    Manifold solid
    8 Posts 5 Posters 10.4k Views 5 Watching
      Dropout
      Hi All
      I am trying to slice up a model to cut on my CNC. Apparently the part is not a manifold solid. What is a manifold solid, and why isn't my model one? And, how do I make it one?
      Thanks in advance.
      Colonial 8 inch 3D test ver 6.skp
        d12dozr
        Here's an explanation of manifold, AKA "Solid".
        You can use Thomthom's excellent Solid Inspector to help you find holes.
        http://goo.gl/f7ooYh
          Dropout
          Found it a fixed it.
            d12dozr
            Nice! Good luck on the rest of the project. πŸ‘
            We love to see finished pieces -if you can post pics when its done that'd be great!
            • pbacotP Offline
              I gather you are using 8Pro and not 7.1 as per your profile?
                My 'Slicer5' [from whence the error message comes?] only works with >=v8 so you must be using that ?
                A 'solid' [manifold] group is one that contains only faces and their edges, forming a continuous imperforate surface.
                Every edge must have two faces - no fewer and no more.
                So that means no 'unfaced' edges, no 'flaps', no 'holes', no internal 'partitions'.
                'Solid-Inspector' shows that one end has some tiny 'flap' fringes around it.
                If you then Erase those edges the geometry when grouped is shown as 'solid' in Entity Info: alternatively you might want to PushPull the end-face out by the tiny amount to subsume these flap-faces into the main surfaces - this will make the two matching end-faces in line, which is probably what's required ??
                Incidentally you have modeled the whole thing 'inside out' - select one face and context-menu Reverse it, then Orient the rest to match - remember that the 'blue' back-faces go inside objects - the front-faces look outwards...
                  Dropout
                  v8, not pro. I'll change the profile.
                    remibouns Newcomers
                    I can't make my design a manifold solid I need help
                    take one.skp
