    Question
    22 Posts 6 Posters 2.7k Views 6 Watching
      If I understand your question, you don't need a plugin to do that.
      But perhaps you're looking for a plugin to do animation? You might look at http://forums.sketchucation.com/viewtopic.php?f=323&t=13234
        jorge2011
        thanks, but what I need is to have many scenes in the same file, and each scene to place components or groups in different positions
          OK. You don't need a plugin for that. Make copies of the components/groups placed throughout the model as needed. Create layers that can be associated with the scenes. Then assign the layers to the components/groups that you want to show in each scene.
          So you might have a component in Position 1 in Scene 1 and that component is associated with Layer 1. All other layers are turned off for Scene 1. Then in Scene 2, the component in Position 2 is on Layer 2 and all other layers are turned off.
          That's how I made this animation.
          [flash=640,510:2y2e33ww]http://blip.tv/play/AYLBv28A?p=1[/flash:2y2e33ww]
          http://blip.tv/designclick-build/lock-stitch-animation-5267339
            jorge2011
            Thank you very much for your explanation
            If this is how I work with the layer and components or groups. But it is more simple, just move objects and save your position in each scene.
            Keyframeanimator is a good plugin, but payment and more complex.
            I just want a simple tool that allows to keep the same object is different positions, different scenes
              I don't think you'llo get what you're after for free. You might as well buck up and get Keyframe.
              • HumpmetwiceH
                Humpmetwice
                You might could try proper animation? http://forums.sketchucation.com/viewtopic.php?t=10946
                  Mover ?
                  Make animation of any object : start / End
                  And you can of course use any movment of the scenes in the same time! β˜€
                  What do you want more ?
                    jorge2011
                    Thanks for your reply
                    Pilou: only moves the plug to move or rotate objects, this plugin not support saving different positions for groups or components in different scenes
                    humpmetwice, this plugin is very good, but complex.
                    No need to animate objects. Only save different positions in different scenes
                    similar to:
                    http://www.youtube.com/watch?v=TokvZKmWLlQ&feature=plcp
                    I only need a funsion similar to the first part of the video that records the position of the groups
                    • brookefoxB
                      brookefox
                      There may be some folks out there looking at your subject line and having questions of their own, like what does this guy think the subject line is for? Better to put some meat on that hook if you want to catch something. Otherwise they may think you don't mind wasting their time... Do you know what I mean?
                      ~ Curm β˜€
                      ~ Brooke
                        jorge2011
                        sorry, not understand. my English is a little bad
                        • brookefoxB
                          brookefox
                          I often struggle with it.
                          You were doing pretty well, though.
                          ~ Brooke
                          • HumpmetwiceH
                            Humpmetwice
                            [flash=640,510:fx0xaozk]http://blip.tv/play/AYLBv28A?p=1[/flash:fx0xaozk]
                            All this was done with just different scenes and layers? If so amazing job and I bet very time consuming!
                              So what is the problem ?
                              SU makes that automatically no ?
                              You want an export image of each different position ?
                              Have you an example of what do you want exactly ?
                                jorge2011
                                thanks for their answers.
                                Pilou
                                Forexample.
                                1 - I want to make an office and try 10 different ways to arrange the furniture. After show my client and titrated in 3d it the most interesting options.
                                I do not need the image, I need the 3D options, then go adjusting the most interesting.
                                This can be done by creating groups and components, duplicate, and show different layers and different scenes. But this makes duplicate geometries and is a bit annoying to go hiding and showing.
                                • brookefoxB
                                  brookefox
                                  You are right about the duplicates but not about the annoying. Once you create the different scenes there is no delay to speak of and the hiding and showing is all done for you. You can have transitional effects and animate it if impressing is in your program.
                                  ~ Brooke
                                  • sdmitchS
                                    sdmitch
                                    @jorge2011 said:
                                    hola. A question.
                                    There is a plugin, simple and easy, allowing save componenes or groups in different positions and different scenes?
                                    Something like this?
                                    [flash=800,600:30l6ffb1]http://www.youtube.com/v/MfVDs_zvhfA[/flash:30l6ffb1]
                                    http://sdmitch.blogspot.com/
                                    • brookefoxB
                                      brookefox
                                      That's very accommodating of you, Sam, but you've surely opened a hole in the dike...
                                      Could we have some animation and transitional effects with that, please?
                                      ~ Brooke
                                      • sdmitchS
                                        sdmitch
                                        I,m sure you are right Brooke.
                                          jorge2011
                                          sdmitch excellent. is possible to test this plugin?
                                            http://sdmitch.blogspot.com/ and search Scene Manager ! πŸ˜‰
