    Question
    22 Posts 6 Posters 2.3k Views 6 Watching
    • brookefoxB Offline
      brookefox
      There may be some folks out there looking at your subject line and having questions of their own, like what does this guy think the subject line is for? Better to put some meat on that hook if you want to catch something. Otherwise they may think you don't mind wasting their time... Do you know what I mean?
      ~ Curm β˜€
      ~ Brooke
        jorge2011
        sorry, not understand. my English is a little bad
          brookefox
          I often struggle with it.
          You were doing pretty well, though.
          ~ Brooke
          • HumpmetwiceH Offline
            Humpmetwice
            @dave r said:
            OK. You don't need a plugin for that. Make copies of the components/groups placed throughout the model as needed. Create layers that can be associated with the scenes. Then assign the layers to the components/groups that you want to show in each scene.
            So you might have a component in Position 1 in Scene 1 and that component is associated with Layer 1. All other layers are turned off for Scene 1. Then in Scene 2, the component in Position 2 is on Layer 2 and all other layers are turned off.
            That's how I made this animation.
            [flash=640,510:fx0xaozk]http://blip.tv/play/AYLBv28A?p=1[/flash:fx0xaozk]
            http://blip.tv/designclick-build/lock-stitch-animation-5267339
            All this was done with just different scenes and layers? If so amazing job and I bet very time consuming!
              No need to animate objects. Only save different positions in different scenes
              So what is the problem ?
              SU makes that automatically no ?
              You want an export image of each different position ?
              Have you an example of what do you want exactly ?
                jorge2011
                thanks for their answers.
                Pilou
                Forexample.
                1 - I want to make an office and try 10 different ways to arrange the furniture. After show my client and titrated in 3d it the most interesting options.
                I do not need the image, I need the 3D options, then go adjusting the most interesting.
                This can be done by creating groups and components, duplicate, and show different layers and different scenes. But this makes duplicate geometries and is a bit annoying to go hiding and showing.
                  brookefox
                  You are right about the duplicates but not about the annoying. Once you create the different scenes there is no delay to speak of and the hiding and showing is all done for you. You can have transitional effects and animate it if impressing is in your program.
                  ~ Brooke
                  • sdmitchS Offline
                    sdmitch
                    @jorge2011 said:
                    hola. A question.
                    There is a plugin, simple and easy, allowing save componenes or groups in different positions and different scenes?
                    Something like this?
                    [flash=800,600:30l6ffb1]http://www.youtube.com/v/MfVDs_zvhfA[/flash:30l6ffb1]
                    http://sdmitch.blogspot.com/
                      brookefox
                      That's very accommodating of you, Sam, but you've surely opened a hole in the dike...
                      Could we have some animation and transitional effects with that, please?
                      ~ Brooke
                      • sdmitchS Offline
                        sdmitch
                        I,m sure you are right Brooke.
                          jorge2011
                          sdmitch excellent. is possible to test this plugin?
                            http://sdmitch.blogspot.com/ and search Scene Manager ! πŸ˜‰
                              jorge2011
                              gracias PILOU.
                              This plugin is interesting.
                              I would like, if possible, add some features.?
                              1 - to use different components and groups.
                              2 - to usr many identical components.
                              3 - add an interface to sin, perhaps, html or something similar to the interface of this plugin: http://www.smustard.com/script/RepeatCopy
                              thank you very much
