    Sketchup won't run on Lion
    10 Posts 5 Posters 493 Views 5 Watching
      linea
      Hi all
      Hope you are all keeping well,
      I am hoping that somebody can help me. I have a macbook air running Lion and recently it has decided that it will not run Sketchup (8 free). It has ample memory. I've tried a clean install, clicking on files as opposed to the icon but nothing works. Any ideas?
      Thanks in advance
      jon
      p.s, for no particular reason, I have attached something I'm working on
        driven
        If it was working, and you still have space left on your hard-drive, I'd suspect a corrupt .plist.
        ~/Library/Preferences/com.google.sketchup8.plist
        a fresh install will actually just carry on using the old .plist unless you park it or bin it, first.
        It will also use the one from v6 or v7 as a basis if it's in there, so bin those as well.
        often manually trashing the plist and emptying trash will do the trick.
        Some would suggest a System shutdown before continuing, not a Restart
        I have a folder where I 'Park' different versions, which seems to have the same effect.
        Restarting your current SU will then write a new one.
        Move and rename your plugins folder first, and don't put any back until SU works.
        let us know if you need more specific help, Lion's Path may be a bit different.
          linea
          Hi John
          Thanks for helping, but I'm maybe getting this wrong. I think I've looked in the right folder but there is no file called com.google.sketchup8.plist
            driven
            I missed out the 'free' bit...
            you probably looked in the HD/Library/, it's in the User's [as in your name]/Library
            on Leopard it's like this, you wont have the red folder, I have the pro version shown below and keep a free version in the separate folder...
            otherwise, open Terminal.app and paste this in
            open ~/Library/Preferences/com.google.sketchupfree8.plist and it will open.
            if it does, right-click it's name in window title and select to go to the folder.
            once found you can close it and use
            rm ~/Library/Preferences/com.google.sketchupprofree8.plist and it will be removed completely.
              linea
              Hi Driver
              Thanks for the help. Sorry for the late reply. I have tried this and unfortunately this hasn't fixed it either. I'll take a trip to the mac shop...
              • TIGT Online
                Have you got v8M2-free - I think it addressed some issues specific to Lion being flaky...
                  linea
                  After months of trying to figure this out myself I finally went to the mac shop and they fixed it so I'll explain in case it helps anybody else in the future. My problem was that I could not get passed an unresponsive green SU startup screen, I just got the hourglass and then an error message at which point SU crashed. Somehow the mac shop guy managed to freeze the hourglass so that he could un-tick the "show on startup" box on the green window. He said he had come across the issue before.
                  jon
                    Jon, there's a new maintenance release now. Do you have it installed?
                      linea
                      Hi Dave
                      Hmm, not sure. I will check that
                      jon
                        This would have helped if you described when you first posted about your problem. All this info is valuable when trying to find the cause and a solution. Also, error messages are normally extremely useful in determining the issue - include them in your description of the problem.
