    How to tackle this slopy thing...?
    18 Posts 8 Posters 612 Views 8 Watching
      pisosse
      I'm sorta lost on how to put a top on this construction.
      The side is tilting in every direction so to get a face on it and connect that to the beam is crazy difficult.
      http://mentalindustries.com/help/1.jpg
      http://mentalindustries.com/help/2.jpg
      look at this little video on where I am in the process.
      404 Not Found
      (mentalindustries.com)
        @pbacot said:
        Drawing with line tool from "a" hover over triangle until thick black line appears, press shift and draw fourth side to adjacent edge of column for "b".
        Thick black line and a blue inference point with a tooltip "On face". Then press Shift.
        • pbacotP Offline
          and "Press and hold shift." 😉
          • brookefoxB Offline
            brookefox
            The relevant recommended inference is the shadowy 'on the plane of'?
            I know 'on (the) face (of)', in this case the back face on which the line is being drawn, but I don't know 'on (the) plane (of), meaning the three points defining the triangle. (As you know, the new line need not be parallel, and that inference would be magenta).
            General inference help:
            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=70143
            ~ Brooke
            • pbacotP Offline
              In the attached picture, draw the red triangle. I assume you know either "a" or "b". Drawing with line tool from "a" hover over triangle [edit:while holding down the shift key] until thick black line appears, HOLD the shift key and draw fourth side to adjacent edge of column for "b". Edge "a-b" should then lie in the red triangle's plane. Complete four-sided shape, group face and four edges, and push-pull. Hope this helps. Untitled.png
              [EDIT: before push-pull you may want to continue drawing the outline of the face that extends to the left.]
                pisosse
                AWSOMENESS...! your the most helpfull and ressourcefull bunch I've met on the net in many years.
                THANKS!
                  @pbacot said:
                  ...and "Press and hold shift." 😉
                    brookefox
                    Please see my attempt to answer my own question. I don't get a thick black line or the inference mentioned. ('On face,' and the typicals I get, of course.) The black dotted line Peter shows looks like a construction line rather than the 'thick black' line, but I don't know since I cannot replicate it.
                    ~ Brooke
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi folks.
                      You can also start simple and complexify afterward.
                      Click on the scenes tabs of this SU file for ideas.
                      Box on a post.skp
                      • Wo3DanW Offline
                        Wo3Dan
                        @brookefox said:
                        ..... The black dotted line Peter shows looks like a construction line rather than the 'thick black' line, ....
                        The dotted line is indeed a guide or construction line.
                        To replicate a thick black line (in general):
                        start an edge on a face F, or on its perimeter (or even somewhere in the same plane that face F is in, but outside the perimeter. Then hover the cursor to somewhere on that face F till you see 'On Face' and now press and hold down [Shift]. You should now get the thick black line to lock the "edge in progress" to face F.
                        While holding down [Shift], you can move the cursor away. The rotating thick black line is "connected" to its inference 'On Face' by a thin dashed line and stays in plane. It ensures that the second endpoint will also be in the plane of face F. Don't release [Shift] till after the second click.
                        • pbacotP Offline
                          That is a guide line such as OP has in his video showing the establishment of the side of the triangle, "a" being the point to complete it. The inference indicator is a thick black line, while you are drawing with the line tool.
                          I started drawing at "a" so I can draw "a-b". Note (as I amended my first post ealier 😳 ) You press shift as you pull out that edge with the line tool, and pass over the face. The line changes to a heavy black line. In this case it's simultaneous with the "on face", which you do get. You should be getting a heavy line if you are drawing.
                          I often don't know how to describe what I am doing because I am doing it automatically. I noted the pressing of shift but not exactly when.
                          • gillesG Offline
                            gilles
                            How did you learnt this?
                            I've never read or see anything about this.
                              A couple of YT videos:
                              http://www.youtube.com/watch?v=rDvwHon6-zY
                              http://www.youtube.com/watch?v=fFfmIgJqlIw
                              • gillesG Offline
                                gilles
                                Never stop learning. 😉
                                • simon le bonS Offline
                                  simon le bon
                                  +1 👍 👍 😳
                                  simon
                                    brookefox
                                    Thanks, Gerrit, you nailed it for me: Thin black line changing to thick when pressing shift to lock whilst getting 'on face' inference indicators. For me, it was in fact a missing inference: 'on plane of'. Thank you, Peter. I missed the OP's video link entirely.
                                    SNEAKY EDIT: Pardon what bears repeating until is sinks in: I think the quote in Gilles' post following misses the key point that the black line is not thick until you press and hold shift.
                                    ~ Brooke
                                      brookefox
                                      More specifically, if you are particularly interested in the surface or planar lock which this thread centers on, go to minute 5 of the second video listed above. All of it is for me a good inference locking reminder, though.
                                      ~ Brooke
                                        In this case, you can even link like this below - watch the #t=05m00s part at the end of the video link.
                                        http://www.youtube.com/watch?v=fFfmIgJqlIw#t=05m00s
                                        Unfortunately this does not work with the simple phpBB embed code.
