    Mac pc differences- AGAIN
    14 Posts 3 Posters 540 Views 3 Watching
    • cmeedC Offline
      cmeed
      Hello All
      Can someone help me understand the differences when opening a new SU window on a pc than on a Mac. I've used a Mac for ages but recently I've started using a pc.
      when i open a new window on the Mac, Sketchup opens window after window. when i open a new window on the Pc it shuts the previous window and open a new one.
      To get multiple windows open - i open an existing project using windows explorer, and can have multiple projects going, but as soon as i want a fresh window, it will close what i am working on
      (file-Open or CTRL+O)
      So using explorer is the only way - enlighten me sketchucation!!
      c
        Yes, you need to launch a new instance of SketchUp, just execute the shortcut again to start with a new fresh model. On Windows each model is a separate instance, while on OSX SU is an MDI application.
        • cmeedC Offline
          cmeed
          ahhh.... ok
          takes a bit of getting used to but there we go .
          Multiple-document interface - Wikipedia
          (en.wikipedia.org)
          ps - plugins certainly work better on a PC.
          • cmeedC Offline
            cmeed
            Something i need to also understand is the difference in saving
            The file names change sometimes
            example
            doc1.skp is what i opened
            gets changed to 0.skp
            then 1.skp
            for the most recent......
            whys this?
            c
              i've never seen that happen on either my PC or Mac.
                example
                then 1.skp
                whys this?
                c
                0.skp, 1.skp is temp files SketchUp to to write to, once the model is successfully written to file the 0.skp file will replace the original and 0.skp will be removed.
                  Ah, I thought the he was saying the file name is getting changed.
                  • cmeedC Offline
                    cmeed
                    thats what i thought was happening.
                    thanks again
                    • cmeedC Offline
                      cmeed
                      hold on ...!
                      so why would i still have 0.skp and 1.skp if they are removed
                      Am i doing something wrong?
                        @cmeed said:
                        hold on ...!
                        They should not remain - something strange is going on. Where are you storing your files? Network drive?
                        • cmeedC Offline
                          cmeed
                          hello again, been away from the computer for a few days - apologise for the delay
                          my files are stored in Documents which is on the local hard drive
                          • cmeedC Offline
                            cmeed
                            i've experienced another difference.
                            (PC) I resized the viewport and all the tool bars I'd arranged neatly are now haphazardly all over the place. ?
                              Yes. This is a normal sort of thing. After you put the toolbars where you want them, go to View>Toolbars and choose Save toolbar (or whatever it says.) In the future you can choose Restore Toolbars to reset them after resizing the window.
                              • cmeedC Offline
                                cmeed
                                great help---- i love Sketchucation......
