    [Plugin] Tree generator v0.2
    36 Posts 20 Posters 90.4k Views 20 Watching
    • PixeroP Offline
      Pixero
      @thomthom said:
      This fractal tree generation is great. 👍
      If you need some inspiration:
      http://www.frecle.net/index.php?show=treed.about
      tree[d] is the best tree creation app I've ever tried. And its free! (outputs to .x)
      And by the same author, the Tree editor in the coming Unity 3 (tree[d] on steroids).
      http://hometime.net/tree%20edit/tree%20edit.html
      Note the yellow circle and squares. With them you can move and modify branches manually.
        pibuz
        Following this with HUGE curiosity.
        Can't wait to see to what spectacular plugin this will lead..
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
          archigrafix
          I too. Of course biggest challenges are:
          1. go Low or High poly depending on the user need....
          2. Use of component intensively for SU memory management and for fast modifications
          3. UV mapping of the parts at creation time...cause after that it's almost impossible job to do with SU tools
          Agir comme un homme de pensée, et penser comme un homme d'action...
          • RichardR Offline
            Richard
            Wow that unity generator looks sweet! Looks to have some funky real time functionality though the example video leaves a bit to be desired!
            I'm still keen to see Tom's new creations! Any idea where he is at with them! We so need a better tree option for SU use!
            As for my own developments (and a far cry from the first shitty job like ten years ago), I've worked out how to cut the poly count WAY down and still get good leaf grouping at little poly cost, yet as Archigrafix hints, once I get to the bark mapping to the trunk and branches I'm stuffed and all fell in a heap!
            BUILTBRAND.COM.AU
            • bmikeB Offline
              bmike
              How does one get a tree[d] tree into SketchUp?
              I'm running Pro 7.? or 8...
              • RichardR Offline
                Richard
                Hmmm? Still trying to get a workflow happening, this mapping is looking a little better!
                BUILTBRAND.COM.AU
                  tald311
                  Bump. As a landscape architect the one thing I wish I had was a tree-maker for SketchUp. Ideally, trees that can be rendered so full 3D Trees. Crossing fingers and hoping for an early Christmas
                    tald311
                    No easy way. I used the OBJ plugin and got the geometry into the model but not the textures.
                    I use 3D trees from the warehouse for rendering and get decent results. SU 7 and 8 can handle a good amount of pollys. It's not VUE so your not going to create forests but you can get some good results.
                    Most of my models use 3D trees and I can render up to 2 million pollys in Podium, Shaderlight or whatever.
                    Having 3D trees in SketchUp to be rendered is great. I am a broken record today.
                    Daniel
                    • bigstickB Offline
                      bigstick
                      I have taken Richard's excellent work on this, added some more branch and leaf types, and done some restructuring with regard to names and insertion points, and come up with something that can build some pretty nice low poly 3d trees.
                      I probably ought to warn you that it does take a little time and effort, but the results are good and render fairly quickly.
                      Apologies for the Podium 'plug', I have just left the info bar on to show the render time on my 2010 Core i5 MacBook Pro.
                      TREE FACTORY 2_1_4.skp.zip
                        Nice tree! 😄
                        Renders well. Would love to see more of these trees.
                        • bigstickB Offline
                          bigstick
                          They are only 700k in size as well, which is pretty neat.
                          I wonder whether this approach would lend itself to a Ruby script. Once you have the branching structure, level 1, level 2, level 3 etc created with simple components, if the Ruby script determines the insertion point, rotation, angle of each component, you could swap out or load in any number of more complex branches. This is in effect what I did manually with the predefined components. I made the paths for the branches manually, used Tapermaker to create the 3d extruded versions, and built the (and modified Richard's) 3d leaf clusters.
                          Let's say you have an L-system script which creates the basic structure, you could have modules which create the leaf components, and the branches. Then, you swap the simple components for the more complex ones and you're there.
                          I think one could create a fairly straightforward typology for trees. There are a few basic variations of form, which simplify the hundreds of variations in the parameters to build trees. For example a scots pine (like most conifers) has a single trunk, with branches radially around the trunk, projecting horizontally. Larch trees have a similar single trunk with branches that are angled downwards and curl up at the ends. Birch trees also have a primary single vertical trunk element (although some species have more) with slender branches that are generally angled upwards, but tend to droop. Oak trees have a short (relative to the height of the tree) primary trunk, which branches into a number of thick branches which are inclined to branch more or less horizontally. There are also only a few types of basic leaf arrangements.
                          I think that it ought to be possible to build up maybe a dozen basic templates which will cover maybe 80% of the most common tree types.
                          I realise that this is a gross over-simplification, but having tried at least 8 different tree generation applications, it is difficult and time-consuming to create trees that look like real species. Without any real understanding of the botany behind the tree growth patterns, one can struggle to create something that looks like a real example of the species.
                          The application Woody3d (http://woody3d.com/home/) is a good example. If you look at their tree library, some of the examples there look good, but nothing at all like their real life counterparts. It looks like a nice application, and some of the rendered images look good, but the trees look a bit limited. For example it doesn't seem to be able to simulate branch droop. One of the things that stops me spending a lot more time on this is my limited knowledge of trees 😄
                          There are lots of Open Source applications whose code that could quite legitimately be used for this, but I suspect it would be a very time-consuming task!
                          • bigstickB Offline
                            bigstick
                            I found this old thread and thought I would add an update. I've been working with the author of NGPlant to implement collada export. The latest version is pretty neat and creates trees with instanced leaves as SU components.
                            NGP is a cool application. It's an open source cross platform WYSIWYG tree generator. More info here:- http://ngplant.sourceforge.net
                            I created some video tutorials on Vimeo for building trees with NGP.
                            The tricky thing is to get realistic trees with a manageable poly count.
                            • 2 / 2
