program.
                                ~ Brooke
                                • sdmitchS Offline
                                  sdmitch
                                  @jorge2011 said:
                                  hola. A question.
                                  There is a plugin, simple and easy, allowing save componenes or groups in different positions and different scenes?
                                  Something like this?
                                  [flash=800,600:30l6ffb1]http://www.youtube.com/v/MfVDs_zvhfA[/flash:30l6ffb1]
                                  http://sdmitch.blogspot.com/
                                    brookefox
                                    That's very accommodating of you, Sam, but you've surely opened a hole in the dike...
                                    Could we have some animation and transitional effects with that, please?
                                    ~ Brooke
                                    • sdmitchS Offline
                                      sdmitch
                                      I,m sure you are right Brooke.
                                        jorge2011
                                        sdmitch excellent. is possible to test this plugin?
                                          http://sdmitch.blogspot.com/ and search Scene Manager ! πŸ˜‰
                                            jorge2011
                                            gracias PILOU.
                                            This plugin is interesting.
                                            I would like, if possible, add some features.?
                                            1 - to use different components and groups.
                                            2 - to usr many identical components.
                                            3 - add an interface to sin, perhaps, html or something similar to the interface of this plugin: http://www.smustard.com/script/RepeatCopy
                                            thank you very much
