    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 231.6k Views 45 Watching
    • bazB Offline
      baz
      Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
      • mitcorbM Offline
        mitcorb
        Hi, cotty:
        Your thread is inspiring and helpful. I have tried a few of the examples, myself. Thank you for posting.
        • jeff hammondJ Offline
          @baz said:
          Nice cotty.
          How would you go about this if you wanted a single face for the front and back?
          Ie: as if it were bent plywood with vertical edges in the z plane.
          Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:)
          baz
          maybe?
          [edit] after step3, delete the face which has all sorts of coplanar lines from the subsmooth.. draw a line to form a new single face.. then push/pull..
            d12dozr
            Just use the Crease tool (at least that's what its called in Subdivide & Smooth), and click on each of those vertices. The Crease tool icon changes from Red when uncreased to Green when creased. There's not a visible effect right away on the model, but you'll be able to tell the difference after running the plugin.
            ...or in this case, Jeff's way is simpler, but you'll still want to crease the end vertices before subdividing so you get square ends. πŸ‘
            http://goo.gl/f7ooYh
            • cottyC Offline
              cotty
              I am not shure, but I will dream of it, maybe a solution will appear ...
              Here is a little boat ...
              cotty_boat.skp
              my SketchUp gallery
              • bazB Offline
                baz
                Thanks Marcus, got it.
                • cottyC Offline
                  cotty
                  Thanks to ninopiamonte, shri, d12dozr, mitcorb for your kind words. I'll try to add new examples regularly. If you have any ideas for simple geometries, let me know or feel free to share them here too...
                  Another example: a very simple wind flower...
                  cotty_wind_flower.skp
                  my SketchUp gallery
                  • cottyC Offline
                    cotty
                    An (empty) piggy bank...
                    cotty_piggy_bank.skp
                    my SketchUp gallery
                      leminilab
                      Here's a little contribution to this great thread:
                      pipistrello lamp
                      pipistrello lamp
                      This one can be certainly found on the internet but I found this an interesting modelling challentge. Could be better but there you go.
                      Thanks a lot for starting this Cotty! πŸ˜„
                      Nicolas
                      • "Live every day as if it were your last and then some day you'll be right."
                      • "ThomThom rules!!!"
                      • cottyC Offline
                        cotty
                        A simple washbasin...
                        cotty_washbasin.skp
                        my SketchUp gallery
                        • cottyC Offline
                          cotty
                          A footprint ...
                          footprint.skp
                          my SketchUp gallery
                            leminilab
                            Seriously, I'm having a blast seeing you enjoying what you do that much! πŸ˜„
                            I like! πŸ‘
                            • cottyC Offline
                              cotty
                              I like! πŸ‘
                              Thank you! And you are right, I enjoy these little Artisan practices πŸ˜‰
                              my SketchUp gallery
                              • utilerU Offline
                                utiler
                                I'm with you nicholas; cotty you bring joy to my day when I've seen what you're doing with Artisan....
                                Just Curious...
                                • cottyC Offline
                                  cotty
                                  Thank you! Here is the next one: "The hand" (anatomically questionable πŸ˜• ) ...
                                  cotty_hand.skp
                                  my SketchUp gallery
                                  • cottyC Offline
                                    cotty
                                    The glass carafe ...
                                    cotty_glasscarafe.skp
                                    my SketchUp gallery
                                      pibuz
                                      Wonderful!
                                      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                      • pbacotP Offline
                                        Would like to see some steps towards the proxy. Is that all free form joining of edges, say for carafe?
                                        • cottyC Offline
                                          cotty
                                          Here are some of the first steps, I will make a more detailed "making of" for the next example...
                                          my SketchUp gallery
                                          • iichiversiiI Offline
                                            iichiversii
                                            That tut looks great πŸ‘
                                            Bring on the Rain...
                                            • 22
                                            • 23
                                            • 3 / 23
